Clearly something has been corrupted but so far the following action has not resolved problem
1. Complete reinstallation of Office (I am using 2003)
2. "Repair Acrobat Installation" from Help Menu and system Restart (using Acrobat X v10.1.5)
If I try to enable the Acrobat AddIn in Word (either manually or through Acrobat) Word reports a runtime error.
Hey there, is there any error number?
and do try this please:
1. Launch Microsoft Word.
2. Click Tools > Macro > Security.
3. Select Medium on the Security Level tab, and click OK.
4. Exit Microsoft Word.
5. Re-launch Microsoft Word.
http://helpx.adobe.com/acrobat/kb/error-runtime-error-start-microsoft. html
I know the verion it is not the same but the solution might be there ![]()
Hope it helps !
Thanks for suggestion however I tried and it did not work. I normally keep Macro Security Low anyway for my own macros.
No error numbers - I get the following Message from Word (or rather from MS Visual C) when I renable addin in Word
Microsoft Visual C++ Runtime Library
Runtime Error
Program Files(x86)\...\OFFICE11\WINWORD.EXE
This application has requested the Runtime to terminate in an unusula way. Please contact the application's support team for more information.
The addin itself is which has to be disabled is described as:
acrobat pdfmaker office com addin (pdfmofficeaddin.dll)
Failed on this
A complete reinstall of the whole of OFFICE11 where all files had been deleted - has made no difference.
Moreover I find that XL loaded with my normal VB programs also fails
I get System Error &H80004005 (-2147467259).
when I try and delete what may be offending code and Save
I get Compile error: Out of memory ... in relation to a VBA line Dim x as New EventClassModule
Due to some automatic code that starts up with the Workbook
This VBA code has been operating fine on an almost daily basis for several years.
So I have some problem that seems to be outside a full configure of OFFICE11 which may or may not be connected to Adobe Acrobat addin - which started my investigation.
North America
Asia Pacific
