Bulldawg_29
Colorspace
Jan 25, 2013 7:16 AM
Tags: #illustrator #indesign #cs6
We are running Creative Suite 6 on our macs here.  When you create a new spot color from the library the alternate color space is in LAB.  We work at a printing company and this doesn't do us very much good.  Is it possible to change this to be CMYK?
Thanks for your help!
  • Rob Day
    Oct 16, 2007
    Jan 25, 2013 7:36 AM   in reply to Bulldawg_29
    If the color is going to print as a spot why do you want a CMYK definition, there will be no CMYK inks used on press? By default the Pantone and Toyo solid ink libraries are defined as Lab but there's nothing stopping you from converting their definitions to CMYK via the swatches panel.
  • Rob Day
    Oct 16, 2007
    Jan 25, 2013 7:50 AM   in reply to Bulldawg_29
    Is there a way to change the default to CMYK instead of LAB like it used to be in all previous versions?
    The Use standard lab Values for Spots check box no longer has any effect. Is the problem with  proofing the spot color or outputting separations?
  • Rob Day
    Oct 16, 2007
    Jan 25, 2013 8:18 AM   in reply to Bulldawg_29
    So if you change the client's swatch color definition via the swatches panel the imposition works? You could script that change—the script would make the conversion then export the PDF.
  • Rob Day
    Oct 16, 2007
    Jan 25, 2013 8:47 AM   in reply to Bulldawg_29
    This AppleScript will change the mode of all spot colors in the active document
    tell application "Adobe InDesign CS6"
        set space of every swatch of document 1 whose model is spot to CMYK
    end tell
    You could also combine the color change with a PDF export. I have a template for that if you want it.
  • Rob Day
    Oct 16, 2007
    Jan 25, 2013 8:58 AM   in reply to Bulldawg_29
    This asks for a save folder and a PDF preset, makes the conversion, and exports:
    http://www.zenodesign.com/forum/ExportCMYKspot.zip
  • Rob Day
    Oct 16, 2007
    Jan 29, 2013 11:39 AM   in reply to Bulldawg_29
    Peter Spier posted this article which explains how to get the previous InDesign dual definition Pantone solids
    Pantone Plus color libraries
    Jan 29, 2013 11:47 AM   in reply to Rob Day
    Technically, I posted a link to the article, like you.
