Bradmoose
rendering issues with swf, layers disapear
Jan 25, 2013 9:49 AM
http://www.eyelookmedia.com/downloads/citykiosk.swf
this is my project. Using AS 3 when you go to interactie maps -> maps of london, you can select what you want to see on the map.  Unfortunatly when in full screen mode or web site embeded once you hit about 75% the next layer you select cause another layer to unslect at random.  The project works great when tested or swf on desktop.
Anyone have any ideas what woudl cuse this??   I am using the visable command to make all layers visable=false on load then the buttons are a toggle between visable / not
Thanks in advance
Brad
  • kglad
    Jul 21, 2002
    Jan 25, 2013 10:59 AM   in reply to Bradmoose
    there's a limit to the number of semi-transparent bitmaps that can be rendered.  you could be exceeding that limit.
  • kglad
    Jul 21, 2002
    Jan 25, 2013 11:53 AM   in reply to Bradmoose
    it depends on the player version but it's something like 24.
    convert to movieclips and enable their cacheAsBitmap property and you should be able to circumvent the problem.
