v65913106
Need aspect ratio to match still images
Jan 25, 2013 2:18 PM
    I create slideshows from still images using CS6 that are then put on DVD and uploaded to vimeo.  The problem I'm having is that I wind up with letterboxing on the sides (not top/bottom) since the aspect ratio isn't correct
I've looked on google and I can't figure out how to create a custom project that has an aspect ratio that matches the still images instead of trying to force them into video aspect ratios.
Is this possible?
Thanks.
    Jan 25, 2013 3:38 PM   in reply to v65913106
    It depends on which version you are using.
    In CS6 you set Scale to Fill in the export settings. This will correct the small black bars on each side.
    In CS5(.5) you crop before you output to dvd.
    For ntsc you might need to tweak the settings.
    Jan 26, 2013 11:38 PM   in reply to v65913106
    The settings of the project don't matter as much as you might think. The settings of the sequence do. It is easy enough to create a sequence from a photograph and the settings will be perfect. Read this: http://forums.adobe.com/message/3804341#3804341
    However...
    If you are shooting pictures like I do, they are 3:2.  That ratio does not exactly work on a DVD. You can make it work by editing in a 3:2 sequence and then when you are finished you can do any number of things. You can nest your sequence into a 4:3 or 16:9 sequence and you will have choices to make. Do you scale the images down until you see everything but you have black bars, or do you scale them down to fit the sides but that means cutting off the top and bottom.
    The problem is that there is no way to publish a video on a DVD with a custom shape that I know of. Someone like Jeff Bellune might show up and provide an answer. He is an expert DVD guy.
    I don't know how you could get a DVD to play a 3:2 ratio video, but for YouTube it is a simple matter of using the pictures to create the sequence.
    Then all you need to do is export using a 3:2 ratio, like 1620X1080, meaning you might have to unlink height and width. I have to tell you that you can upload a 3:2 video to YouTube but YouTube will play it back in a 16:9 frame amd leave black borders on the sides. I just checked.
    You see, video is 16:9 or 4:3. Photos are 3:2 or so. Now, my new camera can shoot 16:9 photos, and some people shoot that way to avoid the problem you have right now.
