I am trying to place two images into my ID document. The first one is a 350x200px jpg. The second is a 728x90px jpg. Both have been saved out of PS in the exact same way. The first jpg places at 100%, but the second places at 50%. I have tried creating new jpegs for testing, checked all my settings, but I can't find why this is happening. Why aren't both of my images placing at 100%?
I am on the most up-to-date version of InDesign (8.0.1).
Hi HammyKG,
You need to take a look at the document settings for your images. It sounds like they have different pixels per inch (PPI) measurements.
If I have two images that are both 300px by 300px:
and place them in InDesign, but one is 72ppi and the other is 300ppi they will place at different sizes:
It is a little bit confusing if you are coming from a web design background where pixels are the only way to define size, but in print PPI is king. If you have Photoshop you can open these images and change their PPI by going to Image > Image Size and changing the Resolution option. If you are printing the document I would recommend you make the PPI 300. If you are using it on the web I would make it 72ppi.
I'm gong to believe that you've saved both at 72 ppi and one really is placing at 50%. First, there was a bug that would scale images of some certain dimenesion, but that probably is not what's happening. Second, sometimes ID guesses about images that were never actually saved in Photoshop, but are direct from the camera.
And third, and probably the most likey, in my opinion, are you placing the files into existing frames? The frame may have had a scaling factor or fitting option applied before you placed the image.
I really believe this is an issue on the InDesign side. I'm placing these jpgs one at a time, without an existing frame, just to keep all factors simple. I've checked my Frame Fitting Options and the Content Fitting is set to None. It doesn't make sense for InDesign to place one graphic at 100% and to place the other at 50%. I've tried creating new jpgs (as shown below), so I know it's not specific to the original files in question.
Do you remember I mentioned a bug in my previous post? I think you just found another set of dimensions that triggers it. You can report it at Adobe - Feature Request/Bug Report Form and maybe it will be fixed sometime around CS9.
A little of both, I guess. This is the second time I kow of that this has been reported, so it's real enough, but it's also only the second time and the last time was over a year ago, I'm pretty sure, so it isn't affecting a lot of users, and it doesn't crash the file or anything awful, so it's got to be low priority.
North America
Asia Pacific
