Just downloaded 7.3 but does not show in plugins. The download appeared to go OK but the plugin has not installed. Any suggestions?
Did you get any kind of error messages while installing the 7.3 camera raw plugin?
Did you run the installer after downloading if not gotton thru the pse 11 editor Help>Updates
The 7.3 camera raw plugin itself should be in:
(right click on the plugin and choose properties to see the version)
C:\Program Files\Common Files\Adobe\Plug-Ins\Elements 11\File Formats
Did you do the install on an administrative account?
Is your xp system 32 or 64 bit?
Thank you for the last post. The install gave no error message when loading the 7.3 plugin like an update at the end of the installation of elements 11. I checked the above C:Program Files etc and found the plugin in Formats. Under "properties" it showed as Ver.7.3.0.71.
Also, I installed as an administrator.
The plugin does appear where you indicated but does not show in the Elements drop down menu. Thank you for your continuing support.
PS 32 bit
I think you have the right plugin installed as the 64 bit version is several mb larger in size.
I'd try resetting the photoshop elements 11 preferences by going to Edit>Preferences>General in the pse 11 editor and clicking on
Reset Preferences on next launch and restart photoshop elements 11.
If that doesn't work then try deleting the photoshop elements preferences folder manually by closing pse 11
and going to:
C:\Documents and Settings\Your Name\Application Data\Adobe\Photoshop Elements\11
and delete the Editor folder and then start pse 11.
This all very strange as there have been a couple of other posts recently with problems with the 7.3 camera plugin and pse 11.
You might try turning off your virus scanning software and see if that makes a difference.
(be sure your not connected to the internet and don't forget to turn it back on)
I know this isn't the right way to get the plugin to work, but just as experiment you could move the camera raw plugin to
the plugins folder in pse 11 and see if that works.
C:\Program Files\Adobe\Photoshop Elements 11\Plug-ins
I'm kinda running out of suggestions, but here's the 7.3 camera raw plugin from a windows version of pse 11.
Uncheck the additional plugins path in the editor, go to the below folder and delete the old plugin and put the downloaded one in after unzipping.
Tried all of the above with no success. I think I shall uninstall from my desk top and install onto my laptop and hope that that works. It is frustrating because I know how good the program is having used Elements 8 for the past eighteen months or so.
Can I thank you again for your help and I'll let you know how the program runs on the laptop.
Best wishes to you.
Have installed Elements 11 on laptop. Windows 7 OS. Plugins under Help shows ver 7.1. When trying to update under Help I keep getting an error message that the server cannot be accessed and suggests I try again later. I have tried several times and keep getting the error code U41M1C212. Other wise the program seems to work ok. Any suggestions.
Try this solution:
<http://dasongoh.blogspot.co.uk/2011/12/how-to-fix-adobe-application-ma nager.html>
Good luck and post back.
North America
Asia Pacific
