BhSussman
Unable to create guides that Show up
Jan 25, 2013 5:48 PM
Tags: #guides
I am unable to create guides (those light blue balancing horiz & vert lines) in fireworks 6. Whenever I try to create a guide it re-draws the ruler origin. I even watched a video demonstrating this and when I try to follow it it still re-draws the ruler. What am I doing wrong?
Update: Okay, I was able to create guides...but only sometimes. Usually the guides don't stick! I can't tell when the guides will show up or not. Could this be a memory problem? I do have the latest & best Asus gaming PC.
Thank you
    Jan 25, 2013 6:35 PM   in reply to BhSussman
    Are you really using Fireworks 6? If so, that's a very old version…
    As far as redrawing the ruler origins, that should only happen if you drag from the top left corner, where the rulers intersect. Otherwise, to create a new guide, you drag from the horizontal or vertical rulers at the top or side of the canvas.
    There are a few basic guides-related commands in the View menu. There's also a really powerful command panel extension that can help you in working with guides: http://www.adobe.com/devnet/fireworks/articles/guides_panel.html
    You're not the first Fireworks user to experience some issues with the drawing and rendering of guides. Unfortunately, I'm not sure what would be causing the issue(s) you're experiencing.
    Jan 25, 2013 6:39 PM   in reply to BhSussman
    Here's a previous thread on this subject: http://forums.adobe.com/message/4341999
