After spending time in PS elements 11 making changes in color and applying frames etc. I noticed after saving the file my resolution went from 5.5Mb to 847kb. Why is this? Help!!!
I think I know what I did wrong. I just chose the wrong file size. It couldnt have been my original picture. Typically when you change things in PS it shouldnt
reduce your file size/resolution correct? I have a few different computers, one is a mac with PS 5 and a PC laptop with PSE 11. Hopefully its ok to use both for editing the same picture. They are in 2 different locations. Thanks for responding......
I don't see why everyone is saying that editing a JPG and saving a JPG will not reduce the file size. It can reduce the file size. Even with a single save.
I don't think going from 5.5MB to 847kb is anything to worry about. It's entirely possible, depending on a lot of conditions.
Furthermore, capegirl1, my advice to you would be to stop worrying about file size of JPGs. If you think the file size of JPGs is a meaningful indicator of the quality of your photo, or the correctness of your actions, then you will be misled often. Just stop paying attention to it.
I would disagree with dj_paige to some extent. It is possible for certain editing steps (saving as jpg low quality, for example, or downsampling and upsampling again, rasterizing a vector and then dragging it more than 100%, etc.) to reduce the available information to a point where the print will be lousy.
Barbara- is it ok to use different PSE on one photo at the same time? As I have PSE 6 on my mac and PSE 11 on my PC. Both in different locations, so I may use my mac at one point, save the file then import to my PC on another day.
Secondly, is it ok to rename a file for saving? Or should you keep the assigned name? I often change the name.
Thank-you everyone for your help.
Years ago I wanted to print a panaroma and it was rejected by Ezprints as not a high enough resolution to print. This does occur and kudos to the companies who do a check and reject pictures that will print poorly due to reolution.
Of course, printers reject photos if the resolution is too low.
Resolution is not file size. Let's stop confusing these items.
I don't really see a problem in using the Editors from different versions of PSE on the same photo, provided you save as TIF or PSD. (If you save as JPG, there is a quality loss, and then you open the file again and save it again, there is additional quality loss.)
I wouldn't use the Organizers from two different versions of PSE one the same photo.
I think you should always use a different name than the original photo when you save a photo, you never want to overwrite your originals.
Great, so changing the name to save it differently will not cause any issues. Good to know. For example, if I edit a photo in PSE
I may save the file as 0107PSE.jpg vs the original 0107.jpg. So, I know where I did the editing as I also have Photodirector on my PC, which I would use the itials PD at the end. For some reason, I was also trying to save (save as) a photo as a jpg in PSE11 and it only gave me a choice of
pse or pnb (I believe as the other choice), but did not see jpg? There was no export option. Your thoughts?
I am pretty sure its a jpg file. I am getting myself confused because I am a mac person. And i have been working on my new PC laptop which has PSE 11 and another program called Photodirector. So, I am pretty sure I am saving files correctly. I am at work, so I cant look at it this moment. I could always try and email the jpg to you.
I did what you said, go to image and choose 8 bit. But it wasnt a choice because it was grayed out, so it must already be one. Then another choice was bitmap and maybe colorindex?? Not 100% sure on that one.
I believe I may have started editing it on my mac with has the full version of PSCS5. Saved that file as a jpg.
Then I wanted to do more editing using Photodirector on my PC, put the file on my thumbdrive and downloaded it to my PC. From there I did some editing in PD (similiar to LR). Then final editing on the PC with PSE.
Sorry, I know this sounds confusing. The reason I use my full version of PS is it has HDR toning which I like to play with. So, I usually start there. In the end, I always "save as" jpg. Hopefully I havent totally confused you.
Thanks so much for your help.
It either is a JPG, or it isn't. When you get a chance, please confirm.
If 8bits was greyed out, then it is 8bits, and you should be able to save it as an 8bit file, which includes the ability to save as a JPG.
If for some reason, you can't save it as a JPG, you probably ought to let us see some screen captures (for example, of the "Save As" dialog box) and maybe some other things that I will think of as we go on.
I figured out part of the problem, maybe you can explain. I have 2 files of the same picture, one is in a folder on my desktop. But the other one is not, it is pse file icon on the desktop.
The file in the folder will "save as" a jpg/ But the file with just the pse will not. I have no idea though how I saved it in a folder. I usually do save as, name the file and save it to the desktop.
Sorry for the quality, taken with my phone.
North America
Asia Pacific
