Marc Eisenoff
Scaling a layer in photoshop CS6 and file size?
Jan 26, 2013 9:19 AM
Tags: #photoshop #layer #cs6
Why should scaling a layer in photoshop CS6, have an effect on the size of the file?
  • JJMack
    Jan 9, 2006
    Jan 26, 2013 10:18 AM   in reply to Marc Eisenoff
    Photoshop supports any size layers. Layers can have any aspect ratio and size and are not limited in size to canvas size.  When you scale up a raster  layer in size its done using interpolation. If you save a layered file format all layers pixels need to be recorded in the layer file.  Pixel data is the largest data part of image files.  Scaling Layers up in size can greatly increase the size of a layered image file.  The same document saved in an image file format that does not support layers will be much smaller. For only a single composite layer the size if the documents canvas will be saved.
  • Pierre Courtejoie
    Jan 11, 2006
    Jan 26, 2013 10:21 AM   in reply to Marc Eisenoff
    Hello, If I'm not mistaken, the transparent areas are more compressible than the non transparent ones, given the latter have also RGB values.
  • JJMack
    Jan 9, 2006
    Jan 26, 2013 10:35 AM   in reply to Pierre Courtejoie
    I would think that two areas that are equal in size where one area is all transparent and the other area is all white 255 255 255 RGB that these areas would compress to about the same amount of data.   Details show through different value RGB values and will not compress as well as a solid white wall.  Not all images are compressed.  File sizes differ greatly depending one image file format save.
  • Noel Carboni
    Dec 23, 2006
    Jan 26, 2013 10:35 AM   in reply to Marc Eisenoff
    Define "the size of the file" please, explicitly.
    There are eleventy seven different things people might mean by "size of the file".
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jan 26, 2013 10:37 AM   in reply to JJMack
    By the way, full transparency in Photoshop is represented by pure white pixels (e.g., R, G, and B planes with all max values) with an additional layer mask that's all zeros.
    -Noel
  • Pierre Courtejoie
    Jan 11, 2006
    Jan 26, 2013 10:50 AM   in reply to Marc Eisenoff
    Given the fact that the content outside the visible area of the image is saved (it is often called "big data"), unless you trim or crop it out, yes, I expect that data to have some "weight"...
    About your second question, yes, it's the number of pixels that matters. Try it with a document of the same pixel amount, but different resolution, drag one on the other, it'll be the same, as Photoshop renders a pixel at a pixel.
  • Noel Carboni
    Dec 23, 2006
    Jan 26, 2013 11:27 AM   in reply to Marc Eisenoff
    Out of curiosity, do you have a RAM shortage (e.g., resulting in slow system performance)?  If not, worrying about how Photoshop allocates RAM to maintain its data structures, while academically interesting (well, I find it such), probably doesn't tell us all that much that's truly useful.
    If you ever want to understand more about how Photoshop works under the covers, and you're a dyed-in-the-wool geek like me, a look at the Photoshop SDK can tell you volumes.  Writing plug-in software isn't for the faint-of-heart, but it will tell you tons about how things work.  Funny thing...  I didn't used to think in rectangles...
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jan 26, 2013 11:50 AM   in reply to Marc Eisenoff
    Yes, the [  ] Delete Cropped Pixels setting of the crop tool can result in interesting effects.  In addition to the storage space, many (most? all?) filters actually work on the data beyond the visible edge of the canvas.
    I've found that I've ended up turning off that feature and just being very sure about what I'm doing when I crop.
    -Noel
    Jan 26, 2013 12:01 PM   in reply to Noel Carboni
    I NEVER crop the extended pixels out of a doc I'm working on. Too many times has the client came back and changed a size and say, maybe go horizontal instead of vertical, where if I'd cropped them out, I'd be back to square one. Having it, I can just chnge canvas size and go from there. IF a client requires a layered file (which I rarely will ever send) I'll save a "cropped" version for them to knock down the file size.
  • JJMack
    Jan 9, 2006
    Jan 26, 2013 12:05 PM   in reply to Noel Carboni
    Yes Photoshop workings are very complex indeed
  • Noel Carboni
    Dec 23, 2006
    Jan 26, 2013 12:07 PM   in reply to CRCJJ
    Our differences in needs with Photoshop of course lead to different choices.
    But beyond that I find it always possible to go back to the original image if one needs more - assuming you keep your raw files.  An added bonus is that it just may be possible to get a better image if one goes all the way back to the source data.  This could be true, for example, if one were to have prepared the image using the raw converter in Photoshop CS5 initially.  The converter just keeps getting better and better.  I was just noting this morning how much better a particular night shot I had done back in 2011 came out with the newest version of the converter with the PV2012 development process.
    -Noel
  • JJMack
    Jan 9, 2006
    Jan 26, 2013 12:17 PM   in reply to Noel Carboni
    Yes the main reason these days to upgrade to the latest version of Photoshop is the get the ACR updates.  Still CS6 was a ruff and trying upgrade and I think the Adobe Cloud is gray and I don't mean it has a silver lining.  I'm happy here on the ground.
