heses
image cropping changes
Jan 26, 2013 6:51 PM
Tags: #11
Just installed Elements 11 on a new Asus ET2300 all-in-one with Windows 8.  Resolution is set at a recommended 1920x1080.  I opened a jpeg in Elements and cropped the image to a square, but when I hit Print, what I see on the print set-up screen (and what actually prints) is an image with a good part of the top and bottom missing (although there is also a small image in the upper left corner that looks intact).  I tried setting the computer resolution to 1600x900 and the image was severely cropped on the sides.
How do I correct this problem?  If I choose one of the other resolution options, I guess that I might get a square or something close to it, but I assume that will effect my results in viewing venues.
    Jan 26, 2013 7:05 PM   in reply to heses
    I suggest read this printed tutorial to get the idea how to crop an image professionally:
    <http://helpx.adobe.com/photoshop-elements/getting-started/crop-photos. html>
    Good luck.
    Jan 27, 2013 7:52 AM   in reply to heses
    Try cropping by using the marquee tool. Hold shift as you drag to constrain it to a square, then go to Image>Crop. Does that produce a different result when you print?
    Jan 27, 2013 8:44 AM   in reply to heses
    Are you trying to print a square photo?
    Jan 27, 2013 7:38 PM   in reply to heses
    Unfortunately, I found nothing at that link-site that solves my problem, which is that the print that comes out is very different from the cropped area that I have selected.
    Are you saving the picture before printing?  It looks like you are not saving the picture.  The way I do is as follows:
    1) Load the picture in the editor;
    2) Duplicate the image;
    3) Crop the duplicated image;
    4) Save the cropped image;
    5) Load this image again to be certain it is saved;
    5) Print the (re)loaded image;
    Using this workflow you are certain that you are printing the correct image.
