whytebate
Help with XML Keyword file
Jan 26, 2013 7:43 PM
I've just had to reinstall CS6 on my iMac (Hard drive was replaced due to a fault). All my keywords are saved on the back up copy made of all of my files - filename is Adobe Bridge Keywords.xml - is was in a folder User/Library/Application support/Abobe/Bridge CS6.
I'd have thought I would have 2 options here:
1. import keywords (but I can't seem to import an XMLfile using the import function)
2. replace the newly created Adobe Bridge Keywords.xml file with the old one...
Problem is - there doens't appear to be a new XML file & the file structure User/Library/Application support/Abobe/Bridge CS6 doesn't appear to exist.
Anyone know where i might start with this puzzle?
Sarah
    Jan 27, 2013 3:30 AM   in reply to whytebate
    Hello,
    I think there is no new xml file because bridge create one if he need one.
    If you give new keyword to a picture, i think bridge will create this file. You can try this.
    But i think the only thing you'll have to do is just copy your saved files in the same directory even if there is no correspondant files, just copy it and i believe that you're keywords will come back to your new install of adobe bridge.
    I have allready done that whith my windows computer, and it was ok
    sorry i don't speak english very well.
  • Omke Oudeman
    Nov 27, 2004
    Jan 27, 2013 5:07 AM   in reply to whytebate
    This option only works on a text file, usually the keyword list that was first exported using the same menu as import (little menu icon top right of the keyword panel)
    I agree with guewen on this one.
