jQuery Flicker Feed Plugin Help
Jan 27, 2013 2:44 AM
Tags: #html #css #flickr_publishing #jquizme_plugin
Hi
Im trying to use this plugin from http://www.gethifi.com/blog/a-jquery-flickr-feed-plugin on my website at http://danielwaddon.com/ but cant seam to get it working.
Its in the bottom of the website. any information as to what im doing wrong and what I need to do?
Daniel
    Jan 27, 2013 1:16 PM   in reply to Daniel-Waddon
    You might want to fix your code errors before you add any more stuff to your page.
    http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fdanielwaddon. com%2F
    Nancy O.
    Jan 27, 2013 1:30 PM   in reply to Daniel-Waddon
    Vendor specific CSS properties are not the problem and you can safely skip those warnings.
    However you have other more serious errors such as closing tags that don't match your document type, re-using IDs, <script> tags without type, etc...  Until you sort out all the code errors, it's very hard to trouble shoot new problems.
    Nancy O.
    Jan 27, 2013 1:41 PM   in reply to Daniel-Waddon
    Simply ignore warnings about vender-specific pre-fixes (-moz, -webkit, -ms, -o).
    Concentrate on your other 37 code errors.
    Nancy O.
    Jan 27, 2013 2:07 PM   in reply to Daniel-Waddon
    You're getting there...
    On line 99, replace this:
    <div class="contentinformation" id="Webdesign">^
    with this:
    <div class="contentinformation">
    On line 106, replace this:
    <div class="contentinformation" id="Ecommercedesign">^
    with this:
    On line 120, replace this:
    <div class="contentinformation" id="logodesign">^
    with this:
    Also, go to Commands > Spell check in DW.
    Nancy O.
    Jan 27, 2013 2:35 PM   in reply to Daniel-Waddon
    First, I see conflicting jQuery libraries in your<head> tags.
    Your Flicker Feed plugin requires 1.4.2.  I don't know if it will work with other versions of jQuery.  So try changing your jQuery library to this one.
    <script src="http://ajax.googleapis.com/ajax/libs/jquery/1.4.2/jquery.min.js"></script>
    Secondly,  your FlickerFeed code needs to be wrapped inside <ul> and <script> tags like this:
    <p>Flicker Feed</p>
    <ul>
    $(document).ready(function(){
    $('#basicuse').jflickrfeed({
        limit: 14,
        qstrings: {
        itemTemplate:
        '<li>' +
            '<a href="{{image_b}}"><img src="{{image_s}}" alt="{{title}}"></a>' +
        '</li>'
      </script>
    </ul>
    Hope it works for you!
    Nancy O.
    Jan 27, 2013 3:07 PM   in reply to Daniel-Waddon
    Jan 27, 2013 3:21 PM   in reply to Daniel-Waddon
    <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.4.2/jquery.min.js"></script>
    Nancy O.
    Jan 27, 2013 3:28 PM   in reply to Daniel-Waddon
    Yes.
    N
    Jan 30, 2013 11:27 AM   in reply to Daniel-Waddon
    Use CSS to style the .odd and .even flickrRow classes.
    .odd {
    list-style: none;
    clear: left;
    float: left;
    width: auto;
    .even {
    list-style: none;
    float: left;
    margin-left: 25px;
    width: auto;
    Sample HTML:
    <div id="test" class="flickrFeed">
    <ul>
    <li class="flickrRow odd"><img src="image1.jpg"/></li>
    <li class="flickrRow even"><img src="image2.jpg"/></li>
    <li class="flickrRow odd"><img src="image3.jpg"/></li>
    <li class="flickrRow even"><img src="image4.jpg"/></li>
    </ul>
    </div>
    Nancy O.
