Lt12345
Missing guided edit and quick fix tabs in Elements 10
Jan 27, 2013 9:38 AM
using iPhoto and elements 10 I cannot find the guided edit or quick fix tabs to use on imported image from iphoto. The picture is visible. Other tools are visible and work. Where are the missing edit tabs located?
    Jan 27, 2013 1:09 PM   in reply to Lt12345
    I am having the same or a similar issue, my Guided and and Quick window tabs are black and I don't have the option under the 'window' tab to 'show' anything.
    Jan 28, 2013 9:07 AM   in reply to Lt12345
    Can you post a screenshot?
    In the meanwhile try the following steps:
    1. Close Elements.  2. Launch the Photoshop Elements Welcome Screen and hold down ctrl + alt + shift as you click Editor.
    2. Continue to hold the keys until you see a message box asking if you want to delete Photoshop Elements settings file. Click Yes. Elements will open with default preferences.
    Regards,
    vaishali
    Jan 28, 2013 11:31 AM   in reply to ~V
    That did not work, I did click "yes" on the message box to delete the settings file. I still have a black box where the options used to be for "quick" and "guided" tabs.
    Jan 28, 2013 8:46 PM   in reply to JohnWPhoto
    I suggest you to uninstall(from control panel) and do a fresh installation again.
    ~V
