VideoJos
Cannot write a Blue Ray encore CS error mesage
Jan 27, 2013 10:35 AM
Tags: #error_processing
I do not succed in writing a Blu Ray with encore CS 6.
The project check reports that the project is ok, no broken links etc.
I have used several default trancode en Blu ray settings.Each time with the same result:
After I click "build" in order to burne the BD, the proces runs okay until it start to burn to the BD.
Than the following error message comes "Blue Ray errror "Device error"code 3 Note "A5_storage_error = 97071"
After that you can only click "ok" and then the proces stops, without finishing a Blue Ray Disk.
OS = Windows 7, 64 bit.
Does somebody knows how to fix this?
    Jan 27, 2013 11:08 AM   in reply to VideoJos
    Go back to the main page http://forums.adobe.com/community/encore
    Look up... click on the article
    Jan 27, 2013 4:51 PM   in reply to VideoJos
    Are you able to Burn to Folder from that same Encore Project?
    If not, what error does that process yield?
    Jan 28, 2013 1:27 PM   in reply to VideoJos
    My reply #1 mentions a link to an article, located at http://forums.adobe.com/thread/988529
    Did you ever find and read that article?
    Jan 29, 2013 8:42 AM   in reply to VideoJos
    Your problem with direct burning from Encore MAY be described below... in which case, there is nothing Adobe may do to fix the problem, since the problem is not Encore
    Things and Software to AVOID when authoring/burning a DVD or BluRay
    Start --> http://forums.adobe.com/thread/608660
    #2 has WHY Explained http://forums.adobe.com/thread/607390
    Plus http://forums.adobe.com/thread/562941
    Create an ISO (Encore) or folder on your hard drive (Encore or Premiere Elements) and then use the FREE http://www.imgburn.com/index.php?act=download to write files or folders or ISO to disc for DVD or BluRay (send the author a PayPal donation if you like his program)
    Imgburn will read the ACTUAL disc brand from the disc, which is not always the same as the box label (Memorex is notorious for buying "anything" and putting it inside a Memorex box)
    When you write to disc with Imgburn, use the SLOWEST possible speed setting, so your burner has the best chance to create "good, well formed" laser burn holes... since no DVD player is required to read a burned disc, having a "good" one from a high quality blank will help
    And, some other problems to keep in mind so you don't get caught
    Odd Errors http://forums.adobe.com/thread/670174
    Long File Names or odd characters cause problems
    Read http://forums.adobe.com/thread/588273
    And #4 http://forums.adobe.com/thread/666558
    And This Message Thread http://forums.adobe.com/thread/665641
    I do not burn to BluRay, and I could burn direct to DVD with Encore, but I ALWAYS use Imgburn since I have more control over the burning parameters
