Any help would be appreciated!
Is this question about Premier Elements 11 (you say PE11) ? If so then try this:
If you have Adobe Premiere Elements installed, you can burn media files to a DVD/Blu Ray Disc.
If this doesn't work then try this link:
<http://forums.adobe.com/community/premiere_elements?view=discussions>
Good luck.
If you have version sets created for the edited files, you can go to Find>By Details(metadata). From the dropdown, scroll to "Version set" and from the secnd dropdown that appears, select "in a version set". Click on Search. Now your grid will show only the edited files in version set. Select the files and go ahead.
Hope that helps!
Hope that helps!
No, the grid will not show ONLY the edited files in version sets. It will also show other files in the version sets.
That may be enough for sonicbuffalo's purpose, though...
For instance, you might select all and export to a new folder and reimport them in a temporary catalog where you could delete the files not including 'edited' in the file names.
Burning a selection for a slideshow generally requires the export step to resize the pictures, so it may not be a bid deal to do so.
North America
Asia Pacific
