How do I delete a keyword from a file... permanently?
Jan 27, 2013 8:54 PM
Tags: #keywords #delete #deleting_keywords
How do I delete a keyword from a file... permanently? That is, the tags are updated in the file when I write as well. Effectively, when the keywords have been removed, and the file is re-imported, only those keywords I want remain.
    Jan 27, 2013 8:59 PM   in reply to Ed VanWieren
    Try this:
    1) Right-Click on the photo that contains the key word;
    2) Select Remove Keyword Tag;
    3) Click on the keyword that you want to remove;
    Good luck and post back if this is not what you want.
    Jan 27, 2013 9:19 PM   in reply to Ed VanWieren
    If you want to remove the Tags completely then just use the Minus sign in the Tag Panel.  See this picture (RED SQUARE BOX):
    Hope this helps.
    Jan 27, 2013 9:47 PM   in reply to Ed VanWieren
    Select the file, from the right panel, click "Information" tab.
    Now expand Metadata header. There you will see "Edi IPTC". Click it. This will launch IPTC metadata dialog. YOu can select and delete the tags. Click Save,
    The metadata will be removed from the file as well.
    Andaleeb
    Jan 27, 2013 10:05 PM   in reply to Ed VanWieren
    Yeah I understand.. but unfortunately that's the only way, going one by one per file, as of now.
    Andaleeb
    Jan 27, 2013 11:25 PM   in reply to Ed VanWieren
    Ed VanWieren wrote:
    I am sad to hear that. For an image organization tool, one would expect tools for manipulating many images at once!
    Are you aware of any tools that accomplish what I ask for?
    Thanks again.
    Yes, there are specialized  tools to manipulate exif data. Have a look at exiftool and its GUI (interface module) = exiftoogui.
    http://u88.n24.queensu.ca/exiftool/forum/index.php?topic=2750.0
    You did not state which PSE version you have.
    If you have PSE6, 7 or 8, you could try psedbtool from John R Ellis. This utility can 'write metadta to files' without keeping the old keywords.
    http://www.johnrellis.com/psedbtool/index.htm
    Jan 28, 2013 4:38 AM   in reply to MichelBParis
    I believe it is exiftoolgui for the name. Once upon a time, maybe in W7 I stumbled across a way to update the exif data via explorer(my computer). Exiftool is free and works well.
    I need to do this if I ever want to switch to LR, I have lots of tags written into my files that are old(I have had PSE for over a decade) and when I went to play with LR discovered all these ancient tags. I wish Adobe would do something about this. In my mind, only the tags from the current catalog shold be in the Exif data, not all the old tags.
    Jan 28, 2013 4:51 AM   in reply to swharton07
    You are right.
    This has already been discussed on this forum. Some users would like the 'write metadata to files' to automatically get rid of tags no longer in the catalog. There are pros and cons. For instance there are cases when you do not want useful temporary tags to be written in the files themselves. I think we could agree to have an option when you choose to write metadata.
  • 99jon
    Jan 6, 2010
    Jan 28, 2013 7:15 AM   in reply to Ed VanWieren
    Hi Ed
    You can do what you want in the PSE11 Organizer metadata panel. Simply select a thumbnail and click on the three little dots next to IPTC. You can add or clear metadata and resave. If you select multiple thumbnails you should see a button to Add IPTC data and you get the options to overwrite existing metadata or append new metadata.
