How do I uninstall and re-install CS5 Adobe Media Encoder?
Jan 28, 2013 7:41 AM
When I export media from Adobe Premiere CS5, whether I export directly from Premiere or use the Adobe Media Encoder, the system freezes for several minutes before starting the encoding.  When I check the uninstall menu, there is no listing for uninstalling Adobe Media Encoder. I understand that the Adobe Media Encoder is related to both Premiere and After Affects, which I also have installed. If I uninstall and reinstall Premiere 5.0.3, will that also reinstall the Adobe Media Encoder?  If not, what action could I take to get the encoding function of CS5 working properly? Do I need to uninstall the entire CS5 suite and run the Adobe Created Suite Cleaner Tool, then reinstall?
I'm using Windows 7 ultimate 64 bit with an Intel i7 processor and 24 GB of RAM.
    Jan 28, 2013 9:12 AM   in reply to Dan 101
    The whole system becomes unresponsive, keyboard and mouse don't work at all, or it just takes a bit for AME to actually start encoding?
    Jan 28, 2013 7:42 PM   in reply to Dan 101
    Yeah, that's definitely not normal.  Unfortunately, I don't really have any ideas about what might be causing the hold up.  Unless someone chimes with with something, a reinstall might be called for.
    Yes, deactivate first.  And do run the Cleaner Tool.
