Text on a path
Jan 28, 2013 8:54 AM
I attempted to place text on a path.  I drew an oval, selected text on a path tool.  The text start is at the very top and wraps around the path clockwise.  I try to select the path 'handle' but I cannot.
    Jan 28, 2013 11:09 AM   in reply to RoyWhite0348
    Roy,
    If you switch to the Selection Tool, you should be able to drag the Type by the I-beam, round the ellipse, or across to flip to the inside.
    Is that what you are after?
    Jan 28, 2013 1:33 PM   in reply to RoyWhite0348
    Which version of Illustrator are you using? And which beam exactly are you trying to select?
    Older versions of AI have got less beams than newer ones. Right, Jacob ?
    Jan 28, 2013 2:57 PM   in reply to Kurt Gold
    I believe you know better than I, Kurt.
    And I believe the
    path 'handle'
    may be something else. After all, the path does show handles when Direct Selected.
    Still, guessing is more fun than being told, no?
