I am using a CheckBox as an itemRenderer in a DataGrid but am not certain how I can count the number of items selected. Below is my sample code.
<?xml version="1.0"?>
<!-- dpcontrols/DataGridPassData.mxml -->
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
initialize="initData()">
<mx:Script>
<![CDATA[
import mx.collections.*;
import mx.events.ListEvent;
[Bindable]
public var dpTests:ArrayCollection;
[Bindable]
private var vCountSelected:int=0;
private var DGArray:Array = [
{Category:'Transfer', Status:'Active', Price:10.55},
{Category:'Transfer', Status:'Inactive', Price:0},
{Category:'Transfer', Status:'Archived', Price:0},
{Category:'Initial', Status:'New', Price:25.75},
{Category:'Initial', Status:'Old', Price:15.25}];
//Initialize dpTests ArrayCollection variable from the Array.
public function initData():void {
dpTests=new ArrayCollection(DGArray);
protected function dgTests_changeHandler(event:ListEvent):void
var count:int=0;
// loop through the datagrid
for (var s:int=0; s < dgTests.dataProvider.length; s++)
// Select a row during each loop
this.dgTests.selectedIndex=s;
//var c:int=dgTests.selectedItem.dfSelected;
var b:Boolean=dgTests.selectedItem.dfSelected;
if (b=true)
// increment the variable
count++;
// assign the local variable to the private variable
vCountSelected=count;
private function itemClickEvent(event:ListEvent):void {
clickColumn.text=String(event.columnIndex);
clickRow.text=String(event.rowIndex);
eventType.text=event.type;
</mx:Script>
<mx:DataGrid id="dgTests" width="350" height="200" change="dgTests_changeHandler(event)"
dataProvider="{dpTests}" itemClick="itemClickEvent(event)">
<mx:columns>
<mx:DataGridColumn dataField="Category" />
<mx:DataGridColumn dataField="Status" />
<mx:DataGridColumn dataField="Price" />
<mx:DataGridColumn id="dgcCategorySelected"
dataField="dfSelected"
itemRenderer="mx.controls.CheckBox"
rendererIsEditor="true"
editorDataField="selected"
width="20"
headerText=""
textAlign="center"/>
</mx:columns>
</mx:DataGrid>
<mx:Form id="fSumm">
<mx:FormItem label="Column Index:">
<mx:Label id="clickColumn"/>
</mx:FormItem>
<mx:FormItem label="Row Index:">
<mx:Label id="clickRow"/>
</mx:FormItem>
<mx:FormItem label="Type:">
<mx:Label id="eventType"/>
</mx:FormItem>
<mx:FormItem label="Count Selected:">
<mx:Label id="lCountSelected" text="{this.vCountSelected}"/>
</mx:FormItem>
</mx:Form>
</mx:Application>
My assumption (which is obviously wrong) is that the value for count should increment and decrement as items are checked and unchecked. Instead, when I check the first checkbox I get the total of items in the dataprovider.
How can I just get the count of the items selected with the checkbox?
Thanks!
Lee
<mx:Script>
<![CDATA[
[Bindable]
[Bindable]
var count:int=0;
if (b == true)
count++;
//vCountSelected++;
</mx:Script>
<mx:columns>
width="20"
headerText=""
</mx:columns>
</mx:DataGrid>
</mx:FormItem>
</mx:FormItem>
</mx:FormItem>
</mx:FormItem>
</mx:Form>
</mx:Application>
Try initializing that field to false in each array item.
If that doesn’t work, try an actual class definition instead of plain objects. The DG is trying to guess the datatype of the dfSelected field in order to know how to save the value. If it guesses wrong, the way booleans get handled could cause them to appear as if they are true.
North America
Asia Pacific
