afrank89
Adopted a Website! DW says head is locked. Detach from template not available!
Jan 28, 2013 10:59 PM
Tags: #error #dreamweaver #templates #widgets
I recently started remodeleing a website for a local business and I am trying to update some images and use slideshows. When I try to insert widget I get the "Required links could not be added to this file because the <head> tag is in a locked region." error.  I have recently started using DW again after quite some time. Am I missing something here. I could not find a template file on the server and when I go to detatch from template the option is not available like it is not using a template. Please help. I am trying to add widget to this page:
http://www.bigbearhideaway.com/blackbear.php
It seems the pages get all of their attributes from here:
http://www.bigbearhideaway.com/header.html
ANY help is much appreciated!
    Jan 28, 2013 11:13 PM   in reply to afrank89
    In your document remove all reference to templates and save the document.
    Instead of using DWT, use PHP's include file instead.
    Jan 29, 2013 6:32 AM   in reply to afrank89
    I'm in complete agreement with Gramps, and while you are rearranging things, be sure to repair all your links to your local computer (they start with file://C/
    <link href="file:///C|/Users/afrankng/AppData/Roaming/Adobe/Dreamweaver CS6/en_US/Configuration/Temp/Assets/eam53A0.tmp/css/lightbox.css" rel="stylesheet" type="text/css" />
    <link href="file:///C|/Users/afrankng/AppData/Roaming/Adobe/Dreamweaver CS6/en_US/Configuration/Temp/Assets/eam53A0.tmp/css/sample_lightbox_l ayout.css" rel="stylesheet" type="text/css" />
    <script src="file:///C|/Users/afrankng/AppData/Roaming/Adobe/Dreamweaver CS6/en_US/Configuration/Temp/Assets/eam53A0.tmp/scripts/jquery.js" type="text/javascript"></script>
    <script src="file:///C|/Users/afrankng/AppData/Roaming/Adobe/Dreamweaver CS6/en_US/Configuration/Temp/Assets/eam53A0.tmp/scripts/lightbox.js" type="text/javascript"></script>
    And visitors hate horizontal scrollbars that push one third of your content off the right side of the screen/viewport
    Jan 29, 2013 8:32 AM   in reply to afrank89
    Open Template.dwt file in Code View.
    Scroll down to just above the </head> tag.
    Go to Insert > Template > Editable Region.
    Name it "head'
    Code should resemble this:
         <head>
              <!-- TemplateBeginEditable name="head" -->
              <!-- TemplateEndEditable -->
         </head>
    Save Template.
    Nancy O.
    Jan 29, 2013 9:04 AM   in reply to afrank89
    I apologize -
    We have all been asssuming that your site was built on a DW template.- it is NOT
    As you indicated a while back, the site is already using a server side include.
    All I can see wrong now, is that the header.html include file does have.a scrap of template code at lines 315-316. Remove them both and you should be fine.
    </head>
    I see.  It looks like a disected Template because your header include contains this:
    </head>
    So at some point, this site was built with Templates.
    Nancy O.
    Jan 29, 2013 9:10 AM   in reply to afrank89
    What's the link to the site?
    Nancy O.
    Jan 29, 2013 9:15 AM   in reply to afrank89
    Nevermind.  I see the link in your original post.
    Best suggestion I can come up with is to view source in browser, copy & paste entire code into a new, blank HTML document.  Repeat with other site pages.
    You should have no trouble editing that.
    Nancy O.
