AllynTech
Flex 3 Adding LineSeries via ActionScript
Jan 29, 2013 4:01 PM
Tags: #as3 #flex #3 #actionscript #charting_problem #lineseries
I have seen a few posts on this, and I have had my current code working, but when it doesn't work I find myself at a loss to be able to debug why.
My SensorReading object:
public class SensorReading
     public var SensorName:String;
      public var ChannelName:String;
     public var UOM:String;
     public var ReadingDate:Date;
     public var ReadingValue:String;
I can dynamically get up to 32 different channels of information. Each channel of data is an array of SensorReadings, and I receive an ArrayCollection of all the readings arrays (e.g. dataCollection.getItemAt(5) would receive the data array for channel #6's data).
All I get is blank charts (code below). I have set breakpoints on many locations, including creating debug functions for series.dataFunction and chart.click(), and the series all seem to be correct, and the dataProviders for each line appears to be correct.
Any thoughts on the issue would be greatly appreciated!
//view.chart is the LineChart target
// clear out any existing chart axis
var seriesArray:Array = new Array();
view.chart.series = seriesArray;
view.chart.verticalAxis = new LinearAxis();
// prepare for multiple axes if needed
var axisIndex:Array = new Array();
var axis:LinearAxis;
var axisRenderer:AxisRenderer;
var axisRenderers:Array = new Array();
// channel data collection
for ( var j:int = 0; j < channelDataColl.length; j++ )
          // get the first row of data to set up
          // the series information from
          reading = ( channelDataColl.getItemAt(j) as Array )[0] as SensorReading;
          // instance a new lineseries for this dataset
          var series:LineSeries = new LineSeries();
          var channelProvider:Array = channelDataColl.getItemAt(j) as Array;
          series.dataProvider = channelProvider;
          series.yField = "ReadingNumber";
          series.xField = "ReadingDate";
          series.displayName = reading.SensorName + "\n" +
                    reading.ChannelName + "\n" +
                    reading.UOM
          // if we have a new unit of measure, then
          // add a new vertical axis unless this is
          // the first one
          if ( axisIndex.indexOf( reading.UOM ) < 0 )
                    axis = new LinearAxis();
                    axis.displayName = reading.UOM;
                    axis.title = reading.UOM;
                    axis.autoAdjust = true;
                    // check if this is the first axis
                    if ( axisIndex.length == 0 )
                              // work around a flex issue by using
                              // the default axis for the first axis
                              view.chart.verticalAxis = axis;
                    else
                              series.verticalAxis = axis;
                              axisRenderer = new AxisRenderer();
                              axisRenderer.axis = axis;
                              axisRenderers.push( axisRenderer );
                              view.chart.verticalAxisRenderers = axisRenderers;
                    // add uom to our existing list
                    axisIndex.push( reading.UOM );
          // add this series to the chart
          var seriesArray:Array = view.chart.series;
          seriesArray.push( series );
view.chart.invalidateDisplayList();
// end of code
// MXML
<mx:LineChart
          id="chart" width="100%" height="100%"
          showDataTips="true"
          seriesFilters="[]"
          click="onChartDebugClick( event )"
          dataTipFunction="formatDataTips">
          <mx:horizontalAxis>
                    <mx:DateTimeAxis
                              id="hAxis"
                              dataUnits="minutes"
                              title="Date"
                              alignLabelsToUnits="true"
                              displayLocalTime="true"
                              parseFunction="debugParseFunction"/>
          </mx:horizontalAxis>
          <mx:horizontalAxisRenderers>
                    <mx:AxisRenderer axis="{hAxis}"
                                                             showLine="true"
                                                             tickPlacement="outside"
          </mx:horizontalAxisRenderers>
</mx:LineChart>
