cdsvvxv
-load-externs seems to ignore custom classes
Jan 29, 2013 11:32 PM
Tags: #module #mxmlc #load-externs #link-report
I have an application structure as follows:
project-root
        | ----- src
        |          | ----- modules
        |          |               |----- mymodule1
        |          |               |               | ----- MyModule1.mxml
        |          |               |----- mymodule2
        |          |               |----- mxmlc-config.xml
        |          | ----- rest of packages
        |          | ----- Main.mxml
exclude.xml (generated by -link-report)
When I build the Main.mxml I use:
-link-report exclude.xml src\Main.mxml
to generate a exclude.xml in the root of the project directory. I then compile my modules using:
@mxmlc -load-config+=src\module\mxmlc-config.xml -o=MyModule1.swf
The exclude.xml contains all of the Flex classes and also the classes from Main.mxml. However if in a module I use:
private var _myMainProjectClass:MyMainProjectClass;
I get the following warning:
Warning: Main is a module or application that is directly referenced. This will cause Main and all of its dependencies to be linked in with module.mymodule1:MyModule1. Using an interface is the recommended practice to avoid this.
Why is MyMainProjectClass not excluded in the build of MyModule1.swf?
