Footnotes
Jan 30, 2013 2:08 AM
    Jan 30, 2013 2:08 AM   in reply to Community Help
    is there a way to create footnotes outside of the textbox? and if not, would it be possible in the future versions?
    thanks!
  • jmlevy
    Oct 30, 2004
    Jan 30, 2013 2:57 AM   in reply to tanyildiz
    You need a script to achieve this. See here.
    Jan 30, 2013 3:38 AM   in reply to jmlevy
    i'll try, thank you for your quick answer :-)
    Jan 30, 2013 4:18 AM   in reply to tanyildiz
    tanyildiz wrote:
    thanks!
    Keep dreaming - I've been campaigning for better footnotes since InDesign CS3! And I'm sure others have been way before that.
    http://forums.adobe.com/message/2744922#2744922
    Join the cause!
    Jan 30, 2013 4:31 AM   in reply to tanyildiz
    tanyildiz wrote:
    thanks!
    Add your voice with a formal feature request here: Wishform
    Regards,
    Peter
    _______________________
    Peter Gold
    KnowHow ProServices
    Jan 30, 2013 4:57 AM   in reply to Eugene Tyson
    Eugene Tyson wrote:
    tanyildiz wrote:
    thanks!
    Footnotes were first implemented in CS2. Its features, drawbacks, and bugs are exactly the same in the current version of InDesign, CS6.
    I'm starting to think the wishform just is a redirect > thrash. (It's either that, or the Flash/HTML5/iApp fanbase use automated bots to fill it up with whatever the current Fad of The Year is.)
    Jan 30, 2013 8:24 AM   in reply to [Jongware]
    I'm convinced the wishform resides on a server sitting in a blackhole at the center of the Milky Way.
    Jan 30, 2013 12:41 PM   in reply to Eugene Tyson
    Well, I once wished for an Illustrator-style layers panel, and that came true. Maybe you forgot to throw in a quarter.
    Mar 4, 2013 3:35 AM   in reply to Community Help
    Please can anyone suggest a way to edit the (superscript) numbering of footnote in ID 5.5?  I need to repeat numbers ie footnote 3 is used several times in the text...
    Any suggestions please?
    Mar 5, 2013 4:03 AM   in reply to JonJaxon
    hi,
    i think, this is not possible. instead of it, you can write the other numbers (and applying style of footnote references) where you need them, out of original footnote numbering.
    Mar 5, 2013 4:12 AM   in reply to tanyildiz
    A good suggestion, thank you - I'll try it!
    Jon
