clansman156
Opening Cr2 photos
Jan 30, 2013 3:32 AM
my Elements 11 will not open files with IMG---CR2 file names where Elements 10 opens them OK. What is the problem
  • 99jon
    Jan 6, 2010
    Jan 30, 2013 3:49 AM   in reply to clansman156
    Make sure you have the camera raw plug-in. Launch the PSE11 editor and click:
    Help >> About Plug-in >> Camera Raw
    You should see something like this image. Press Esc to close.
  • 99jon
    Jan 6, 2010
    Jan 30, 2013 7:55 AM   in reply to clansman156
    Can you check to see if the File Formats folder exists within the PSE11 folder? If it does; is there anything in it?
    C:\Program Files (x86)\Common Files\Adobe\Plug-Ins\Elements 11\File Formats
    Jan 31, 2013 2:54 AM   in reply to clansman156
    In my case I'm seeing Camera Raw.8BI File in that folder.
    Can you check your Editor for the following-
    Andaleeb
    Jan 31, 2013 2:58 AM   in reply to clansman156
    Clansman,
    Can you please check your path and confirm that you included the common files bit
    Brian
  • 99jon
    Jan 6, 2010
    Jan 31, 2013 3:21 AM   in reply to clansman156
    1. Use the link below to download the plug-in.
    2. Open the zip folder and on the menu click Extract all files; then click the Extract button.
    3. Drag the file Camera Raw.8bi into the empty File Formats folder.
    Make sure you use the correct file path.
    Please let us know if it works.
    N.B. the download folder will only remain public for a limited period today. This is to prevent illegal uploads.
    https://rapidshare.com/#!download|628p2|755075302|Camera%20Raw%207.3%2 0WINDOWS.zip|11872|0|0
  • 99jon
    Jan 6, 2010
    Jan 31, 2013 4:07 AM   in reply to clansman156
    Message #3
  • 99jon
    Jan 6, 2010
    Jan 31, 2013 4:10 AM   in reply to clansman156
    Are you opening from the PSE11 Editor (expert mode)
    File >> Open
  • 99jon
    Jan 6, 2010
    Jan 31, 2013 4:22 AM   in reply to clansman156
    You will have seaparate File Formats folders in Elements 10 and Elements 11
  • 99jon
    Jan 6, 2010
    Jan 31, 2013 5:24 AM   in reply to clansman156
    This is how they appear on my 32 bit system in Program Files:
    PSE10
    PSE11
  • 99jon
    Jan 6, 2010
    Feb 1, 2013 5:38 AM   in reply to clansman156
    Thanks Gordon. Glad you finally got it working.
