Hyperlinks from Converted Word Doc put figure caption at very top of screen
Jan 30, 2013 9:50 AM
I converted a large MS-Word file to RH9.  When I generate WebHelp and select the hyperlink to a figure name, the figure caption (appearing at the bottom of the figure) appears at the VERY top of the screen. The user must scroll up to see the figure. Is there any workaround for this or any setting in Word or Robohelp I am not aware of.
I am using the default Target Frame option (Page Default) in Word and have tried some of the other options there without success. Thank you for any help you can provide.
nankinnankin
    Feb 11, 2013 4:54 PM   in reply to nankinnankin
    Hi
    Let me explain this with an example :-
    Whenever you create a word document with 2 images overlapping each other and import that Word Document in Robohelp, Robohelp cannot understand the same because Robohelp works with HTML. In Design view you might get a chance to view the images overlapping correctly however in the HTML view you can find the images are not overlapeed with any html tags, they are rather separated. So there is no overlap that you can achieve in HTML.
    So this task is not possible in Robohelp, untill and unless you come up with some great HTML tags which will be helpful for me as well.
    Hope it helps
    Thanks and Regards
    VJ
