Sledhead24/7
Lighting adjustments on multiple photos
Jan 30, 2013 7:24 PM
I'm trying to adjust the lighting on over 800 pictures ina  timelapse video that was taken in low light and I'm trying to brighten up the pictures a little, since all the pictures need the same effects is there a way I can apply the same lighting adjustments to all the pictures? Im using premiere elements 11 on mac OSX 10.8.2
    Jan 30, 2013 8:00 PM   in reply to Sledhead24/7
    If they all need the same Effect, just apply it to the first Clip/Still Image, and adjust, as required. Then, Rt-click on that Clip/Still, choosing Copy. Now, Select all others, Rt-click on them, choosing Paste Attributes. Done.
    PS - if needed, though you did Paste the Attributes, you could still manually tweak each one, as needed.
    Jan 31, 2013 5:17 AM   in reply to Bill Hunt
    FYI, in version 11, Paste Attributes is called Paste Effects and Adjustments.
    Jan 31, 2013 5:49 AM   in reply to Steve Grisetti
    Steve,
    Thank you for that correction. Maybe one day I will get all of the syntax changes straight in my mind - and then they will be changed again.
    After about 8 years, PrPro made some changes in verbage too, to make FCP, and AVID switchers feel more comfortable. Just more to learn.
    Appreciated.
