zen15006
Logo placement
Jan 31, 2013 3:58 AM
Hi
have a project and in the bottom lh corner I want to place a logo to stay there all the time.
I created the logo in illustrator and exported it as a png with a transparent backgroud,
When I import into premiere the background is black??
When I add it to the time line in video 2 the concept works apart from the log is placed dead centre.
What step have I missed
thanks
Ian
  • Dan Plonsker
    Dec 23, 2010
    Jan 31, 2013 4:05 AM   in reply to zen15006
    Hello Ian,
    1. When in the project bin it usually shows with a black backgroung.
    2. You now need to move it to its place. Use the effects controls>motion for it.
    You may need to scale it too.
    Hope this helps.
    Dan
    Jan 31, 2013 10:06 AM   in reply to zen15006
    The black BG is the alpha channel.  ie transparent.
    Same as a Title you create in Premiere.  They automatically have alpha channels.
    Same for a psd on a transparent BG . This will also show on a black bg in Premiere.
    Dan has correctly informed you how to position it.  (Select your graphic clip. "Effects Control > Motion...)
    FY: All clips have these  "Fixed Effects" attached to them that you will find in the "Effects Control Window"
    Feb 1, 2013 4:42 AM   in reply to shooternz
    If you need transparency, edit in Photoshop using a transparent background and then save the image as a PSD file. Then import into Premiere for an automatic transparent background.
