I use Premiere Pro 5.5 at work and 6.0 at home. The following problem happens with both.
When I encode my project out to mpeg2 and play it back in windows media player, at random
parts of the video it will stutter/skip/jerk for a frame or two. I've tried every possible variable available in mpeg2
and it still does it. It also never does it in the same spot in the video when
I re-encode. When I import and watch the video in premiere pro, it plays fine. When I burn to bluray, it
plays fine. We use rushworks at our station to play commercials, and the files have to be mpeg2 and they are played
out using windows media player, so I can't just use a different file type like avi or quicktime or use a different player.
I've seen others with the same problem on message boards, but as yet, no solution. Does anyone know how to fix this problem?
Thank You,
Virgil
home system:
Motherboard - Asus P6x58D Premium
CPU - Intel Core i7 960 3.2GHz QUAD Core 8mb 130W (Socket 1366 45nm)
Ram - 24 DDR-1333
Video Card - PNY Quadro 4000 PCI-E 2GB
Windows 7 Professional 64-bit OEM
Primary Storage - Western Digital 1TB SATA 6Gb/s
Secondary Storage - Western Digital 2TB SATA 6Gb/s
>encode my project
How about project details?
What are you editing, and does your project match your video?
Please NOTE that the PPro CS6 screen may look a bit different (I use CS5)
For CS5 and later, the easy way to insure that your video and your project match
See 2nd post for picture of NEW ITEM process http://forums.adobe.com/thread/872666
-and a FAQ on sequence setting http://forums.adobe.com/message/3804341
When your project sequence is correct, you will not see a red line over your timeline at first import, before you do anything to the video
Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
What is a CODEC... a Primer http://forums.adobe.com/thread/546811
What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
Report back with the codec details of your file, use the programs below... a screen shot works well to SHOW people what you are doing
http://forums.adobe.com/thread/592070?tstart=30
For PC http://mediainfo.sourceforge.net/en or http://www.headbands.com/gspot/
The video is AVCHD Video (.MTS) and works very well with PPCS5/6. I also use P2 video files and they work fine too.
Here is the info on a mpeg2 file I encoded. Is this the information that you needed?
Virgil
General
Complete name : C:\Users\Admin\Desktop\Heart Ball Video Final.mpg
Format : MPEG-PS
File size : 802 MiB
Duration : 5mn 42s
Overall bit rate : 19.7 Mbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : No
Format settings, Matrix : Default
Format settings, GOP : M=1, N=6
Duration : 5mn 42s
Bit rate mode : Constant
Bit rate : 18.5 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.298
Stream size : 776 MiB (97%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 5mn 42s
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 10.4 MiB (1%)
North America
Asia Pacific
