thx1138b
External Hard Drive Suddenly Loaded With Corrupt Image Files (Mac User)
Jan 31, 2013 6:43 PM
Tags: #external_hard_drive #corrupt_psd #maxtor_drive #not_a_valid_photoshop_document
I'm using an iMac with CS6. I have an external Maxtor 1TB drive that is 13 months old. I have had no issues at all with it until today, when I attempted to access  a PSD file from the drive and received an error message telling me that the document was not a valid photoshop file. I looked at the directory at this point and noticed that the preview icons for many of the photoshop and jpg files on the drive were disabled. In each of these cases, the files will not open.
I have:
1. Repaired permissions and volumes on the external drive.
2. Changed the file extension and attempted to open.
3. Opened the file in a hex editor and looked for extra lines of code, or text, or whatever.
4. Copied the file to a different drive.
5. Attempted to open in a different program (Preview, Illustrator)
In no cases will the files open, and I'm stumped. The drive itself seems to be working fine. Not every file is affected, and the files that are affected are both in a variety of locations on the drive and were created over a period of years. Any ideas about how to resolve this issue will be sincerely appreciated.
    Jan 31, 2013 6:18 PM   in reply to thx1138b
    Sounds like your drive is failing. Bad sectors maybe. But you do have a backup?
    Looks like you did everything but what you should have done immediately. DISK REPAIR to RECOVER files.
    Just hope you have not screwed the files up permanently by doing all this other stuff.
    Use Dick Utility's Disk Repair, Drive Genius, or Disk Warrior.
    Jan 31, 2013 7:13 PM   in reply to thx1138b
    have you tried using a different cable, a different computer
    maybe pulling the drive out of its enclosure
    but if you can't drag/copy a file from the bad HD to your desktop and open it w/o problems something is probably toasted
    Jan 31, 2013 7:15 PM   in reply to thx1138b
    In no cases will the files open. The drive itself seems to be working fine.
    If you open the folder in Bridge and the thumbnails just show icons try purging the cache.  Go to Tools/cache/purge cache for xxxx folder.  Let thumbs rebuild and if you still have just icons for those problem files I would say the drive is not working fine.
    The problem may be intermittent, but I would have very little faith in it.  See if you can find other programs to test the drive for bad segements and read/write operations.
    If you put files on this drive also put the same file on another drive at the same time until you get this figured out.  Drive failure is not the uncommon.
    Feb 1, 2013 2:54 PM   in reply to thx1138b
    That's  valuable knowlege, thanks for posting your fix.
