How to dock the floating tools palette in InDesign CS6 for Mac? Normal way doesn't work
Feb 1, 2013 5:29 AM
Tags: #indesign #cs6 #tools #mac_os_lion #docking_toolbars #ui_interface
In all my CS applications except InDesign CS6 (Mac), I can dock the tools window by the side of the main content panes like any other window: drag it to the edge, and at just the right point, it highlights where it will be docked with a blue outline, and docks when you let go.
I can't find any way to do this in InDesign CS6 (Version 8.0, Mac), however. Unlike every other window, it never gives the option to dock, no matter where I drag it. The only options in the toolbar itself switch between one row vertical, two rows vertical, and one row horizontal. I've also looked in Preferences > Interface and the only options refer to the "Floating tools bar" and give the same one row vertical, two rows vertical, and one row horizontal options as the tool bar itself.
I can't see any option to stop it floating. I've tried on a variety of Window > Arrange settings, and with Window > Application Frame both ticked and unticked, and nothing works. I can make it snap to position in a corner, but it doesn't dock and doesn't stop floating.
It's not just the inconsistency and nuisance of it sitting on top of the documents and not moving with the rest of the window that causes a problem: I'm on a Mac (Lion) and the floating toolbar breaks a normal useful operating system function. In every application except InDesign, when I press F3, the current window shrinks down and I see every other open window, organised by application, with each application's icon floating on top. In InDesign CS6, it's the floating tool bar, not the main window, that shrinks. The main InDesign window stays where it is, awkwardly sat between the icons and my other windows, in the way of the other windows - effectively making it impossible to use F3 to switch to a different other window without switching out of InDesign first.
Here's a screenshot I found online (looks like Windows version of CS6?) where the tools bar is docked: no close icon, slots in neatly alongside the content panes, not treated as a seperate window by the OS.
http://photos.pcpro.co.uk/images/front_picture_library_PC_Pro/dir_354/it_photo_177415_52.jpg
I'm having trouble finding Mac screenshots where it's docked - in most, it's floating awkwardly above the left ruler.
    Feb 1, 2013 5:30 AM   in reply to alanomaly
    Turn on the application frame. For some reason, it's off by default.
    Bob
    Feb 1, 2013 5:45 AM   in reply to alanomaly
    Sorry about that. I'm not having any issues with that here but you might want to try turning it to two columns and then drag it.
    That might kick start it a bit. Perhaps a new workspace would help, also.
    If all esle fails, trash your prefs.
    Bob
    Feb 1, 2013 9:50 AM   in reply to alanomaly
    I had this identical problem. The latest update fixes it.
    Audrey
    Feb 12, 2013 8:02 AM   in reply to alanomaly
    try resetting the wokspace.
    Apr 9, 2013 3:12 PM   in reply to alanomaly
    Its a strange bug, but I have found a work around.
    If you dock another palette (is info, layers etc...) to the left, you can then dock the tool bar to the left of that pallete. You can then detach the pallete and the tool bar will stay docked.
    Feb 4, 2014 5:10 PM   in reply to alanomaly
    Bob's suggestion above worked for me - thank you.
    I went to the Window menu and, all the way at the bottom, I clicked Application Frame. Everything docks now.
