Been struggling to resolve this error since yesterday in Flash Builder 4.7 packaging an app for iOS.
Error occurred while packaging the application:
Exception in thread "Main Thread" java.lang.UnsatisfiedLinkError: Can't load library: C:\Program Files\Adobe\Adobe Flash Builder 4.7 (64 Bit)\eclipse\plugins\com.adobe.flash.compiler_4.7.0.349722\AIRSDK\lib \aot\lib\llvm.dll
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1706)
at java.lang.Runtime.load0(Runtime.java:770)
at java.lang.System.load(System.java:1004)
at adobe.abc.LLVMEmitter.loadJNI(LLVMEmitter.java:587)
at adobe.abc.LLVMEmitter.<clinit>(LLVMEmitter.java:597)
at com.adobe.air.ipa.AOTCompiler.generateExtensionsGlue(AOTCompiler.java :419)
at com.adobe.air.ipa.AOTCompiler.generateMachineBinaries(AOTCompiler.jav a:1790)
at com.adobe.air.ipa.IPAOutputStream.createIosBinary(IPAOutputStream.jav a:378)
at com.adobe.air.ipa.IPAOutputStream.finalizeSig(IPAOutputStream.java:76 2)
at com.adobe.air.ApplicationPackager.createPackage(ApplicationPackager.j ava:91)
at com.adobe.air.ipa.IPAPackager.createPackage(IPAPackager.java:246)
at com.adobe.air.ADT.parseArgsAndGo(ADT.java:571)
at com.adobe.air.ADT.run(ADT.java:419)
at com.adobe.air.ADT.main(ADT.java:470)
In my case this seemed to be caused by a 32-bit installation of JRE (Java Runtime Environment) I had installed for an unrelated application. With JRE installed it's possible that Flash Builder was attempting but unable to use the 32-bit dlls?
Apparent Solution:
I installed the 64-bit version of JRE alongside it which appears to have resolved the problem.
Update:
My previous proposed solution (of installing the 64-bit JRE) resulted in a different problem. After multiple attempts and restarts I was unable to work in the Flash Builder IDE as it became unresponsive on load. Each time I had to use Task Manager to close the application.
Apparent Solution:
Close all applications running in Windows
Uninstall all versions of JRE (Java Runtime Environment)
Uninstall Flash Builder 4.7
Reinstall Flash Builder 4.7
North America
Asia Pacific
