IvanRisingStar
After Effects CS6 - mp4 file error
Feb 2, 2013 9:33 PM
Initially I struggled to get After Effects to import footage that was shot with a Sony F3 (mp4 codec)
I got it right eventually, don’t know how but it worked fine for more than a month.
This afternoon however it just refused to work and I get the standard error saying the file is damaged or unsupported.
I checked the forum but can’t seem to find a solution the problem. A couple of people suggested that the footage be converted to another format.
So I have 2 questions:
1. Is this a bug in CS6?
2. What other format can I convert the footage to without losing any quality that will play in After Effects.
Regards
IvanRisingStar
    Feb 3, 2013 12:24 AM   in reply to IvanRisingStar
    Have you installed any alternate media players or CoDec packs recently? If so, you may have busted up your CoDecs. Get rid of whatever you added and reinstall AE as well as Quicktime. Beyond that you would have to provide a lot more info to figure this out.
    Mylenium
    Feb 3, 2013 1:54 AM   in reply to IvanRisingStar
    Just asking. These issues are most commonly caused by such stuff... If it worked for a month, then something has chnaged that prevents it from working now... Do the files still open in Media Player or Quicktime?
    Mylenium
    Feb 3, 2013 3:47 AM   in reply to IvanRisingStar
    Neither QT nor WMP being able to play the files would still indicate a CoDec issue or at least a graphics acceleration issue. Perhaps update/ un-update your graphics driver and check the hardware playback options in the QT system control panel and WMP's settings...
    Mylenium
