Hello!
I have a Running Header that is using my style from my Chapter Name in my book. In the chapter name on the page, I've used a soft return. Now my Running Header only shows half of the chapter name because I used a soft return in the title on the page.
Is there any work around for this?
Thanks!
Variables don't break across lines, and they pick up exactly the text that is carrying whatever style is selected, so if you use a soft return and specify a paragraph style your header text will ose everything beyond the line break (because the varialbe cannot wrap). You can use two paragraph styles (that differ only in their names, if you like) and a hard return with two paragraph style variables, and a space between, or you can use two character styles applied to the different lines in a single paragraph with the forced break and two character style-based running headers, again with a space between.
The character styles, if you use this method, should have no attributes at all other than a unique name so they do not change the formatting. You can apply the characters styles as nested styles in the paragraph style (a good way to do it becasue the disappear completely when you assign a new paragraph style to the variable text itself, or to a TOC listing that uses the paragraph style). The character style method in connection with a forced line break may make your life easier when it's time to build the TOC since the chapter headings will use only one paragraph style. You will, though, need to use find/change on the TOC to replace the forced line breaks with spaces.
To use the nested style approach you define the basic formatting of the paragraph style, then in the nested styles section appy character style 1 up to 1 forced line break, none through 1 character, and character style 2 through 1 sentence.
I think I understand the nested character style approach. Except that my second line needs to be indented somewhat and I can't (don't know how to) achieve that without making a hard return.
I was successful with the two-paragraph style approach, but again it puts the hard return when I generate the TOC. Maybe this is fine, since even using a soft return would break the lines in the TOC generation anyway. Is that correct?
A break is a break. Either way you would need to remove it if desired in the TOC.
I suppose one could use a frame which is attached to the text. One line for the header and each frame adjusted so the text would wrap where desired for each chapter. One paragraph style, one line in the TOC.
Mike
That's correct. The differnce, though is you only need to include one paragaph style if you use the forced break approach, which makes things a bit simple in building the TOC.
To get your second line indent, add that amount as a left indent to the pargarph style, then add the same amount as a negative to the first line. This is called a hanging indent.
I think it might work with InDesign CS6's text frame Auto Size feature and a combination of techniques mentioned above. Just a wild stab, didn't try to test.
HTH
Regards,
Peter
_______________________
Peter Gold
KnowHow ProServices
That is contrary to my experiences so far, so I checked with InDesign CS4, CS5, and CS6. This is the behavior I remembered: a soft return gets converted to a regular space. There is no difference between a Paragraph style (left header) and a Character style (right header).
However ...
If I change the type from "First on Page" to "Last on Page", soft returns are suddenly discarded!
(This is on my Mac; does Windows show the same erratic behavior re: Soft Returns?)
No amount of resizing the frame ever makes parts of the header invisible. If the text frame is too small, the header just gets crunched up to fit; it'll never wrap to a second line. Also, since soft returns aren't picked up, you will never get a "second line" that way either.
So it's not what the OP is experiencing.
I would like to see a screenshot from a page showing both chapter title and the resulting header, with Invisible Characters on.
> As you said, the forced break was converted to a space when using first on page, but it was just dropped entirely when using last.
Submitted as Bug. It's potentially harmful, as it is an unexplainable and unnecessary random difference when you toggle from First to Last on Page.
cc2545, unfortunately this issue seems unrelated to yours. Care to show a screenshot? Perhaps there is something else in your file that messes up things for you.
Ok, I think I figured out what's happening for me...
In preparing my screenshot test, I was now able to recreate the same effect that Peter has. When I went back to look at my "real" file, I realized I don't have the running header on my Chapter start page, so the first instance it shows up is on the following pages.I guess that's why I have to put the extra space before the forced line break for it to work. In any event, here's my test images (they work like Peter's).
First on Page:
Last on Page:
Unfortunately no, I cannot show that text here. But here's more of my tests on those actual pages...
With a space before the soft return:
First on page = 2 spaces in Running Header on the chapter start page, and correct Running Headers on succeeding pages.
Last on page = Correct Running Headers on all pages
With NO space before the soft return:
First on page = Correct Running Header on chapter start page, incorrect on all succeeding pages (ie no space where the soft return was)
Last on page = Incorrect Running Header on all pages (ie no space where the soft return was)
Hope this helps.
I'm confused at this point. In your first post you said everything after the soft return was missing. My suspicion is that you actually had a hard return, not soft, since none of us, at this point is seeing text after the line break disappearing.
The use of the character styles may still turn out to be the best option since it works around the apparent bug with the dropped space, but we haven't really answered what was happening in the original problem.
Yes, you are probably right, maybe it was a hard return (and I wrote soft). Now that I've made so many tests & changes, I can't remember. Well, I'm glad I helped uncover something else to fix and also found a fix to my immediate problem (because now it's working the way I want it).
Thank you all again for your help.
North America
Asia Pacific
