i know that i am a few years late here, but i am looking ot make the migration from using tables and switching over to div tags and css. i have watched a few tutorials on you tube and am trying to understand everything.
please tell me if this is correct. a div tag is basically a table and css is what is used to style that div tag to meet your needs, is this a correct assumption??
if you go to my current site www.tankinz.com you can clearly see that the site is made up of tables, basically these boxes or tables contain a different item or package that a customer can click on and buy. by using div tags and css would each of these boxes, or tables be their own div?
sorry for sounding a bit moronic but i am trying to make sense of all of this.
please help!
Markup (html) contains elements, such as html, body, h1, h2, p, span, div and so forth. Hence a <div>-tag is part of an element; the other part being the </div>-tag.
The element structure of many web sites is basically (using HTML5 element names)
html
head
body
header
nav
aside
article
footer
These elements can be positioned and styled using style rules (css). Depending on the style rules, the above structure can take on many different styles, without ever touching the markup.
Have a look here for a simple two-column layout using the same structure as above http://www.456bereastreet.com/lab/developing_with_web_standards/csslay out/2-col/
There are plenty of video tutorials, all you need to do is Google the subject. But none that I have come across that go at the same pace as the student.
This will probably help you more http://forums.adobe.com/thread/492638
I strongly recommend that you buy the following book`:
CSS: The Missing Manual
It is very well written and easy to follow. This will give you a good grounding on how to use and apply CSS.
In addition to this book it might ve be helpful to buy a book called 'The CSS Anthology' by Rachel Andrew. This contains all the code and explantion you need to create anything that looks like a table - such as a diary page etc.
Good luck!
Simon
North America
Asia Pacific
