hgkp
quick time export
Feb 3, 2013 12:49 PM
I am exporting a quick time file from my CS 6 time line.
It is a straight time w/o any effects.
So it goes it up till 98% of the render and it comes up with "Unknow Error" message.
I have looked around the forums for this error message but haven't fixed my issue
Here's my setting
Format Quicktime, code H.264, Data rate of 47mbps (limit), encoding quality at 98% and turned on "Use Maximum Render Quality"
It gives the "unknown error" when exporting the tail credits.
So reduced the work area just to the tail end of the movie where it crashed and exported the tail credits and it worked fine.
So my question  - Can cs6 write files of 20 GB ? I have 8GB of RAM Windows 7 machine .
I assigned 5GB of RAM for cs6 premier.
thanks
    Feb 3, 2013 1:12 PM   in reply to hgkp
    Just wondering why you intentionally destroy the 64 bit nature of PR by using 32 bit QuiRcktime?
  • joe bloe premiere
    Dec 6, 2009
    Feb 3, 2013 2:45 PM   in reply to hgkp
    Yes.
  • joe bloe premiere
    Dec 6, 2009
    Feb 3, 2013 2:52 PM   in reply to hgkp
    Without more information regarding your media, sequence,
    project, export settings and system specs, it is impossible to know.
    Feb 3, 2013 6:17 PM   in reply to hgkp
    i need mov file.
    Why?  MP4 is the far more common (and better) format for H.264 video.
    Feb 3, 2013 6:59 PM   in reply to Jim Simon
    Possibly a more important question, does it work if you do it Jim's way and not when you export a Quicktime file?
    Also, 47Mb/s is a very high data rate. What is the data rate of the original footage. It is seldom necessary to export at a higher data rate than the source media.
