I have read previous posts on this subject and the comment that Youtube often change their specs. The various remedial suggestions seem a bit technical for me. Even going into Youtube and trying to upload files does not seem to work.
It would not upload a file I had loaded a few days ago.
I use PE 10 . I am thinking of trying to upload to Vimeo instead which PE 10 does not support. Does PE 11 support Vimeo?
If so it will give me an excuse to upgrade.
Version 11 does indeed give you a direct link to Vimeo as well as YouTube and Facebook.
Although, in version 10 as well as 11, you can also use Share/Computer/AVCHD, where you'll find presets that are optimized for outputting video for YouTube and Vimeo (either one of which will also work for video you plan to upload to Facebook and Flickr).
foxdown88 wrote:
....... The various remedial suggestions seem a bit technical for me. Even going into Youtube and trying to upload files does not seem to work. It would not upload a file I had loaded a few days ago.
If you provide a little more detail, I can probably help. What steps didn't work? What camera footage file type did you start with? How long is your video?
The process that works best for me is to create the video file like Steve says. It is the same in 10 and 11. Then use the YouTube upload page here: https://www.youtube.com/upload
Bill
Thanks Bill
I will try Steve's suggestion.
In answer to your question about the detail.
The source file was AVI.
When I went into Share I chose YouTube
Up came
Flash video
H.264
640x480
30 fps
file size 2min 38 sec
I press Next but in the next screen asking for the title and description the Next button is greyed out.
When I log into YouTube separately and try and upload the file ( and one I have previously uploaded successfully) the message is ' the video has failed to process'
I have tried all the other non HD presets and the next button is still greyed out. Very annoying but the good news is that I have successfully uploaded to Vimeo . See https://vimeo.com/user13747012/videos
Foxdown,
Researching the YouTube issue a bit more, yielded a response from Adobe. Right at the end of 2012, YouTube did make a change in the handling of uploads, but all should have been fixed by about mid-January, 2013.
However, and with that said, it seems that as of early Feb, 2013, some Premiere Elements users were still experiencing issues. I wonder if you were able to rectify the issue with the direct uploading from PrE? Any info would be greatly appreciated.
Thank you, and good luck,
Thanks Bill
Have just created a new clip and tried to upload to PrE but have the same problem ie the Next button is greyed out. However now I have discovered I can download using the AVCH setting to Vimeo and then upload the file into Vimeo; I tried the same thing with the YouTube setting and have successfully uploaded to YouTube
North America
Asia Pacific
