super93
Color Shift When Importing JPG Sequence into Flash CS6
Feb 4, 2013 10:44 AM
I am importing a jpg sequence into flash that has been exported from After Effects CS6. No matter what I try, the color will shift when the image imports into flash. The sequence originally started out as a vector graphic in Illustrator (color profile set to sRGB IEC61966-2.1) and then imported into After Effects for an animation that I couldn't quite achive in Flash. The color profile in After Effects is also sRGB IEC61966-2.1 with the "Match Legacy" checkbox checked. I export it out of After Effects as a JPG Sequence and then import into Flash. No matter what I try, the bitmap images' color will shift (become dull) when I import. Even when I open the images in Windows Photo Gallery, they look fine - it's only when I import into Flash.  I've also tried PNG and .PSD Sequence with the same result. I've searched around, but still haven't found a solution. Any help is greatly appreciated.
    Feb 5, 2013 5:49 AM   in reply to super93
    Flash has Problem with certain 32bit pictures. Try to go for 24bit.
    Feb 18, 2013 7:11 AM   in reply to super93
    I am in the midst of trying to figure out the opposite : Flash to After Effects.  I am betting that this is an issue of 'color profile' attached to the images and the gamma settings in that profile.  RGBA is only part of the story - color profile is all the rest of it.  Eye Dropper doesn't tell you the color profile attached to the image.
    Feb 18, 2013 7:21 AM   in reply to keldonrush
    If you have Fireworks installed, it should help to let it prepare the last version before you import to Flash.
    So the workflow maybe: Illustrator/PS >png>import in fireworks>export to jpg for flash
    Fireworks translates the color space (if its not a common one) into flashs "reduced" colorspace vocbulary
