Audio Channels in Timeline Keep Changing?
Feb 4, 2013 12:52 PM
I have some audio tracks, on those tracks I inserted a .wav file that has 4 channels.  I only need 2 channels. ( 1 and 2 )  I unlinked the audio and I am just using channels 1 and 2.
Channel 2 on the timeline keeps defaulting to Channel 1 - I change it and then next time I open the p[roject the audio on channel 2 goes back to channel 1.
I hope this makes sense.
This picture is what it needs to be
This picture below is what it changes to and I have to reset the channel.
Below is info on the audio channel
Im doing something wrong right?
I hope not because I have already layed in and adjusted all my audio.
Thanks for your help!
    Feb 4, 2013 2:52 PM   in reply to LeBeauStudio
    given:
    --> source is 4 channel WAV
    --> Audio mapping:
    1. source channel 2 -->  mono track channel 1
    Have you made a copy of the WAV in the bin to set the second audio mapping assignment?
    2. source channel 1 --> mono track channel 1
    So it would make sense that the audio is pointing to source channel 1 because that was the last assignment you made?
    I use the channel assigment a lot for 5.1 tracks it is working fine for me.
    --> Can you describe a bit more what doesn't works like expected?
    Feb 6, 2013 11:12 AM   in reply to LeBeauStudio
    Ahh - now I understand ;-)
    so much channel tracks switches...
    Premiere forgets what source channel to use and switches back from source channel 2 to source channel 1 after the project is reopened.
    I'll do some test's here and see if I get the same problem...
    Feb 6, 2013 4:01 PM   in reply to LeBeauStudio
    This Adobe KB Article (and included tutorial) might be helpful for Track Mapping in PrPro CS 6: http://helpx.adobe.com/premiere-pro/using/overview-audio-audio-mixer.h tml
    Jan 15, 2014 2:27 AM   in reply to LeBeauStudio
    I also have this problem. The workaround seems to be to use the Audio Effect "Fill Left" rather than the Channel Assignment method - which just reverts when the project is saved and reloaded. I still don't know why this happens - I think it's a bug.
