grapplepeeps
Having to "double-clutch" adding behaviors every time
Feb 5, 2013 9:47 AM
Hello. I am using Dreamweaver CS6. I've been using DW since CS3. Back then, I thought "Well, it is odd that every time I add a behavior, I have to watch it change on it's own from, say 'OnClick' to 'On MouseOver' before reentering it as the 'OnClick' I really wanted, but maybe this is just a quirk."
Nope.
Same thing in CS4
Same thing in CS5
Now the same thing in CS6. It seems pointless and easy to fix. It's no big deal. Instead of taking 20 seconds to enter a behavior, I take 40. Not a problem. But, when I have to do several dozen repetitive behaviors, as I just did, it really adds up, even if only in the carple tunnels.
Adobe folks, are you aware of this? It can't be just me. Why not fix it so that when I select "OnXxxx," and add the Behavior, then OK, it's just there. Saved. Why must it switch on it's own to a different trigger before it will accept and implement my choice?
Glenn
    Feb 5, 2013 10:18 AM   in reply to grapplepeeps
    Same in MX2004.
    This is a user forum, staff rarely read it
    Submit your suggestion to
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Feb 5, 2013 11:56 AM   in reply to grapplepeeps
    Don't hold me to this, but I seem to recall that after selecting the behavior,
    before returning to the document window, I would left-click in a blank area of the Behaviors panel and it would "lock in" my first selection
    Feb 5, 2013 12:35 PM   in reply to grapplepeeps
    I rarely use behaviors.  But I just did a test in CS6 (Creative Cloud version) and I could not replicate your problem.  Ideally the onClick trigger should be applied to the anchor <a> tag and not the img or text.
    <a href="javascript:()" onclick="MM_effectAppearFade(this, 1000, 100, 0, false)">type some text</a>
    Nancy O.
    Feb 5, 2013 12:51 PM   in reply to Nancy O.
    I also just tested in DWCS4 and can't get it to do what you describe.
    Could you post the exact step-by-step process you are using (don't leave out a mouse click)?
