I have searched the forums for weeks and have yet to find a solution that works. I am currently running WIndows 7 Pro 64 Bit in a corporate environment. I orginally installed all my apps from the Application Manager and then one day about a month ago, it stopped working. I know I have read posts that you can download the trials but there are certain products that you cannot get in a trial like Edge Animate. I have done the following things to resolve: (in no paticular order, just everything I have tried thus far). I really need to get Edge Animate installed. I have spent over a week trying to solve this so hopeuflly someone out there can see something I am not.
Read all my logs and compared them to other forum issues.
Uninstalled every Adobe App and ran the Cleaner Tool.
Re-Installed the AAM Manager 6.2all.
Created a new admin account on my computer and tried from there.
Tried on a different computer.
Renamed my OOBE folder.
Turned off all my antivirus and firewall software. I tested to make sure that I could get to the https license site and I could.
Rebuilt my machine from scratch. NO ADOBE SOFTWARE, ANIT-VIRUS etc. Still the same issues. For installing new software I get: The download appears corrupt, Press Cancel -(60)
And for updates I get: Update Failed: The download appears corrupt. ...... (U43M1D207).
Here is the weird part. I watch step by step what it does. I open up Applicaiton Manger. Click on Install (say for Edge Animate). Go to my Users\AppData\Local\Temp folder and see that it creates a temporary folder with letters and numbers. I can see 4 files being downloaded fully. Edge Animate.exe (2), Manifest.xml and info. It fully downloads them and then they disappear and that's when the error appears. I made sure that the proper rights were on that folder and set to Full Access.
Here is my PDAPP.log: I cleared out the log and ran the install for a new app and an update so you can see both errors.
02/05/13 12:01:12:611 | [INFO] | | ASU | RunMeFirst | RunMeFirst | | | 6248 | Build Version - 7.0.0.230
02/05/13 12:01:12:611 | [INFO] | | ASU | RunMeFirst | RunMeFirst | | | 6248 | Logging Level verbosity Set to 4
02/05/13 12:01:12:611 | [INFO] | | ASU | RunMeFirst | RunMeFirst | | | 6248 | Launching the Bootstrapper in elevated mode
02/05/13 12:01:12:611 | [INFO] | | ASU | RunMeFirst | Utilities | | | 6248 | Path to Process :C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\Set-up.bin Process Directory :C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2 arguments being passed :"C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\Set-up.bin"
02/05/13 12:01:12:611 | [INFO] | | ASU | RunMeFirst | Utilities | | | 6248 | Success in CreateProcess
02/05/13 12:01:13:079 | [INFO] | | ASU | Setup | Setup | | | 6256 | Build Version - 7.0.0.233
02/05/13 12:01:13:079 | [INFO] | | ASU | Setup | Setup | | | 6256 | Logging Level verbosity Set to 4
02/05/13 12:01:13:095 | [INFO] | | ASU | Setup | Setup | | | 6256 | Start Adobe Setup
02/05/13 12:01:13:095 | [INFO] | | ASU | Setup | Setup | | | 6256 | TimeLog: Bootstrapper Start
02/05/13 12:01:13:095 | [INFO] | | ASU | Setup | Setup | | | 6256 | TimeLog: Start initial checks
02/05/13 12:01:13:095 | [INFO] | | ASU | Setup | Setup | | | 6256 | Dictionary Path: C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\resources\Dictionary\en_US\stringTable.zdct
02/05/13 12:01:13:095 | [INFO] | | ASU | Setup | PIM | | | 6256 | XML is valid
02/05/13 12:01:13:095 | [WARN] | | ASU | Setup | PIM | | | 6256 | Failed to find Node
02/05/13 12:01:13:173 | [INFO] | | ASU | Setup | Utilities | | | 6280 | Semaphore is not locked
02/05/13 12:01:13:204 | [INFO] | | ASU | PIM | PIM | | | 6280 | Build Version - 7.0.0.233
02/05/13 12:01:13:204 | [INFO] | | ASU | PIM | PIM | | | 6280 | Logging Level verbosity Set to 4
02/05/13 12:01:13:204 | [INFO] | | ASU | PIM | Utilities | | | 6280 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\pim.db-journal' does not exist
02/05/13 12:01:13:204 | [INFO] | | ASU | PIM | Utilities | | | 6280 | File 'C:\Users\a01gassu\AppData\Local\Temp\\asuap.txt' does not exist
02/05/13 12:01:13:204 | [INFO] | | ASU | PIM | PIM | | | 6280 | CREATE PIM Instance ...
02/05/13 12:01:13:204 | [INFO] | | ASU | PIM | Utilities | | | 6280 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\pim.db-journal' does not exist
02/05/13 12:01:13:204 | [INFO] | | ASU | PIM | Utilities | | | 6280 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\pim.db' does not exist
02/05/13 12:01:13:204 | [INFO] | | ASU | PIM | PIM | | | 6280 | trying to createOrUpdatePIMDbSchema.
02/05/13 12:01:13:298 | [INFO] | | ASU | PIM | PIM | | | 6280 | SUCCESS Created Tables.
02/05/13 12:01:13:298 | [INFO] | | ASU | PIM | PIM | | | 6280 | PIM Database is Up To Date.
02/05/13 12:01:13:298 | [INFO] | | ASU | PIM | PIM | | | 6280 | Updater Inventory location:C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\resources\updaterinventory.dll
02/05/13 12:01:13:298 | [INFO] | | ASU | PIM | PIM | | | 6280 | Acquired System level ACF lock ...
02/05/13 12:01:13:313 | [INFO] | | ASU | Setup | Setup | | | 6256 | TimeLog: End initial checks
02/05/13 12:01:13:313 | [INFO] | | ASU | Setup | Setup | | | 6284 | TimeLog: Begin Installing
02/05/13 12:01:13:313 | [INFO] | | ASU | PIM | PIM | | | 6284 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/05/13 12:01:13:313 | [INFO] | | ASU | PIM | PIM | | | 6284 | XML is valid
02/05/13 12:01:13:313 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:13:407 | [INFO] | | ASU | PIM | PIM | | | 6284 | XML is valid
02/05/13 12:01:13:407 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:13:438 | [INFO] | | ASU | PIM | PIM | | | 6284 | XML is valid
02/05/13 12:01:13:438 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:13:469 | [INFO] | | ASU | PIM | PIM | | | 6284 | XML is valid
02/05/13 12:01:13:469 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:13:485 | [INFO] | | ASU | PIM | PIM | | | 6284 | XML is valid
02/05/13 12:01:13:485 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:13:516 | [INFO] | | ASU | PIM | PIM | | | 6284 | XML is valid
02/05/13 12:01:13:516 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:13:547 | [INFO] | | ASU | PIM | PIM | | | 6284 | XML is valid
02/05/13 12:01:13:547 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:13:641 | [INFO] | | ASU | PIM | PIM | | | 6284 | XML is valid
02/05/13 12:01:13:641 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:13:672 | [INFO] | | ASU | PIM | PIM | | | 6284 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 122563823
02/05/13 12:01:13:672 | [INFO] | | ASU | PIM | PIM | | | 6284 | Executing Adobe Genuine Validation for all the AAM packages
02/05/13 12:01:13:672 | [INFO] | | ASU | PIM | PIM | | | 6284 | Validating package file: 'C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\core\PDApp.pimx'
02/05/13 12:01:13:672 | [INFO] | | ASU | PIM | PIM | | | 6284 | Validating package file: 'C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\core\PDApp.pima'
02/05/13 12:01:13:672 | [INFO] | | ASU | PIM | PIM | | | 6284 | Validating package file: 'C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\D6\D6.pimx'
02/05/13 12:01:13:672 | [INFO] | | ASU | PIM | PIM | | | 6284 | Validating package file: 'C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\D6\D6.pima'
02/05/13 12:01:13:672 | [INFO] | | ASU | PIM | PIM | | | 6284 | Validating package file: 'C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\DECore\DECore.pimx'
02/05/13 12:01:13:672 | [INFO] | | ASU | PIM | PIM | | | 6284 | Validating package file: 'C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\DECore\DECore.pima'
02/05/13 12:01:13:672 | [INFO] | | ASU | PIM | PIM | | | 6284 | Validating package file: 'C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\DWA\DWA.pimx'
02/05/13 12:01:13:672 | [INFO] | | ASU | PIM | PIM | | | 6284 | Validating package file: 'C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\DWA\DWA.pima'
02/05/13 12:01:13:688 | [INFO] | | ASU | PIM | PIM | | | 6284 | Validating package file: 'C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\P6\P6.pimx'
02/05/13 12:01:13:688 | [INFO] | | ASU | PIM | PIM | | | 6284 | Validating package file: 'C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\P6\P6.pima'
02/05/13 12:01:13:688 | [INFO] | | ASU | PIM | PIM | | | 6284 | Validating package file: 'C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\LWA\LWA.pimx'
02/05/13 12:01:13:688 | [INFO] | | ASU | PIM | PIM | | | 6284 | Validating package file: 'C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\LWA\LWA.pima'
02/05/13 12:01:13:688 | [INFO] | | ASU | PIM | PIM | | | 6284 | Validating package file: 'C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\UWA\UWA.pimx'
02/05/13 12:01:13:688 | [INFO] | | ASU | PIM | PIM | | | 6284 | Validating package file: 'C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\UWA\UWA.pima'
02/05/13 12:01:13:688 | [INFO] | | ASU | PIM | PIM | | | 6284 | Validating package file: 'C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\CCM\CCM.pimx'
02/05/13 12:01:13:688 | [INFO] | | ASU | PIM | PIM | | | 6284 | Validating package file: 'C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\CCM\CCM.pima'
02/05/13 12:01:13:688 | [INFO] | | ASU | PIM | PIM | | | 6284 | Adobe Genuine Validation PASSED for all the AAM packages
02/05/13 12:01:13:688 | [INFO] | | ASU | PIM | PIM | | | 6284 | START installPackage at file C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\core\PDApp.pimx
02/05/13 12:01:13:703 | [INFO] | | ASU | PIM | PIM | | | 6284 | XML is valid
02/05/13 12:01:13:703 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:13:953 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS insertPackageUpdateList.
02/05/13 12:01:13:953 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:13:953 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS insertAppletRegInfoList.
02/05/13 12:01:15:279 | [INFO] | | ASU | PIM | Utilities | | | 6284 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core\PDApp.pimx' does not exist
02/05/13 12:01:15:654 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS installPackage at file C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\core\PDApp.pimx.
02/05/13 12:01:15:763 | [INFO] | | ASU | PIM | PIM | | | 6284 | START installPackage at file C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\D6\D6.pimx
02/05/13 12:01:15:763 | [INFO] | | ASU | PIM | PIM | | | 6284 | XML is valid
02/05/13 12:01:15:778 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:15:919 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS insertPackageUpdateList.
02/05/13 12:01:15:919 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS insertAppletRegInfoList.
02/05/13 12:01:16:434 | [INFO] | | ASU | PIM | Utilities | | | 6284 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\D6\D6.pimx' does not exist
02/05/13 12:01:17:026 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS installPackage at file C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\D6\D6.pimx.
02/05/13 12:01:17:104 | [INFO] | | ASU | PIM | PIM | | | 6284 | START installPackage at file C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\DECore\DECore.pimx
02/05/13 12:01:17:104 | [INFO] | | ASU | PIM | PIM | | | 6284 | XML is valid
02/05/13 12:01:17:104 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:17:229 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS insertPackageUpdateList.
02/05/13 12:01:17:229 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:17:229 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS insertAppletRegInfoList.
02/05/13 12:01:18:914 | [INFO] | | ASU | PIM | Utilities | | | 6284 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\DECore\DECore.pimx' does not exist
02/05/13 12:01:19:226 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS installPackage at file C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\DECore\DECore.pimx.
02/05/13 12:01:19:366 | [INFO] | | ASU | PIM | PIM | | | 6284 | START installPackage at file C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\DWA\DWA.pimx
02/05/13 12:01:19:366 | [INFO] | | ASU | PIM | PIM | | | 6284 | XML is valid
02/05/13 12:01:19:366 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:19:819 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS insertPackageUpdateList.
02/05/13 12:01:19:819 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS insertAppletRegInfoList.
02/05/13 12:01:19:819 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:20:365 | [INFO] | | ASU | PIM | Utilities | | | 6284 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\DWA\DWA.pimx' does not exist
02/05/13 12:01:20:739 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS installPackage at file C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\DWA\DWA.pimx.
02/05/13 12:01:21:176 | [INFO] | | ASU | PIM | PIM | | | 6284 | START installPackage at file C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\P6\P6.pimx
02/05/13 12:01:21:176 | [INFO] | | ASU | PIM | PIM | | | 6284 | XML is valid
02/05/13 12:01:21:176 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:21:316 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS insertPackageUpdateList.
02/05/13 12:01:21:316 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS insertAppletRegInfoList.
02/05/13 12:01:24:327 | [INFO] | | ASU | PIM | Utilities | | | 6284 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\P6\P6.pimx' does not exist
02/05/13 12:01:25:435 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS installPackage at file C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\P6\P6.pimx.
02/05/13 12:01:25:825 | [INFO] | | ASU | PIM | PIM | | | 6284 | START installPackage at file C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\LWA\LWA.pimx
02/05/13 12:01:25:825 | [INFO] | | ASU | PIM | PIM | | | 6284 | XML is valid
02/05/13 12:01:25:825 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:26:121 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS insertPackageUpdateList.
02/05/13 12:01:26:121 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS insertAppletRegInfoList.
02/05/13 12:01:26:121 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:28:306 | [INFO] | | ASU | PIM | Utilities | | | 6284 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\LWA\LWA.pimx' does not exist
02/05/13 12:01:28:742 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS installPackage at file C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\LWA\LWA.pimx.
02/05/13 12:01:29:491 | [INFO] | | ASU | PIM | PIM | | | 6284 | START installPackage at file C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\UWA\UWA.pimx
02/05/13 12:01:29:491 | [INFO] | | ASU | PIM | PIM | | | 6284 | XML is valid
02/05/13 12:01:29:491 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:29:881 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS insertPackageUpdateList.
02/05/13 12:01:29:881 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS insertAppletRegInfoList.
02/05/13 12:01:31:582 | [INFO] | | ASU | PIM | Utilities | | | 6284 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\UWA\UWA.pimx' does not exist
02/05/13 12:01:32:206 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS installPackage at file C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\UWA\UWA.pimx.
02/05/13 12:01:32:299 | [INFO] | | ASU | PIM | PIM | | | 6284 | START installPackage at file C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\CCM\CCM.pimx
02/05/13 12:01:32:299 | [INFO] | | ASU | PIM | PIM | | | 6284 | XML is valid
02/05/13 12:01:32:299 | [WARN] | | ASU | PIM | PIM | | | 6284 | Failed to find Node
02/05/13 12:01:32:455 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS insertPackageUpdateList.
02/05/13 12:01:32:455 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS insertAppletRegInfoList.
02/05/13 12:01:33:750 | [INFO] | | ASU | PIM | Utilities | | | 6284 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\CCM\CCM.pimx' does not exist
02/05/13 12:01:34:561 | [INFO] | | ASU | PIM | Utilities | | | 6284 | Path to Process :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\CCM\Utilities\AdobeApplicationManager(URIHandler).exe Process Directory :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\CCM\Utilities arguments being passed :"C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\CCM\Utilities\AdobeApplicationManager(URIHandler).exe" --register=true --createShortcut=true
02/05/13 12:01:34:561 | [INFO] | | ASU | PIM | Utilities | | | 6284 | Success in CreateProcess
02/05/13 12:01:35:092 | [INFO] | | ASU | PIM | Utilities | | | 6284 | Sucessfully launched and executed process...
02/05/13 12:01:35:092 | [INFO] | | ASU | PIM | PIM | | | 6284 | Successfully executed install modifier at path: 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\CCM\Utilities\AdobeApplicationManager(URIHandler).exe'
02/05/13 12:01:35:092 | [INFO] | | ASU | PIM | PIM | | | 6284 | SUCCESS installPackage at file C:\Users\a01gassu\Desktop\Adobe Application Manager 6.2\packages\CCM\CCM.pimx.
02/05/13 12:01:35:841 | [INFO] | | ASU | PIM | Utilities | | | 6284 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\PDAppFlex.swf' does not exist
02/05/13 12:01:35:919 | [INFO] | | ASU | PIM | Utilities | | | 6284 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\PDAppFlex-app.xml' does not exist
02/05/13 12:01:35:965 | [INFO] | | ASU | PIM | PIM | | | 6284 | Processing ... _pimCreateOrUpdateAAMInventory
02/05/13 12:01:35:981 | [INFO] | | ASU | PIM | PIM | | | 6284 | Inventory Already present on the machine...
02/05/13 12:01:35:981 | [INFO] | | ASU | Setup | Setup | | | 6284 | TimeLog: End Installing. Now launching PDApp
02/05/13 12:01:36:558 | [INFO] | | ASU | Setup | Setup | | | 6256 | Bootstrapping successful. PDApp launched. Quitting Bootstrapper
02/05/13 12:01:36:558 | [INFO] | | ASU | PIM | PIM | | | 6256 | PIMSqlite closeDB status 0
02/05/13 12:01:36:558 | [INFO] | | ASU | PIM | PIM | | | 6256 | FREE PIM Instance ...
02/05/13 12:01:36:558 | [INFO] | | ASU | Setup | Setup | | | 6256 | ================= End Adobe Setup. Exit code: 0 =================
02/05/13 12:01:49:210 | [INFO] | | ASU | PDApp | PDApp | | | 6544 | Build Version - 7.0.0.233
02/05/13 12:01:49:210 | [INFO] | | ASU | PDApp | PDApp | | | 6544 | Logging Level verbosity Set to 4
02/05/13 12:01:49:210 | [INFO] | | ASU | PDApp | PDApp.CommandLineParser | | | 6544 | Parsing the command line provided. Number of command line arguments is 4
02/05/13 12:01:49:210 | [INFO] | | ASU | PDApp | PDApp | | | 6544 | Detecting Applet Database Library file...
02/05/13 12:01:49:210 | [INFO] | | ASU | PDApp | PDApp | | | 6544 | Fetching Applet registeration information...
02/05/13 12:01:49:210 | [INFO] | | ASU | PDApp | PDApp.AppletManager | | | 6544 | AppletManager initialize...
02/05/13 12:01:49:210 | [INFO] | | ASU | PDApp | PDApp.AppletManager | | | 6544 | Applet database path - C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core\..
02/05/13 12:01:49:210 | [INFO] | | ASU | PDApp | PDApp.AppletManager | | | 6544 | PIM library path - C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core\AdobePIM.dll
02/05/13 12:01:49:210 | [INFO] | | ASU | PDApp | PDApp.AppletManager | | | 6544 | Loading PIM library...
02/05/13 12:01:49:226 | [INFO] | | ASU | PIM | PIM | | | 6544 | Build Version - 7.0.0.233
02/05/13 12:01:49:226 | [INFO] | | ASU | PIM | PIM | | | 6544 | Logging Level verbosity Set to 4
02/05/13 12:01:49:226 | [INFO] | | ASU | PIM | PIM | | | 6544 | CREATE PIM Instance ...
02/05/13 12:01:49:226 | [INFO] | | ASU | PIM | Utilities | | | 6544 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core\..\pim.db-journal' does not exist
02/05/13 12:01:49:288 | [INFO] | | ASU | PIM | PIM | | | 6544 | trying to createOrUpdatePIMDbSchema.
02/05/13 12:01:49:288 | [INFO] | | ASU | PIM | PIM | | | 6544 | Current db schema version on machine 1.
02/05/13 12:01:49:288 | [INFO] | | ASU | PIM | PIM | | | 6544 | Current db schema version to install 1.
02/05/13 12:01:49:288 | [INFO] | | ASU | PIM | PIM | | | 6544 | PIM DB Schema is up to date. Current schema version is 1.
02/05/13 12:01:49:288 | [INFO] | | ASU | PIM | PIM | | | 6544 | PIM Database is Up To Date.
02/05/13 12:01:49:288 | [INFO] | | ASU | PDApp | PDApp.AppletManager | | | 6544 | Getting applet data from Applet database
02/05/13 12:01:49:288 | [INFO] | | ASU | PDApp | PDApp.AppletManager | | | 6544 | All installed pakages version string (pim_getCurrentPackagesVersion) is CCM:7.0.0.237|D6:7.0.0.235|DECore:7.0.0.235|DWA:3.0.97.0|LWA:3.0.97.0|P6:7.0.0.125|PDApp:7.0.0.235|UWA:7.0.0.235
02/05/13 12:01:49:288 | [INFO] | | ASU | PIM | PIM | | | 6544 | PIMSqlite closeDB status 0
02/05/13 12:01:49:288 | [INFO] | | ASU | PIM | PIM | | | 6544 | FREE PIM Instance ...
02/05/13 12:01:49:288 | [INFO] | | ASU | PDApp | PDApp.AppletManager | | | 6544 | Registering Applets...
02/05/13 12:01:49:288 | [INFO] | | ASU | PDApp | PDApp | | | 6544 | DWA AppletID argument not specified on command line. Trying to find the existing instance
02/05/13 12:01:49:288 | [INFO] | | ASU | PDApp | PDApp | | | 6544 | This is the first instance so creating a thread for listening to the created pipe
02/05/13 12:01:49:288 | [INFO] | | ASU | PDApp | PipeThread | | | 6556 | Pipe thread started
02/05/13 12:01:49:288 | [INFO] | | ASU | PDApp | PDApp | | | 6544 | Starting AsyncMessageProcessor
02/05/13 12:01:49:288 | [INFO] | | ASU | PDApp | PDApp.AsyncMsgProcessor | | | 6544 | AsyncMsgProcessor initialized...
02/05/13 12:01:49:288 | [INFO] | | ASU | PDApp | PDApp.AsyncMsgProcessor | | | 6544 | AsyncMsgProcessor started. on thread id = 6564
02/05/13 12:01:49:288 | [INFO] | | ASU | PDApp | PDApp.WindowManager | | | 6544 | Initializing native WindowManager
02/05/13 12:01:49:288 | [INFO] | | ASU | PDApp | PDApp.WindowManager | | | 6544 | Creating window instance
02/05/13 12:01:49:288 | [INFO] | | ASU | PDApp | PDApp.WindowManager | | | 6544 | Checking for appletID and appletVersion given in CommandLineOptions
02/05/13 12:01:49:288 | [INFO] | | ASU | PDApp | PDApp.WindowManager | | | 6544 | Creating APE stage instance
02/05/13 12:01:50:349 | [INFO] | | ASU | PDApp | PDApp.ExternalGateway | | | 6544 | MessageHandler initialized...
02/05/13 12:01:50:349 | [INFO] | | ASU | PDApp | PDApp.ExternalGateway | | | 6544 | ExternalGateway initialized...
02/05/13 12:01:50:349 | [INFO] | | ASU | PDApp | PDApp.ExternalGateway | | | 6544 | NativeCommandHandler initialized...
02/05/13 12:01:50:365 | [INFO] | | ASU | PDApp | PDApp.StartupCommand | | | 6544 | Logging Level verbosity Set to INFO
02/05/13 12:01:50:365 | [INFO] | | ASU | PDApp | PDApp.StartupCommand | | | 6544 | Processing the startup Command
02/05/13 12:01:50:365 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Starting Applet registeration...
02/05/13 12:01:50:380 | [INFO] | | ASU | PDApp | PDAPP.MainDisplayMediator | | | 6544 | Looking up for the Exact versioned applet for ID :CCM_UI
02/05/13 12:01:50:380 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading Applet: CCM_UI Version = 1.0
02/05/13 12:01:50:396 | [INFO] | | ASU | PDApp | PDApp.ZStringLoader | | | 6544 | PDAPP SWF - locale set to - en_US
02/05/13 12:01:50:411 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 0 out of 1481767
02/05/13 12:01:50:411 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 65536 out of 1481767
02/05/13 12:01:50:411 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 131072 out of 1481767
02/05/13 12:01:50:411 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 196608 out of 1481767
02/05/13 12:01:50:411 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 262144 out of 1481767
02/05/13 12:01:50:411 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 327680 out of 1481767
02/05/13 12:01:50:427 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 393216 out of 1481767
02/05/13 12:01:50:427 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 458752 out of 1481767
02/05/13 12:01:50:427 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 524288 out of 1481767
02/05/13 12:01:50:427 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 589824 out of 1481767
02/05/13 12:01:50:427 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 655360 out of 1481767
02/05/13 12:01:50:427 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 720896 out of 1481767
02/05/13 12:01:50:427 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 786432 out of 1481767
02/05/13 12:01:50:427 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 851968 out of 1481767
02/05/13 12:01:50:427 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 917504 out of 1481767
02/05/13 12:01:50:443 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 983040 out of 1481767
02/05/13 12:01:50:443 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 1048576 out of 1481767
02/05/13 12:01:50:443 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 1114112 out of 1481767
02/05/13 12:01:50:443 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 1179648 out of 1481767
02/05/13 12:01:50:443 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 1245184 out of 1481767
02/05/13 12:01:50:443 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 1310720 out of 1481767
02/05/13 12:01:50:443 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 1376256 out of 1481767
02/05/13 12:01:50:443 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 1441792 out of 1481767
02/05/13 12:01:50:443 | [INFO] | | ASU | PDApp | PDAPP.AppletManager | | | 6544 | Loading progress 1481767 out of 1481767
02/05/13 12:01:50:864 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = ApplicationStartupCommand, type = null
02/05/13 12:01:50:864 | [INFO] | | ASU | PDApp | CCM.AppStartup | | | 6544 | Processing the application startup command
02/05/13 12:01:50:864 | [INFO] | | ASU | PDApp | PDApp.ExternalGateway | | | 6544 | Recieved Applet Loading Completion
02/05/13 12:01:50:864 | [INFO] | | ASU | PDApp | CCM.AppStartup | | | 6544 | DPI values are 96,96 and DPIType is set to 1
02/05/13 12:01:50:879 | [INFO] | | ASU | PDApp | com.adobe.aam.shared.view.mediator.compositeComponent.ScreenBasePopupWindowMediator | | | 6544 | onRegister
02/05/13 12:01:50:879 | [INFO] | | ASU | PDApp | CCM.AppStartup | | | 6544 | Going to start the workflow
02/05/13 12:01:50:879 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow, type = null
02/05/13 12:01:50:879 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow_manager, type = null
02/05/13 12:01:50:879 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = bootEXECUTE_CCM_WORKFLOW, type = null
02/05/13 12:01:50:879 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = initCCMNativeSignal, type = null
02/05/13 12:01:50:879 | [INFO] | | ASU | PDApp | CCM.InitializeCCMNativeCommand | | | 6544 | inside initial windows show
02/05/13 12:01:50:895 | [INFO] | | ASU | PDApp | PDApp.AppletManager | | | 6544 | Loading Applet - CCM_Native for WindowID - 1
02/05/13 12:01:50:911 | [INFO] | | ASU | PDApp | CCMNativeApplet | | | 6544 | startApplet
02/05/13 12:01:50:911 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow_manager, type = null
02/05/13 12:01:50:911 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = initZstringSignal, type = null
02/05/13 12:01:50:942 | [INFO] | | ASU | PDApp | ZStringLoader | | | 6544 | Trying to load ZString for preferred locale - en_US
02/05/13 12:01:50:942 | [INFO] | | ASU | PDApp | ZStringLoader | | | 6544 | Locale set to - en_US
02/05/13 12:01:50:942 | [INFO] | | ASU | PDApp | CCM.InitializeZstringCommand | | | 6544 | Font fallback applied is applicationFonts 'Lucida Grande, Segoe UI, Tahoma, _sans' inputControlFonts: 'Lucida Grande, Segoe UI, Tahoma, _sans'
02/05/13 12:01:50:957 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = zstringLoadCompleteSignal, type = null
02/05/13 12:01:50:957 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow, type = null
02/05/13 12:01:50:957 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow_manager, type = null
02/05/13 12:01:50:957 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = initAppletViewSignal, type = null
02/05/13 12:01:50:973 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = ShowScreen, type = null
02/05/13 12:01:50:973 | [INFO] | | ASU | PDApp | AAMShared.DynamicViewMediator | | | 6544 | Showing screen with screenID : com.adobe.aam.shared.view.compositeComponent::CCMMainView
02/05/13 12:01:51:067 | [INFO] | | ASU | PDApp | CCM.PrepareInitialAppletView | | | 6544 | Going to show the window now!!!
02/05/13 12:01:51:238 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = RegisterMediatorCommand, type = null
02/05/13 12:01:51:238 | [INFO] | | ASU | PDApp | com.adobe.aam.shared.view.mediator.compositeComponent.CCMMainViewMediator | | | 6544 | onRegister
02/05/13 12:01:51:238 | [INFO] | | ASU | PDApp | com.adobe.aam.shared.view.mediator.component.CCMMainContentMediator | | | 6544 | onRegister
02/05/13 12:01:51:238 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = CCM_CONTENT_REFRESH_DATA, type = null
02/05/13 12:01:51:238 | [INFO] | | ASU | PDApp | com.adobe.aam.shared.view.mediator.component.CCMMainContentMediator | | | 6544 | handleNotification : CCM_CONTENT_REFRESH_DATA
02/05/13 12:01:51:238 | [INFO] | | ASU | PDApp | com.adobe.aam.shared.view.mediator.component.CCMNavigationPanelMediator | | | 6544 | onRegister
02/05/13 12:01:51:238 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = CCM_NAVIGATION_PANEL_REFRESH_DATA, type = null
02/05/13 12:01:51:238 | [INFO] | | ASU | PDApp | com.adobe.aam.shared.view.mediator.component.CCMNavigationPanelMediator | | | 6544 | handleNotification : CCM_NAVIGATION_PANEL_REFRESH_DATA
02/05/13 12:01:51:238 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = ccmInitialViewCompleteSignal, type = null
02/05/13 12:01:51:238 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = CCM_MAIN_CONTENT_IS_BUSY, type = null
02/05/13 12:01:51:238 | [INFO] | | ASU | PDApp | com.adobe.aam.shared.view.mediator.component.CCMMainContentMediator | | | 6544 | handleNotification : CCM_MAIN_CONTENT_IS_BUSY
02/05/13 12:01:51:238 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow, type = null
02/05/13 12:01:51:238 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow_manager, type = null
02/05/13 12:01:51:238 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = preprocess_ccm_applet, type = null
02/05/13 12:01:51:254 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = populateSystemInfoDataSignal, type = null
02/05/13 12:01:51:254 | [INFO] | | ASU | PDApp | SystemUtilities | | | 6544 | Current system is a windows system
02/05/13 12:01:51:254 | [INFO] | | ASU | PDApp | SystemUtilities | | | 6544 | Current system is 64 bit
02/05/13 12:01:51:254 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = initNativeSessionsSignal, type = null
02/05/13 12:01:51:254 | [INFO] | | ASU | PDApp | CCMNativeApplet | | | 6544 | createSession
02/05/13 12:01:51:254 | [INFO] | | ASU | PDApp | CCMNativeApplet | | | 6544 | dlmAppletSessionProxy.sessionId = {76C89C44-B9B1-47A2-9A71-3CB13E3C36C5}
02/05/13 12:01:51:254 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = initGlobalUpdateSession, type = null
02/05/13 12:01:51:316 | [INFO] | | ASU | PDApp | CCMNativeApplet | | | 6544 | dlmAppletSessionProxy.sessionId = {5621E9AD-39EA-4686-B443-DA3AB4C158F6}
02/05/13 12:01:51:332 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow_manager, type = null
02/05/13 12:01:51:332 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = readGlobalPrefSignal, type = null
02/05/13 12:01:51:332 | [INFO] | | ASU | OPM | OPM | | | 6544 | Build Version - 7.0.0.237
02/05/13 12:01:51:332 | [INFO] | | ASU | OPM | OPM | | | 6544 | Logging Level verbosity Set to 4
02/05/13 12:01:51:332 | [INFO] | | ASU | OPM | OPM | | | 6544 | Schema version and schema compatibility version are same or greater than current
02/05/13 12:01:52:003 | [INFO] | | ASU | OPM | OPM | | | 6544 | Successfully opened opm session, db location:C:\Users\a01gassu\AppData\Local\Adobe\OOBE\opm.db in opm_createLibRef
02/05/13 12:01:52:003 | [INFO] | | ASU | OPM | OPM | | | 6544 | No Record found for the input fields in opm_getValueForKey
02/05/13 12:01:52:003 | [INFO] | | ASU | OPM | OPM | | | 6544 | Released OPM refrence successfully in opm_freeLibRef
02/05/13 12:01:52:003 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow_manager, type = null
02/05/13 12:01:52:003 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = readUpdatesPrefSignal, type = null
02/05/13 12:01:52:065 | [INFO] | | ASU | PDApp | PDApp.MessageQuequeManager | | | 6544 | Message Queue Manager initialized...
02/05/13 12:01:52:569 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:01:52:569 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = readUpdatesPrefResultSignal, type = null
02/05/13 12:01:52:569 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = GetUpdaterPreferencesCompleteSignal, type = null
02/05/13 12:01:52:569 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow, type = null
02/05/13 12:01:52:569 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow_manager, type = null
02/05/13 12:01:52:569 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = check_new_aam_version, type = null
02/05/13 12:01:52:579 | [INFO] | | ASU | OPM | Utilities | | | 6640 | File 'C:\Users\a01gassu\AppData\Local\Temp\{2C77F8A3-4149-4CB9-8AEF-CF29B6E39246}AAMVersion.xml' does not exist
02/05/13 12:01:52:579 | [INFO] | | ASU | OPM | Utilities | | | 6640 | File 'C:\Users\a01gassu\AppData\Local\Temp\{2C77F8A3-4149-4CB9-8AEF-CF29B6E39246}\AAMVersion.xml' does not exist
02/05/13 12:01:55:847 | [INFO] | | ASU | PIM | PIM | | | 6640 | Build Version - 7.0.0.233
02/05/13 12:01:55:847 | [INFO] | | ASU | PIM | PIM | | | 6640 | Logging Level verbosity Set to 4
02/05/13 12:01:55:847 | [INFO] | | ASU | PIM | PIM | | | 6640 | CREATE PIM Instance ...
02/05/13 12:01:55:847 | [INFO] | | ASU | PIM | Utilities | | | 6640 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\pim.db-journal' does not exist
02/05/13 12:01:55:847 | [INFO] | | ASU | PIM | PIM | | | 6640 | trying to createOrUpdatePIMDbSchema.
02/05/13 12:01:55:847 | [INFO] | | ASU | PIM | PIM | | | 6640 | Current db schema version on machine 1.
02/05/13 12:01:55:847 | [INFO] | | ASU | PIM | PIM | | | 6640 | Current db schema version to install 1.
02/05/13 12:01:55:847 | [INFO] | | ASU | PIM | PIM | | | 6640 | PIM DB Schema is up to date. Current schema version is 1.
02/05/13 12:01:55:847 | [INFO] | | ASU | PIM | PIM | | | 6640 | PIM Database is Up To Date.
02/05/13 12:01:55:847 | [INFO] | | ASU | PIM | PIM | | | 6640 | PIMSqlite closeDB status 0
02/05/13 12:01:55:847 | [INFO] | | ASU | PIM | PIM | | | 6640 | FREE PIM Instance ...
02/05/13 12:01:56:206 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:01:56:206 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = aamVersionCheckCompleteSignal, type = null
02/05/13 12:01:56:206 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow, type = null
02/05/13 12:01:56:206 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow_manager, type = null
02/05/13 12:01:56:206 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = parseInputXmlForDownloadRequestSignal, type = null
02/05/13 12:01:56:206 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = showAdobeLogInSignal, type = null
02/05/13 12:01:56:206 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = initProvCommonSignal, type = null
02/05/13 12:01:56:206 | [INFO] | | ASU | PDApp | PDApp.AppletManager | | | 6544 | Loading Applet - LWA_Native for WindowID - 1
02/05/13 12:01:56:237 | [INFO] | | ASU | LWANative | LWANative | | | Build Version - 7.0.0.124
02/05/13 12:01:56:237 | [INFO] | | ASU | LWANative | LWANative | | | Logging Level verbosity Set to 4
02/05/13 12:01:56:237 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = INIT_PROV_COMMON_NOTIFICATION, type = null
02/05/13 12:01:56:237 | [INFO] | | ASU | PDApp | ProvCommon.ZStringLoader | | | 6544 | Applet locale set to - en_US
02/05/13 12:01:56:237 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = FetchDefaultUserCommand, type = null
02/05/13 12:01:56:253 | [INFO] | | ASU | LWANative | LWANative | | | Performing openIMSLibSession...
02/05/13 12:01:56:253 | [INFO] | | ASU | LWANative | LWANative | | | pwa_openIMSLibSession Session key : {8DEAC40A-3487-4680-A7A9-3F9EECF19730}
02/05/13 12:01:56:268 | [INFO] | | ASU | IMSLib | IMSLib | | | Build Version - 7.0.0.11
02/05/13 12:01:56:268 | [INFO] | | ASU | IMSLib | IMSLib | | | Logging Level verbosity Set to 4
02/05/13 12:01:56:268 | [INFO] | | ASU | IMSLib | IMSLib | | | Creating IMSLib instance ...
02/05/13 12:01:56:268 | [INFO] | | ASU | OPM | OPM | | | Build Version - 7.0.0.11
02/05/13 12:01:56:268 | [INFO] | | ASU | OPM | OPM | | | Logging Level verbosity Set to 4
02/05/13 12:01:56:268 | [INFO] | | ASU | OPM | OPM | | | Schema version and schema compatibility version are same or greater than current
02/05/13 12:01:56:487 | [INFO] | | ASU | OPM | OPM | | | Successfully opened opm session, db location:C:\Users\a01gassu\AppData\Local\Adobe\OOBE\opm.db in opm_createLibRef
02/05/13 12:01:56:487 | [INFO] | | ASU | OPM | OPM | | | No Record found for the input fields in opm_getValueForKey
02/05/13 12:01:56:487 | [INFO] | | ASU | OPM | IMSLib_OPMWrapper | | | Failed in getting value for key in OPMGetValueForKey domain:OOBE subDomain:ProxyCredentials key:ProxyUsername
02/05/13 12:01:56:487 | [INFO] | | ASU | OPM | IMSLibHelper | | | Failed to get proxy user name from local db in getProxyCredentialsFromLocalStore
02/05/13 12:01:56:487 | [INFO] | | ASU | OPM | OPM | | | Released OPM refrence successfully in opm_freeLibRef
02/05/13 12:01:56:487 | [INFO] | | ASU | OPM | IMSLib | | | Failed get proxy credentials from local store while creating IMSLib instance ...
02/05/13 12:01:56:487 | [INFO] | | ASU | PDApp | ProvisioningNativeAppletBase | | | 6544 | Done opening IMSSession, session key - {8DEAC40A-3487-4680-A7A9-3F9EECF19730}
02/05/13 12:01:56:487 | [INFO] | | ASU | PDApp | ProvisioningNativeAppletBase | | | 6544 | Fetching default user profile for requested ClientID...
02/05/13 12:01:56:487 | [INFO] | | ASU | LWANative | LWANative | | | Performing fetch default user for clientID...
02/05/13 12:01:56:487 | [INFO] | | ASU | OPM | IMSLib | | | Performing fetchDefaultUserInfoForClientId...
02/05/13 12:01:56:487 | [INFO] | | ASU | OPM | OPM | | | Build Version - 7.0.0.11
02/05/13 12:01:56:487 | [INFO] | | ASU | OPM | OPM | | | Logging Level verbosity Set to 4
02/05/13 12:01:56:487 | [INFO] | | ASU | OPM | OPM | | | Schema version and schema compatibility version are same or greater than current
02/05/13 12:01:56:689 | [INFO] | | ASU | OPM | OPM | | | Successfully opened opm session, db location:C:\Users\a01gassu\AppData\Local\Adobe\OOBE\opm.db in opm_createLibRef
02/05/13 12:01:57:937 | [INFO] | | ASU | OPM | OPM | | | returning size of value as:33 in opm_getValueForKey
02/05/13 12:01:57:937 | [INFO] | | ASU | OPM | OPM | | | Successfully retreived value from opm domain:IMSLib subdomain:CSServiceMap key:426eb9f9-9989-45dd-8b7c-1bcdc957c8e5 in opm_getValueForKey
02/05/13 12:01:57:937 | [INFO] | | ASU | OPM | OPM | | | Released OPM refrence successfully in opm_freeLibRef
02/05/13 12:01:57:937 | [INFO] | | ASU | OPM | OPM | | | Build Version - 7.0.0.11
02/05/13 12:01:57:937 | [INFO] | | ASU | OPM | OPM | | | Logging Level verbosity Set to 4
02/05/13 12:01:57:937 | [INFO] | | ASU | OPM | OPM | | | Schema version and schema compatibility version are same or greater than current
02/05/13 12:01:58:421 | [INFO] | | ASU | OPM | OPM | | | Successfully opened opm session, db location:C:\Users\a01gassu\AppData\Local\Adobe\OOBE\opm.db in opm_createLibRef
02/05/13 12:01:58:421 | [INFO] | | ASU | OPM | OPM | | | returning size of value as:1166 in opm_getValueForKey
02/05/13 12:01:58:421 | [INFO] | | ASU | OPM | OPM | | | Successfully retreived value from opm domain:IMSLib subdomain:SignInUsers key:e58f52b002e54a2b37e40e58b8e8a057 in opm_getValueForKey
02/05/13 12:01:58:421 | [INFO] | | ASU | OPM | OPM | | | Released OPM refrence successfully in opm_freeLibRef
02/05/13 12:01:58:421 | [INFO] | | ASU | OPM | IMSLib | | | Performing releaseData...
02/05/13 12:01:58:421 | [INFO] | | ASU | PDApp | ProvisioningNativeAppletBase | | | 6544 | Retrieved default user profile successfully
02/05/13 12:01:58:421 | [INFO] | | ASU | PDApp | ProvisioningNativeAppletBase | | | 6544 | Closing IMSSession: {8DEAC40A-3487-4680-A7A9-3F9EECF19730}
02/05/13 12:01:58:421 | [INFO] | | ASU | LWANative | LWANative | | | Performing closeIMSLibSession...
02/05/13 12:01:58:421 | [INFO] | | ASU | OPM | IMSLib | | | Releasing IMSLib instance ...
02/05/13 12:01:58:421 | [INFO] | | ASU | PDApp | ProvisioningNativeAppletBase | | | 6544 | Done closing IMSSession: {8DEAC40A-3487-4680-A7A9-3F9EECF19730}
02/05/13 12:01:58:421 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = FetchAccessTokenCommand, type = null
02/05/13 12:01:58:421 | [INFO] | | ASU | PDApp | CCM.FetchAccessTokenCommand | | | 6544 | Fetching access token for the requested user...
02/05/13 12:01:58:421 | [INFO] | | ASU | LWANative | LWANative | | | Performing openIMSLibSession...
02/05/13 12:01:58:421 | [INFO] | | ASU | LWANative | LWANative | | | pwa_openIMSLibSession Session key : {BD969FC5-445B-49A9-AEF9-ECA298FC59E2}
02/05/13 12:01:58:421 | [INFO] | | ASU | IMSLib | IMSLib | | | Build Version - 7.0.0.11
02/05/13 12:01:58:421 | [INFO] | | ASU | IMSLib | IMSLib | | | Logging Level verbosity Set to 4
02/05/13 12:01:58:421 | [INFO] | | ASU | IMSLib | IMSLib | | | Creating IMSLib instance ...
02/05/13 12:01:58:437 | [INFO] | | ASU | OPM | OPM | | | Build Version - 7.0.0.11
02/05/13 12:01:58:437 | [INFO] | | ASU | OPM | OPM | | | Logging Level verbosity Set to 4
02/05/13 12:01:58:437 | [INFO] | | ASU | OPM | OPM | | | Schema version and schema compatibility version are same or greater than current
02/05/13 12:01:58:640 | [INFO] | | ASU | OPM | OPM | | | Successfully opened opm session, db location:C:\Users\a01gassu\AppData\Local\Adobe\OOBE\opm.db in opm_createLibRef
02/05/13 12:01:58:640 | [INFO] | | ASU | OPM | OPM | | | No Record found for the input fields in opm_getValueForKey
02/05/13 12:01:58:640 | [INFO] | | ASU | OPM | IMSLib_OPMWrapper | | | Failed in getting value for key in OPMGetValueForKey domain:OOBE subDomain:ProxyCredentials key:ProxyUsername
02/05/13 12:01:58:640 | [INFO] | | ASU | OPM | IMSLibHelper | | | Failed to get proxy user name from local db in getProxyCredentialsFromLocalStore
02/05/13 12:01:58:640 | [INFO] | | ASU | OPM | OPM | | | Released OPM refrence successfully in opm_freeLibRef
02/05/13 12:01:58:640 | [INFO] | | ASU | OPM | IMSLib | | | Failed get proxy credentials from local store while creating IMSLib instance ...
02/05/13 12:01:58:640 | [INFO] | | ASU | PDApp | ProvisioningNativeAppletBase | | | 6544 | Done opening IMSSession, session key - {BD969FC5-445B-49A9-AEF9-ECA298FC59E2}
02/05/13 12:01:58:640 | [INFO] | | ASU | PDApp | ProvisioningNativeAppletBase | | | 6544 | Performing fetchAccessToken...
02/05/13 12:01:58:640 | [INFO] | | ASU | LWANative | LWANative | | | Performing fetch Access token for user...
02/05/13 12:01:58:640 | [INFO] | | ASU | OPM | IMSLib | | | Performing fetch accessToken...
02/05/13 12:01:58:655 | [INFO] | | ASU | OPM | IMSLib | | | Using environment:ims-na1.adobelogin.com
02/05/13 12:01:58:655 | [INFO] | | ASU | OPM | OPM | | | Build Version - 7.0.0.11
02/05/13 12:01:58:655 | [INFO] | | ASU | OPM | OPM | | | Logging Level verbosity Set to 4
02/05/13 12:01:58:655 | [INFO] | | ASU | OPM | OPM | | | Schema version and schema compatibility version are same or greater than current
02/05/13 12:01:58:796 | [INFO] | | ASU | OPM | OPM | | | Successfully opened opm session, db location:C:\Users\a01gassu\AppData\Local\Adobe\OOBE\opm.db in opm_createLibRef
02/05/13 12:01:58:796 | [INFO] | | ASU | OPM | OPM | | | returning size of value as:1166 in opm_getValueForKey
02/05/13 12:01:58:796 | [INFO] | | ASU | OPM | OPM | | | Successfully retreived value from opm domain:IMSLib subdomain:SignInUsers key:e58f52b002e54a2b37e40e58b8e8a057 in opm_getValueForKey
02/05/13 12:01:58:796 | [INFO] | | ASU | OPM | OPM | | | returning size of value as:65 in opm_getValueForKey
02/05/13 12:01:58:796 | [INFO] | | ASU | OPM | OPM | | | Successfully retreived value from opm domain:IMSLib subdomain:Default key:deviceID in opm_getValueForKey
02/05/13 12:01:58:796 | [INFO] | | ASU | OPM | OPM | | | Released OPM refrence successfully in opm_freeLibRef
02/05/13 12:01:58:796 | [INFO] | | ASU | OPM | IMSLibHelper | | | setting authproxy credentials in fetchAccessTokenForDeviceToken
02/05/13 12:01:58:796 | [INFO] | | ASU | OPM | OPM | | | Build Version - 7.0.0.11
02/05/13 12:01:58:796 | [INFO] | | ASU | OPM | OPM | | | Logging Level verbosity Set to 4
02/05/13 12:01:58:796 | [INFO] | | ASU | OPM | OPM | | | Schema version and schema compatibility version are same or greater than current
02/05/13 12:01:59:026 | [INFO] | | ASU | OPM | OPM | | | Successfully opened opm session, db location:C:\Users\a01gassu\AppData\Local\Adobe\OOBE\opm.db in opm_createLibRef
02/05/13 12:01:59:026 | [INFO] | | ASU | OPM | OPM | | | No Record found for the input fields in opm_getValueForKey
02/05/13 12:01:59:026 | [INFO] | | ASU | OPM | IMSLib_OPMWrapper | | | Failed in getting value for key in OPMGetValueForKey domain:OOBE subDomain:ProxyCredentials key:ProxyUsername
02/05/13 12:01:59:026 | [INFO] | | ASU | OPM | IMSLibHelper | | | Failed to get proxy user name from local db in getProxyCredentialsFromLocalStore
02/05/13 12:01:59:026 | [INFO] | | ASU | OPM | OPM | | | Released OPM refrence successfully in opm_freeLibRef
02/05/13 12:01:59:026 | [INFO] | | ASU | OPM | IMSLibHelper | | | Failed to get proxyCredentials from local store in setProxyCredentialsForHTTPRequest
02/05/13 12:01:59:026 | [INFO] | | ASU | OPM | IMSLibHelper | | | Failed in setting authproxy credentials in fetchAccessTokenForDeviceToken
02/05/13 12:01:59:036 | [INFO] | | ASU | OPM | HTTPConnector | | | GetIEProxyInfo - No default proxy present on the user machine
02/05/13 12:02:01:308 | [INFO] | | ASU | OPM | HTTPConnector | | | GetIEProxyInfo - Failed to get proxy for the url, error:12180
02/05/13 12:02:01:308 | [INFO] | | ASU | OPM | HTTPConnector | | | GetIEProxyInfo - proxy Url is
02/05/13 12:02:01:698 | [INFO] | | ASU | OPM | HTTPConnector | | | WINHTTP_CALLBACK_STATUS_HEADERS_AVAILABLE...
02/05/13 12:02:01:698 | [INFO] | | ASU | OPM | HTTPConnector | | | HTTP Request Status code 200.
02/05/13 12:02:01:698 | [INFO] | | ASU | OPM | HTTPConnector | | | The http request returned response code:0
02/05/13 12:02:01:698 | [INFO] | | ASU | OPM | IMSLibHelper | | | user has not selected 'Remember Me', proxy data is not saved in local store
02/05/13 12:02:01:698 | [INFO] | | ASU | OPM | OPM | | | Build Version - 7.0.0.11
02/05/13 12:02:01:698 | [INFO] | | ASU | OPM | OPM | | | Logging Level verbosity Set to 4
02/05/13 12:02:01:698 | [INFO] | | ASU | OPM | OPM | | | Schema version and schema compatibility version are same or greater than current
02/05/13 12:02:02:447 | [INFO] | | ASU | OPM | OPM | | | Successfully opened opm session, db location:C:\Users\a01gassu\AppData\Local\Adobe\OOBE\opm.db in opm_createLibRef
02/05/13 12:02:02:447 | [INFO] | | ASU | OPM | OPM | | | returning size of value as:1166 in opm_getValueForKey
02/05/13 12:02:02:447 | [INFO] | | ASU | OPM | OPM | | | Successfully retreived value from opm domain:IMSLib subdomain:SignInUsers key:e58f52b002e54a2b37e40e58b8e8a057 in opm_getValueForKey
02/05/13 12:02:02:525 | [INFO] | | ASU | OPM | OPM | | | Successfully updated opm.db for fields domain:IMSLib subdomain:SignInUsers key:e58f52b002e54a2b37e40e58b8e8a057 in opm_setValueForKey
02/05/13 12:02:02:525 | [INFO] | | ASU | OPM | OPM | | | Released OPM refrence successfully in opm_freeLibRef
02/05/13 12:02:02:525 | [INFO] | | ASU | OPM | OPM | | | Build Version - 7.0.0.11
02/05/13 12:02:02:525 | [INFO] | | ASU | OPM | OPM | | | Logging Level verbosity Set to 4
02/05/13 12:02:02:525 | [INFO] | | ASU | OPM | OPM | | | Schema version and schema compatibility version are same or greater than current
02/05/13 12:02:02:650 | [INFO] | | ASU | OPM | OPM | | | Successfully opened opm session, db location:C:\Users\a01gassu\AppData\Local\Adobe\OOBE\opm.db in opm_createLibRef
02/05/13 12:02:02:728 | [INFO] | | ASU | OPM | OPM | | | Successfully updated opm.db for fields domain:IMSLib subdomain:CSServiceMap key:426eb9f9-9989-45dd-8b7c-1bcdc957c8e5 in opm_setValueForKey
02/05/13 12:02:02:728 | [INFO] | | ASU | OPM | OPM | | | Released OPM refrence successfully in opm_freeLibRef
02/05/13 12:02:02:728 | [INFO] | | ASU | OPM | OPM | | | Build Version - 7.0.0.11
02/05/13 12:02:02:728 | [INFO] | | ASU | OPM | OPM | | | Logging Level verbosity Set to 4
02/05/13 12:02:02:728 | [INFO] | | ASU | OPM | OPM | | | Schema version and schema compatibility version are same or greater than current
02/05/13 12:02:03:086 | [INFO] | | ASU | OPM | OPM | | | Successfully opened opm session, db location:C:\Users\a01gassu\AppData\Local\Adobe\OOBE\opm.db in opm_createLibRef
02/05/13 12:02:03:445 | [INFO] | | ASU | OPM | OPM | | | Successfully updated opm.db for fields domain:IMSLib subdomain:Default key:deviceID in opm_setValueForKey
02/05/13 12:02:03:445 | [INFO] | | ASU | OPM | OPM | | | Released OPM refrence successfully in opm_freeLibRef
02/05/13 12:02:03:445 | [INFO] | | ASU | OPM | IMSLib | | | Invoking client callback function with response and status : 0
02/05/13 12:02:03:445 | [INFO] | | ASU | LWANative | LWANative | | | Proceeding with fetchAccessToken callback...
02/05/13 12:02:03:492 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = FetchAccessTokenStatusCommand, type = null
02/05/13 12:02:03:492 | [INFO] | | ASU | PDApp | CCM.FetchAccessTokenCommand | | | 6544 | Received FetchAccessToken response with status : success
02/05/13 12:02:03:492 | [INFO] | | ASU | PDApp | CCM.FetchAccessTokenCommand | | | 6544 | AccessToken generated successfully.
02/05/13 12:02:03:492 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = ADOBEID_SIGNIN_ACCESSTOKEN_RESPONSE, type = null
02/05/13 12:02:03:492 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = adobeLogInDoneSignal, type = null
02/05/13 12:02:03:492 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = sendAnalyticsSignal, type = null
02/05/13 12:02:03:508 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = adobeLogInCompleteSignal, type = null
02/05/13 12:02:03:508 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow, type = null
02/05/13 12:02:03:508 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow_manager, type = null
02/05/13 12:02:03:508 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = showPostAdobeIdScreenSignal, type = null
02/05/13 12:02:03:508 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = CCM_MAIN_CONTENT_IS_BUSY, type = null
02/05/13 12:02:03:508 | [INFO] | | ASU | PDApp | com.adobe.aam.shared.view.mediator.component.CCMMainContentMediator | | | 6544 | handleNotification : CCM_MAIN_CONTENT_IS_BUSY
02/05/13 12:02:03:508 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = CCM_NAVIGATION_PANEL_REFRESH_DATA, type = null
02/05/13 12:02:03:508 | [INFO] | | ASU | PDApp | com.adobe.aam.shared.view.mediator.component.CCMNavigationPanelMediator | | | 6544 | handleNotification : CCM_NAVIGATION_PANEL_REFRESH_DATA
02/05/13 12:02:03:508 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = loadUserPrefSignal, type = null
02/05/13 12:02:03:508 | [INFO] | | ASU | OPM | OPM | | | 6544 | Build Version - 7.0.0.237
02/05/13 12:02:03:508 | [INFO] | | ASU | OPM | OPM | | | 6544 | Logging Level verbosity Set to 4
02/05/13 12:02:03:508 | [INFO] | | ASU | OPM | OPM | | | 6544 | Schema version and schema compatibility version are same or greater than current
02/05/13 12:02:03:679 | [INFO] | | ASU | OPM | OPM | | | 6544 | Successfully opened opm session, db location:C:\Users\a01gassu\AppData\Local\Adobe\OOBE\opm.db in opm_createLibRef
02/05/13 12:02:05:255 | [INFO] | | ASU | OPM | OPM | | | 6544 | returning size of value as:339 in opm_getValueForKey
02/05/13 12:02:05:255 | [INFO] | | ASU | OPM | OPM | | | 6544 | Successfully retreived value from opm domain:OOBE subdomain:CCM_Pref key:1b8ec8539d00c8de37ed1903f379b493 in opm_getValueForKey
02/05/13 12:02:05:255 | [INFO] | | ASU | OPM | OPM | | | 6544 | Released OPM refrence successfully in opm_freeLibRef
02/05/13 12:02:05:255 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow_manager, type = null
02/05/13 12:02:05:255 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = prefetchProductsIcons, type = null
02/05/13 12:02:05:271 | [INFO] | | ASU | OPM | Utilities | | | 6688 | File 'C:\Users\a01gassu\AppData\Local\Temp\{2C77F8A3-4149-4CB9-8AEF-CF29B6E39246}\{9AC7DB7C-67B4-4AC4-BD10-97E94251ED00}.xml' does not exist
02/05/13 12:02:05:832 | [INFO] | | ASU | PDApp | CCM.ETSCommunicator | | | 6544 | Response: SUCCESS
02/05/13 12:02:09:498 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:02:09:498 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = IconsPrefetchResult, type = null
02/05/13 12:02:09:529 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = productsIconsFetchedSignal, type = null
02/05/13 12:02:09:529 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow, type = null
02/05/13 12:02:09:529 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow_manager, type = null
02/05/13 12:02:09:529 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = fetchAvailableUpdatesSignal, type = null
2/5/2013 12:02:10 [INFO] OPM - Build Version - 6.0.281.0
2/5/2013 12:02:10 [INFO] OPM - Logging Level verbosity Set to 4
2/5/2013 12:02:10 [INFO] OPM - Schema version and schema compatibility version are same or greater than current
2/5/2013 12:02:10 [INFO] OPM - No Record found for the input fields
2/5/2013 12:02:10 [INFO] OPM - Released OPM refrence successfully
2/5/2013 12:02:11 [INFO] OPM - Build Version - 6.0.281.0
2/5/2013 12:02:11 [INFO] OPM - Logging Level verbosity Set to 4
2/5/2013 12:02:11 [INFO] OPM - Schema version and schema compatibility version are same or greater than current
2/5/2013 12:02:11 [INFO] OPM - No Record found for the input fields
2/5/2013 12:02:11 [INFO] OPM - Released OPM refrence successfully
2/5/2013 12:02:12 [INFO] OPM - No Record found for the input fields
2/5/2013 12:02:12 [INFO] OPM - Released OPM refrence successfully
2/5/2013 12:02:12 [INFO] OPM - Build Version - 6.0.281.0
2/5/2013 12:02:12 [INFO] OPM - Logging Level verbosity Set to 4
2/5/2013 12:02:12 [INFO] OPM - Schema version and schema compatibility version are same or greater than current
2/5/2013 12:02:13 [INFO] OPM - Build Version - 6.0.281.0
2/5/2013 12:02:13 [INFO] OPM - Logging Level verbosity Set to 4
2/5/2013 12:02:13 [INFO] OPM - Schema version and schema compatibility version are same or greater than current
2/5/2013 12:02:13 [INFO] OPM - No Record found for the input fields
2/5/2013 12:02:13 [INFO] OPM - Released OPM refrence successfully
2/5/2013 12:02:14 [INFO] OPM - Build Version - 6.0.281.0
2/5/2013 12:02:14 [INFO] OPM - Logging Level verbosity Set to 4
2/5/2013 12:02:14 [INFO] OPM - Schema version and schema compatibility version are same or greater than current
2/5/2013 12:02:14 [INFO] OPM - No Record found for the input fields
2/5/2013 12:02:14 [INFO] OPM - Released OPM refrence successfully
2/5/2013 12:02:15 [INFO] OPM - Build Version - 6.0.281.0
2/5/2013 12:02:15 [INFO] OPM - Logging Level verbosity Set to 4
2/5/2013 12:02:15 [INFO] OPM - Schema version and schema compatibility version are same or greater than current
2/5/2013 12:02:15 [INFO] OPM - No Record found for the input fields
2/5/2013 12:02:15 [INFO] OPM - Released OPM refrence successfully
2/5/2013 12:02:15 [INFO] OPM - Build Version - 7.0.0.45
2/5/2013 12:02:15 [INFO] OPM - Successfully opened opm session, db location:C:\Users\a01gassu\AppData\Local\Adobe\OOBE\opm.db in opm_createLibRef
2/5/2013 12:02:15 [INFO] OPM - No Record found for the input fields in opm_getValueForKey
2/5/2013 12:02:16 [INFO] OPM - Build Version - 6.0.281.0
2/5/2013 12:02:16 [INFO] OPM - Logging Level verbosity Set to 4
2/5/2013 12:02:16 [INFO] OPM - Schema version and schema compatibility version are same or greater than current
2/5/2013 12:02:16 [INFO] OPM - No Record found for the input fields
2/5/2013 12:02:16 [INFO] OPM - Released OPM refrence successfully
02/05/13 12:02:17:502 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:02:17:502 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = UpdatesFetchResultSignal, type = null
02/05/13 12:02:17:502 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = availableUpdatesInfoFetchedSignal, type = null
02/05/13 12:02:17:507 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow, type = null
02/05/13 12:02:17:507 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow_manager, type = null
02/05/13 12:02:17:507 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = parseAvailableUpdatesSignal, type = null
02/05/13 12:02:17:507 | [WARN] | | ASU | PDApp | UpdateInfo | | | 6544 | Update has WaitingForProductEvent attribute set in tracker xml. Quitting processing of this update.
02/05/13 12:02:18:223 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow_manager, type = null
02/05/13 12:02:18:223 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = fetchAvailableProducts, type = null
02/05/13 12:02:18:228 | [INFO] | | ASU | OPM | Utilities | | | 6752 | File 'C:\Users\a01gassu\AppData\Local\Temp\{2C77F8A3-4149-4CB9-8AEF-CF29B6E39246}\CD75F1CF-5AD2-D0CB-AF29-AB85CCF442E8' does not exist
02/05/13 12:02:22:838 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:02:22:839 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = availableProductsInfoFetchedSignal, type = null
02/05/13 12:02:22:839 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = parseAvailableProducts, type = null
02/05/13 12:02:22:846 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for Adobe Premiere Pro CS6 Family - win32
02/05/13 12:02:22:850 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for Flash Professional CS6 and Mobile Device Packaging - win32
02/05/13 12:02:22:851 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for After Effects CS6 - win64
02/05/13 12:02:22:852 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for Audition CS6 - win32
02/05/13 12:02:22:853 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for Illustrator CS6 - win32
02/05/13 12:02:22:854 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for SpeedGrade CS6 - win64
02/05/13 12:02:22:854 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for Prelude CS6 - win32
02/05/13 12:02:22:855 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for Touch App Plugins - win32
02/05/13 12:02:22:856 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for Dreamweaver CS6 - win32
02/05/13 12:02:22:857 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for Adobe Acrobat XI Pro - win32
02/05/13 12:02:22:858 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for Edge Animate - win32
02/05/13 12:02:22:859 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for Creative Cloud Connection - win32
02/05/13 12:02:22:860 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for Flash Builder and Mobile Device Packaging - win64
02/05/13 12:02:22:860 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for Fireworks CS6 - win32
02/05/13 12:02:22:861 | [WARN] | | ASU | PDApp | ProductArray | | | 6544 | Current product is AAM. So, skipping it - Adobe Application Manager
02/05/13 12:02:22:862 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for Muse - win32
02/05/13 12:02:22:863 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for Lightroom 4.3 - win32
02/05/13 12:02:22:863 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for Photoshop CS6 - win32
02/05/13 12:02:22:865 | [INFO] | | ASU | PDApp | ProductArray | | | 6544 | Highest applicable platform for InDesign CS6 - win32
02/05/13 12:02:22:866 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = productsInfoParsedSignal, type = null
02/05/13 12:02:22:866 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow, type = null
02/05/13 12:02:22:866 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow_manager, type = null
02/05/13 12:02:22:867 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveAllProductsInstallLanguageSignal, type = null
02/05/13 12:02:22:868 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:22:883 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:22:893 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:22:902 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:22:911 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:22:938 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:22:947 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:22:956 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:22:982 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:22:990 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:016 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:025 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:034 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:043 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:069 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:095 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:104 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:113 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:121 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveStandAlondUpdatesSignal, type = null
02/05/13 12:02:23:123 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow_manager, type = null
02/05/13 12:02:23:124 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveAndRefershAllProductsSignal, type = null
02/05/13 12:02:23:124 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveAllProductsInstallLanguageSignal, type = null
02/05/13 12:02:23:125 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:134 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:143 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:151 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:160 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:186 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:195 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:204 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:229 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:238 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:264 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:273 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:281 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:290 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:316 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:341 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:350 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:359 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveInstallLanguageSignal, type = null
02/05/13 12:02:23:367 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = resolveStandAlondUpdatesSignal, type = null
02/05/13 12:02:23:368 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = refreshMainScreenSignal, type = null
02/05/13 12:02:23:369 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = refreshNavigationPanelSignal, type = null
02/05/13 12:02:23:373 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = CCM_NAVIGATION_PANEL_MARK_SELECTED, type = null
02/05/13 12:02:23:374 | [INFO] | | ASU | PDApp | com.adobe.aam.shared.view.mediator.component.CCMNavigationPanelMediator | | | 6544 | handleNotification : CCM_NAVIGATION_PANEL_MARK_SELECTED
02/05/13 12:02:23:375 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = showAvailableProducts, type = null
02/05/13 12:02:23:379 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = CCM_MAIN_CONTENT_IS_BUSY, type = null
02/05/13 12:02:23:379 | [INFO] | | ASU | PDApp | com.adobe.aam.shared.view.mediator.component.CCMMainContentMediator | | | 6544 | handleNotification : CCM_MAIN_CONTENT_IS_BUSY
02/05/13 12:02:23:380 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = CCM_CONTENT_REFRESH_DATA, type = null
02/05/13 12:02:23:380 | [INFO] | | ASU | PDApp | com.adobe.aam.shared.view.mediator.component.CCMMainContentMediator | | | 6544 | handleNotification : CCM_CONTENT_REFRESH_DATA
02/05/13 12:02:23:381 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = setUserMenuenableStateSignal, type = null
02/05/13 12:02:23:382 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = execute_ccm_workflow_manager, type = null
02/05/13 12:02:23:383 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = setViewedUpdatesSignal, type = null
02/05/13 12:02:25:637 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = processInputDownloadRequests, type = null
02/05/13 12:02:28:588 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = productInstalledClickSignal, type = null
02/05/13 12:02:28:589 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = initCCMDownloadWorkflowSignal, type = null
02/05/13 12:02:28:592 | [INFO] | | ASU | PDApp | CCMNativeApplet | | | 6544 | createSession
02/05/13 12:02:28:612 | [INFO] | | ASU | PDApp | CCMNativeApplet | | | 6544 | dlmAppletSessionProxy.sessionId = {5BF940BF-ADC7-4324-A93C-DA3E06115241}
02/05/13 12:02:28:612 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = sessionStartSignal, type = null
02/05/13 12:02:28:613 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = validateCCMDownloadWorkflowSignal, type = null
02/05/13 12:02:28:615 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeCCMDownloadWorkflowSignal, type = null
02/05/13 12:02:28:619 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeProdSessWorkflow, type = null
02/05/13 12:02:28:622 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = acquireAdminElevationSignal, type = null
02/05/13 12:02:28:854 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeCCMDownloadWorkflowSignal, type = null
02/05/13 12:02:28:856 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = addProductInDownloadQueue, type = null
02/05/13 12:02:28:857 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeCCMDownloadWorkflowSignal, type = null
02/05/13 12:02:28:858 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = sendAnalyticsSignal, type = null
02/05/13 12:02:28:859 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeProdSessWorkflow, type = null
02/05/13 12:02:28:860 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = prepareDownloadSignal, type = null
02/05/13 12:02:28:876 | [INFO] | | ASU | OPM | Utilities | | | 6872 | File 'C:\Users\a01gassu\AppData\Local\Temp\{C1914916-E99E-4597-9EDE-9EC6998284D7}\manifest.xml' does not exist
02/05/13 12:02:29:080 | [INFO] | | ASU | PDApp | CCM.ETSCommunicator | | | 6544 | Response: SUCCESS
02/05/13 12:02:31:464 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:02:31:465 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:02:31:466 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMDownloadWorkflowSignal, type = null
02/05/13 12:02:31:468 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = downloadPreparedSignal, type = null
02/05/13 12:02:31:469 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeProdSessWorkflow, type = null
02/05/13 12:02:31:469 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = startDownloadSignal, type = null
02/05/13 12:02:31:974 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:02:31:975 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:02:31:975 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMDownloadWorkflowSignal, type = null
02/05/13 12:02:31:976 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = downloadProgressSignal, type = null
02/05/13 12:02:31:977 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = downloadCompleteSignal, type = null
02/05/13 12:02:31:978 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeProdSessWorkflow, type = null
02/05/13 12:02:31:978 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = manifestParseSignal, type = null
02/05/13 12:02:31:982 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeProdSessWorkflow, type = null
02/05/13 12:02:31:982 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = prepareDownloadSignal, type = null
02/05/13 12:02:31:986 | [INFO] | | ASU | OPM | Utilities | | | 6908 | File 'C:\Users\a01gassu\AppData\Local\Temp\{C1914916-E99E-4597-9EDE-9EC6998284D7}\validation.xml' does not exist
02/05/13 12:02:34:551 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:02:34:551 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:02:34:551 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMDownloadWorkflowSignal, type = null
02/05/13 12:02:34:551 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = downloadPreparedSignal, type = null
02/05/13 12:02:34:554 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeProdSessWorkflow, type = null
02/05/13 12:02:34:554 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = startDownloadSignal, type = null
02/05/13 12:02:35:089 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:02:35:090 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:02:35:090 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMDownloadWorkflowSignal, type = null
02/05/13 12:02:35:090 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = downloadProgressSignal, type = null
02/05/13 12:02:35:091 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = downloadCompleteSignal, type = null
02/05/13 12:02:35:091 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeProdSessWorkflow, type = null
02/05/13 12:02:35:091 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = validationParseSignal, type = null
02/05/13 12:02:35:094 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeProdSessWorkflow, type = null
02/05/13 12:02:35:094 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = prepareDownloadSignal, type = null
02/05/13 12:02:35:100 | [INFO] | | ASU | OPM | Utilities | | | 6928 | File 'C:\Users\a01gassu\AppData\Local\Temp\{C1914916-E99E-4597-9EDE-9EC6998284D7}\Edge_Animate_1_0_1_CCM_LS17.exe' does not exist
02/05/13 12:02:37:634 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:02:37:634 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:02:37:634 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMDownloadWorkflowSignal, type = null
02/05/13 12:02:37:634 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = downloadPreparedSignal, type = null
02/05/13 12:02:37:636 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeProdSessWorkflow, type = null
02/05/13 12:02:37:636 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = startDownloadSignal, type = null
02/05/13 12:02:43:213 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:02:43:214 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:02:43:214 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMDownloadWorkflowSignal, type = null
02/05/13 12:02:43:215 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = downloadProgressSignal, type = null
02/05/13 12:02:50:577 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:02:50:577 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:02:50:577 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMDownloadWorkflowSignal, type = null
02/05/13 12:02:50:577 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = downloadProgressSignal, type = null
02/05/13 12:02:56:297 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:02:56:298 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:02:56:298 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMDownloadWorkflowSignal, type = null
02/05/13 12:02:56:299 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = downloadProgressSignal, type = null
02/05/13 12:03:03:010 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:03:03:010 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:03:03:010 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMDownloadWorkflowSignal, type = null
02/05/13 12:03:03:010 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = downloadProgressSignal, type = null
02/05/13 12:03:10:577 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:03:10:577 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:03:10:577 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMDownloadWorkflowSignal, type = null
02/05/13 12:03:10:577 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = downloadProgressSignal, type = null
02/05/13 12:03:17:331 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:03:17:331 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:03:17:331 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMDownloadWorkflowSignal, type = null
02/05/13 12:03:17:331 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = productSessionDownloadErrorSignal, type = null
02/05/13 12:03:17:331 | [WARN] | | ASU | PDApp | DownloadErrorVo | | | 6544 | Error has come from GDE with error type - -60 and error code - 417
02/05/13 12:03:17:331 | [WARN] | | ASU | PDApp | DownloadError | | | 6544 | Download Error has come with GDE Error type - -60 and error code - 417
02/05/13 12:03:17:331 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = productDownloadCompleteSignal, type = null
02/05/13 12:03:17:331 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = sendAnalyticsSignal, type = null
02/05/13 12:03:17:553 | [INFO] | | ASU | PDApp | CCM.ETSCommunicator | | | 6544 | Response: SUCCESS
02/05/13 12:10:14:775 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = updateInstallClickSignal, type = null
02/05/13 12:10:14:776 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = initCCMUpdateSessionSignal, type = null
02/05/13 12:10:14:779 | [INFO] | | ASU | PDApp | CCMNativeApplet | | | 6544 | createSession
02/05/13 12:10:14:799 | [INFO] | | ASU | PDApp | CCMNativeApplet | | | 6544 | dlmAppletSessionProxy.sessionId = {B0039A42-2173-4D6F-BE14-4F676E49FFE6}
02/05/13 12:10:14:799 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = sessionStartSignal, type = null
02/05/13 12:10:14:800 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeCCMUpdateWorkflowSignal, type = null
02/05/13 12:10:14:803 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeUpdateSessionStateWorker, type = null
02/05/13 12:10:14:804 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = acquireElevationToUpdateSignal, type = null
02/05/13 12:10:14:806 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeCCMUpdateWorkflowSignal, type = null
02/05/13 12:10:14:808 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = addProductInUpdateQueue, type = null
02/05/13 12:10:14:808 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeCCMUpdateWorkflowSignal, type = null
02/05/13 12:10:14:809 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeUpdateSessionStateWorker, type = null
02/05/13 12:10:14:809 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = addProductInDownloadQueue, type = null
02/05/13 12:10:14:810 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeCCMUpdateWorkflowSignal, type = null
02/05/13 12:10:14:810 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = executeUpdateSessionStateWorker, type = null
02/05/13 12:10:14:810 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = startUpdatesDownloadSignal, type = null
02/05/13 12:10:14:811 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = sendAnalyticsSignal, type = null
02/05/13 12:10:15:064 | [INFO] | | ASU | PDApp | CCM.ETSCommunicator | | | 6544 | Response: SUCCESS
02/05/13 12:10:17:750 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:10:17:751 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:10:17:751 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMUpdatesWorkflowSignal, type = null
02/05/13 12:10:17:752 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleUpdateDownloadProgressSignal, type = null
2/5/2013 12:10:19 [INFO] OPM - No Record found for the input fields in opm_getValueForKey
02/05/13 12:10:24:682 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:10:24:682 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:10:24:682 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMUpdatesWorkflowSignal, type = null
02/05/13 12:10:24:682 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleUpdateDownloadProgressSignal, type = null
02/05/13 12:10:28:972 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:10:28:972 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:10:28:972 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMUpdatesWorkflowSignal, type = null
02/05/13 12:10:28:972 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleUpdateDownloadProgressSignal, type = null
02/05/13 12:10:32:549 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:10:32:549 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:10:32:549 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMUpdatesWorkflowSignal, type = null
02/05/13 12:10:32:549 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleUpdateDownloadProgressSignal, type = null
02/05/13 12:10:34:140 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:10:34:140 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:10:34:140 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMUpdatesWorkflowSignal, type = null
02/05/13 12:10:34:140 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleUpdateDownloadProgressSignal, type = null
02/05/13 12:10:35:187 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:10:35:189 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:10:35:189 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMUpdatesWorkflowSignal, type = null
02/05/13 12:10:35:189 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleUpdateDownloadProgressSignal, type = null
02/05/13 12:10:36:265 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataSignal, type = null
02/05/13 12:10:36:265 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = commonNativeDataHandleSignal, type = null
02/05/13 12:10:36:265 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleNativeDataForCCMUpdatesWorkflowSignal, type = null
02/05/13 12:10:36:265 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = handleUpdateDownloadErrorSignal, type = null
02/05/13 12:10:36:265 | [WARN] | | ASU | PDApp | DownloadErrorVo | | | 6544 | Error has come from GDE with error type - U43M1D207 and error code - 207
02/05/13 12:10:36:265 | [WARN] | | ASU | PDApp | DownloadError | | | 6544 | Download Error has come with GDE Error type - U43M1D207 and error code - 207
02/05/13 12:10:36:265 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = updateCompleteSignal, type = null
02/05/13 12:10:36:265 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = productDownloadCompleteSignal, type = null
02/05/13 12:10:36:265 | [INFO] | | ASU | PDApp | DLM.ApplicationFacade | | | 6544 | sendNotification = sendAnalyticsSignal, type = null
02/05/13 12:10:36:465 | [INFO] | | ASU | PDApp | CCM.ETSCommunicator | | | 6544 | Response: SUCCESS
Here is my DLM_Native Log:
02/05/13 11:53:34:344 | [INFO] | | | | | | | Calling regsvr32 C:\Windows\system32\regsvr32.exe /s C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\CCM\Utilities
02/05/13 11:53:34:422 | [INFO] | | | | | | | Finished regsvr32. Exit code: 0
02/05/13 11:53:34:422 | [INFO] | | | | | | | Calling regsvr32 C:\Windows\system32\regsvr32.exe /s C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\CCM\Utilities
02/05/13 11:53:34:531 | [INFO] | | | | | | | Finished regsvr32. Exit code: 0
02/05/13 11:53:34:531 | [INFO] | | | | | | | AAM URI protocol handler registered.
02/05/13 11:53:34:531 | [INFO] | | | | | | | AAM URI: AAM shortcut deleted from all user's desktop and start menu adobe folder.
02/05/13 11:53:34:593 | [INFO] | | | | | | | AAM URI: AAM shortcut created on all user's desktop and start menu adobe folder.
02/05/13 11:53:41:661 | [INFO] | | | | | | | Session is created and key generated is {99920720-2435-4D4D-B351-58333C737DB0}
02/05/13 11:53:41:676 | [WARN] | | | | | | | Could not initialize CCM config sig file as XML data
02/05/13 11:53:45:959 | [INFO] | {99920720-2435-4D4D-B351-58333C737DB0} | | | | | | latest AAM is not present
02/05/13 11:53:47:316 | [INFO] | {99920720-2435-4D4D-B351-58333C737DB0} | | | | | | Going to close the session
02/05/13 11:53:47:316 | [INFO] | {99920720-2435-4D4D-B351-58333C737DB0} | | | | | | All waiting operations finished for this session
02/05/13 11:55:15:229 | [INFO] | | | | | | | Session is created and key generated is {E057E87B-09CC-4836-9E7D-1A045758C118}
02/05/13 11:55:15:244 | [WARN] | | | | | | | Could not initialize CCM config sig file as XML data
02/05/13 11:55:18:934 | [INFO] | {E057E87B-09CC-4836-9E7D-1A045758C118} | | | | | | latest AAM is not present
02/05/13 11:55:20:255 | [INFO] | {E057E87B-09CC-4836-9E7D-1A045758C118} | | | | | | Going to close the session
02/05/13 11:55:20:255 | [INFO] | {E057E87B-09CC-4836-9E7D-1A045758C118} | | | | | | All waiting operations finished for this session
02/05/13 11:57:25:250 | [INFO] | | | | | | | Session is created and key generated is {8FE1ED10-01DE-4A6D-99BC-6C772205AED2}
02/05/13 11:57:25:266 | [WARN] | | | | | | | Could not initialize CCM config sig file as XML data
02/05/13 11:57:29:200 | [INFO] | {8FE1ED10-01DE-4A6D-99BC-6C772205AED2} | | | | | | latest AAM is not present
02/05/13 11:57:30:206 | [INFO] | {8FE1ED10-01DE-4A6D-99BC-6C772205AED2} | | | | | | Going to close the session
02/05/13 11:57:30:211 | [INFO] | {8FE1ED10-01DE-4A6D-99BC-6C772205AED2} | | | | | | All waiting operations finished for this session
02/05/13 12:01:34:624 | [INFO] | | | | | | | 6388 | Calling regsvr32 C:\Windows\system32\regsvr32.exe /s C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\CCM\Utilities
02/05/13 12:01:34:717 | [INFO] | | | | | | | 6388 | Finished regsvr32. Exit code: 0
02/05/13 12:01:34:717 | [INFO] | | | | | | | 6388 | Calling regsvr32 C:\Windows\system32\regsvr32.exe /s C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\CCM\Utilities
02/05/13 12:01:34:905 | [INFO] | | | | | | | 6388 | Finished regsvr32. Exit code: 0
02/05/13 12:01:34:905 | [INFO] | | | | | | | 6388 | AAM URI protocol handler registered.
02/05/13 12:01:34:905 | [INFO] | | | | | | | 6388 | AAM URI: AAM shortcut deleted from all user's desktop and start menu adobe folder.
02/05/13 12:01:35:092 | [INFO] | | | | | | | 6388 | AAM URI: AAM shortcut created on all user's desktop and start menu adobe folder.
02/05/13 12:01:51:254 | [INFO] | | | | | | | 6544 | Update Session is created and key generated is {76C89C44-B9B1-47A2-9A71-3CB13E3C36C5}
02/05/13 12:01:51:316 | [INFO] | | | | | | | 6544 | Product Session is created and key generated is {5621E9AD-39EA-4686-B443-DA3AB4C158F6}
02/05/13 12:01:51:316 | [WARN] | | | | | | | 6544 | Could not initialize CCM config sig file as XML data
02/05/13 12:01:55:847 | [INFO] | {76C89C44-B9B1-47A2-9A71-3CB13E3C36C5} | | | | | | 6640 | No need to update AAM
02/05/13 12:02:17:064 | [INFO] | | | | | | | 6732 | UpdaterCoreHelper :: Check for updates returned SUCCESS
02/05/13 12:02:22:874 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {E0D1B182-6827-4AD8-9C1D-CFFD4314DFE4} is installed for language : en_US
02/05/13 12:02:22:887 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {F7DE06AE-23B6-4837-ADAB-02C5D6658C46} is not installed for language : en_US
02/05/13 12:02:22:897 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {3D46121C-A0E6-4259-B7E0-5127C218A096} is installed for language : en_US
02/05/13 12:02:22:906 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {3c5418ff-7dea-4a37-8c52-45c670677773} is not installed for language : en_US
02/05/13 12:02:22:915 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {7176B973-6011-43C1-AEBC-2D73FE7C6982} is not installed for language : en_US
02/05/13 12:02:22:924 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {42CED1DA-1C36-45D2-88C0-C32DB6B82B49} is installed for language : en_US
02/05/13 12:02:22:933 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {46251F95-B2F8-484A-9B5B-8C0E5A43A202} is installed for language : en_US
02/05/13 12:02:22:942 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {30FD541D-3C9D-41C4-B240-A994EE4E0231} is installed for language : en_US
02/05/13 12:02:22:951 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {CFB770D7-8D43-1014-922B-CC2715FADE3F} is installed for language : en_US
02/05/13 12:02:22:960 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {BD5669B5-49FF-4490-B956-E9D7CB9B0ADC} is not installed for language : en_US
02/05/13 12:02:22:969 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {4FAB339E-2132-434F-9376-9CD735E4C69C} is installed for language : en_US
02/05/13 12:02:22:977 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {D2583A3E-399C-45D7-8AF1-FE5BAFC946CF} is installed for language : en_US
02/05/13 12:02:22:986 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {1EC083EE-5B76-4A2A-B95A-CAF460AA29D6} is not installed for language : en_US
02/05/13 12:02:22:995 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {74EB3499-8B95-4B5C-96EB-7B342F3FD0C6} is not installed for language : en_US
02/05/13 12:02:23:003 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {3289C0E8-78B9-47D4-98E5-F25BFF1CBED4} is installed for language : en_US
02/05/13 12:02:23:011 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {9124DF4E-617D-486B-A970-8FA632244F24} is installed for language : en_US
02/05/13 12:02:23:021 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {848DE8E1-521D-4748-A158-517708107EF3} is not installed for language : en_US
02/05/13 12:02:23:029 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {9A554C9D-E12D-4205-8101-9F4337CD5673} is not installed for language : en_US
02/05/13 12:02:23:038 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {CA7C485C-7A89-11E1-B2C8-CD54B377BC52} is installed for language : en_US
02/05/13 12:02:23:047 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {4869414E-7AEA-4C8E-BE1C-8D40977FD517} is installed for language : en_US
02/05/13 12:02:23:056 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {7D4E9D10-AED6-485D-A2B0-9A1DF1A55545} is installed for language : en_US
02/05/13 12:02:23:064 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {9D3BB9DA-1F59-4DCF-A0BB-691FA8EA2582} is installed for language : en_US
02/05/13 12:02:23:074 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {893B3B44-0A1E-404B-8FE8-0A74509102A9} is not installed for language : en_US
02/05/13 12:02:23:082 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {3EB3A244-177C-4FDC-A409-66D40B1BCD26} is not installed for language : en_US
02/05/13 12:02:23:090 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {68343A68-CE7B-4953-8364-55C2A8296CEE} is not installed for language : en_US
02/05/13 12:02:23:099 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {4817D846-700B-474E-A31B-80892B3E92E3} is installed for language : en_US
02/05/13 12:02:23:108 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {23D3F585-AE29-4670-8E3E-64A0EFB29240} is not installed for language : en_US
02/05/13 12:02:23:117 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} is installed for language : en_US
02/05/13 12:02:23:129 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {E0D1B182-6827-4AD8-9C1D-CFFD4314DFE4} is installed for language : en_US
02/05/13 12:02:23:138 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {F7DE06AE-23B6-4837-ADAB-02C5D6658C46} is not installed for language : en_US
02/05/13 12:02:23:147 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {3D46121C-A0E6-4259-B7E0-5127C218A096} is installed for language : en_US
02/05/13 12:02:23:156 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {3c5418ff-7dea-4a37-8c52-45c670677773} is not installed for language : en_US
02/05/13 12:02:23:164 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {7176B973-6011-43C1-AEBC-2D73FE7C6982} is not installed for language : en_US
02/05/13 12:02:23:173 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {42CED1DA-1C36-45D2-88C0-C32DB6B82B49} is installed for language : en_US
02/05/13 12:02:23:181 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {46251F95-B2F8-484A-9B5B-8C0E5A43A202} is installed for language : en_US
02/05/13 12:02:23:190 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {30FD541D-3C9D-41C4-B240-A994EE4E0231} is installed for language : en_US
02/05/13 12:02:23:199 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {CFB770D7-8D43-1014-922B-CC2715FADE3F} is installed for language : en_US
02/05/13 12:02:23:208 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {BD5669B5-49FF-4490-B956-E9D7CB9B0ADC} is not installed for language : en_US
02/05/13 12:02:23:216 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {4FAB339E-2132-434F-9376-9CD735E4C69C} is installed for language : en_US
02/05/13 12:02:23:225 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {D2583A3E-399C-45D7-8AF1-FE5BAFC946CF} is installed for language : en_US
02/05/13 12:02:23:233 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {1EC083EE-5B76-4A2A-B95A-CAF460AA29D6} is not installed for language : en_US
02/05/13 12:02:23:242 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {74EB3499-8B95-4B5C-96EB-7B342F3FD0C6} is not installed for language : en_US
02/05/13 12:02:23:251 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {3289C0E8-78B9-47D4-98E5-F25BFF1CBED4} is installed for language : en_US
02/05/13 12:02:23:259 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {9124DF4E-617D-486B-A970-8FA632244F24} is installed for language : en_US
02/05/13 12:02:23:268 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {848DE8E1-521D-4748-A158-517708107EF3} is not installed for language : en_US
02/05/13 12:02:23:277 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {9A554C9D-E12D-4205-8101-9F4337CD5673} is not installed for language : en_US
02/05/13 12:02:23:286 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {CA7C485C-7A89-11E1-B2C8-CD54B377BC52} is installed for language : en_US
02/05/13 12:02:23:295 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {4869414E-7AEA-4C8E-BE1C-8D40977FD517} is installed for language : en_US
02/05/13 12:02:23:303 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {7D4E9D10-AED6-485D-A2B0-9A1DF1A55545} is installed for language : en_US
02/05/13 12:02:23:311 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {9D3BB9DA-1F59-4DCF-A0BB-691FA8EA2582} is installed for language : en_US
02/05/13 12:02:23:320 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {893B3B44-0A1E-404B-8FE8-0A74509102A9} is not installed for language : en_US
02/05/13 12:02:23:328 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {3EB3A244-177C-4FDC-A409-66D40B1BCD26} is not installed for language : en_US
02/05/13 12:02:23:336 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {68343A68-CE7B-4953-8364-55C2A8296CEE} is not installed for language : en_US
02/05/13 12:02:23:345 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {4817D846-700B-474E-A31B-80892B3E92E3} is installed for language : en_US
02/05/13 12:02:23:354 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {23D3F585-AE29-4670-8E3E-64A0EFB29240} is not installed for language : en_US
02/05/13 12:02:23:363 | [INFO] | | | | | | | 6544 | getIfProdInstalledInLang : product with adobeCode : {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} is installed for language : en_US
02/05/13 12:02:24:474 | [INFO] | | | | | | | 6544 | Failed to open event handle
02/05/13 12:02:28:611 | [INFO] | | | | | | | 6544 | Update Session is created and key generated is {5BF940BF-ADC7-4324-A93C-DA3E06115241}
02/05/13 12:02:28:624 | [INFO] | | | | | | | 6544 | Launching AAM Helper process
02/05/13 12:02:31:161 | [INFO] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6872 | The value of ETAG for the file is "95c7668891ea0578f86db4ef87996e21:1355500143"
02/05/13 12:02:34:266 | [INFO] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6908 | The value of ETAG for the file is "d3f77a5440ad23c6a163e8ff877658e5:1355500143"
02/05/13 12:02:37:416 | [INFO] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6928 | The value of ETAG for the file is "a78f0fe7cb569f461862e6ab5eda9aee:1355500255"
02/05/13 12:02:40:882 | [ERROR] | | | | | | | 6960 | Signature MISMATCH of segmentID 1 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = b8bde5b600a58c5577edda24474c6a4b
02/05/13 12:02:40:882 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6960 | Checksum validation failed for segment 1
02/05/13 12:02:40:904 | [ERROR] | | | | | | | 6948 | Signature MISMATCH of segmentID 4 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = e42580a2025c5140895d03106a9c1e9d
02/05/13 12:02:40:904 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6948 | Checksum validation failed for segment 4
02/05/13 12:02:40:929 | [ERROR] | | | | | | | 6968 | Signature MISMATCH of segmentID 3 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 2eea0555722f16034cf980b42c64f137
02/05/13 12:02:40:929 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6968 | Checksum validation failed for segment 3
02/05/13 12:02:40:936 | [ERROR] | | | | | | | 6952 | Signature MISMATCH of segmentID 5 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = fb8cb9b3a6fd7087c8070ace1e2cca03
02/05/13 12:02:40:936 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6952 | Checksum validation failed for segment 5
02/05/13 12:02:43:559 | [ERROR] | | | | | | | 6956 | Signature MISMATCH of segmentID 6 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = e121f4f33569884b1139b6ce967ae68c
02/05/13 12:02:43:559 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6956 | Checksum validation failed for segment 6
02/05/13 12:02:43:610 | [ERROR] | | | | | | | 6960 | Signature MISMATCH of segmentID 1 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = b8bde5b600a58c5577edda24474c6a4b
02/05/13 12:02:43:610 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6960 | Checksum validation failed for segment 1
02/05/13 12:02:43:633 | [ERROR] | | | | | | | 6948 | Signature MISMATCH of segmentID 4 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = e42580a2025c5140895d03106a9c1e9d
02/05/13 12:02:43:633 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6948 | Checksum validation failed for segment 4
02/05/13 12:02:43:772 | [ERROR] | | | | | | | 6952 | Signature MISMATCH of segmentID 5 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = fb8cb9b3a6fd7087c8070ace1e2cca03
02/05/13 12:02:43:772 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6952 | Checksum validation failed for segment 5
02/05/13 12:02:43:779 | [ERROR] | | | | | | | 6968 | Signature MISMATCH of segmentID 3 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 2eea0555722f16034cf980b42c64f137
02/05/13 12:02:43:779 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6968 | Checksum validation failed for segment 3
02/05/13 12:02:46:137 | [ERROR] | | | | | | | 6964 | Signature MISMATCH of segmentID 2 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 63b39a75c5d5c561dd701f505dbd427f
02/05/13 12:02:46:137 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6964 | Checksum validation failed for segment 2
02/05/13 12:02:47:527 | [ERROR] | | | | | | | 6948 | Signature MISMATCH of segmentID 4 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = e42580a2025c5140895d03106a9c1e9d
02/05/13 12:02:47:527 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6948 | Checksum validation failed for segment 4
02/05/13 12:02:47:958 | [ERROR] | | | | | | | 6960 | Signature MISMATCH of segmentID 1 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = b8bde5b600a58c5577edda24474c6a4b
02/05/13 12:02:47:958 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6960 | Checksum validation failed for segment 1
02/05/13 12:02:47:958 | [ERROR] | | | | | | | 6956 | Signature MISMATCH of segmentID 6 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = e121f4f33569884b1139b6ce967ae68c
02/05/13 12:02:47:958 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6956 | Checksum validation failed for segment 6
02/05/13 12:02:48:138 | [ERROR] | | | | | | | 6968 | Signature MISMATCH of segmentID 3 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 2eea0555722f16034cf980b42c64f137
02/05/13 12:02:48:138 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6968 | Checksum validation failed for segment 3
02/05/13 12:02:48:141 | [ERROR] | | | | | | | 6952 | Signature MISMATCH of segmentID 5 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = fb8cb9b3a6fd7087c8070ace1e2cca03
02/05/13 12:02:48:141 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6952 | Checksum validation failed for segment 5
02/05/13 12:02:50:094 | [ERROR] | | | | | | | 6964 | Signature MISMATCH of segmentID 2 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 63b39a75c5d5c561dd701f505dbd427f
02/05/13 12:02:50:094 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6964 | Checksum validation failed for segment 2
02/05/13 12:02:51:638 | [ERROR] | | | | | | | 6948 | Signature MISMATCH of segmentID 4 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = e42580a2025c5140895d03106a9c1e9d
02/05/13 12:02:51:638 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6948 | Checksum validation failed for segment 4
02/05/13 12:02:51:981 | [ERROR] | | | | | | | 6956 | Signature MISMATCH of segmentID 6 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = e121f4f33569884b1139b6ce967ae68c
02/05/13 12:02:51:981 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6956 | Checksum validation failed for segment 6
02/05/13 12:02:52:091 | [ERROR] | | | | | | | 6968 | Signature MISMATCH of segmentID 3 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 2eea0555722f16034cf980b42c64f137
02/05/13 12:02:52:091 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6968 | Checksum validation failed for segment 3
02/05/13 12:02:52:101 | [ERROR] | | | | | | | 6952 | Signature MISMATCH of segmentID 5 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = fb8cb9b3a6fd7087c8070ace1e2cca03
02/05/13 12:02:52:101 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6952 | Checksum validation failed for segment 5
02/05/13 12:02:52:126 | [ERROR] | | | | | | | 6960 | Signature MISMATCH of segmentID 1 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = b8bde5b600a58c5577edda24474c6a4b
02/05/13 12:02:52:126 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6960 | Checksum validation failed for segment 1
02/05/13 12:02:53:042 | [ERROR] | | | | | | | 6972 | Signature MISMATCH of segmentID 7 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 0f62cbc6bc265e971857a63936f0409b
02/05/13 12:02:53:042 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6972 | Checksum validation failed for segment 7
02/05/13 12:02:53:422 | [ERROR] | | | | | | | 6964 | Signature MISMATCH of segmentID 2 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 63b39a75c5d5c561dd701f505dbd427f
02/05/13 12:02:53:422 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6964 | Checksum validation failed for segment 2
02/05/13 12:02:55:509 | [ERROR] | | | | | | | 6948 | Signature MISMATCH of segmentID 4 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = e42580a2025c5140895d03106a9c1e9d
02/05/13 12:02:55:509 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6948 | Checksum validation failed for segment 4
02/05/13 12:02:55:516 | [ERROR] | | | | | | | 6956 | Signature MISMATCH of segmentID 6 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = e121f4f33569884b1139b6ce967ae68c
02/05/13 12:02:55:516 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6956 | Checksum validation failed for segment 6
02/05/13 12:02:55:610 | [ERROR] | | | | | | | 6960 | Signature MISMATCH of segmentID 1 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = b8bde5b600a58c5577edda24474c6a4b
02/05/13 12:02:55:610 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6960 | Checksum validation failed for segment 1
02/05/13 12:02:55:861 | [ERROR] | | | | | | | 6952 | Signature MISMATCH of segmentID 5 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = fb8cb9b3a6fd7087c8070ace1e2cca03
02/05/13 12:02:55:861 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6952 | Checksum validation failed for segment 5
02/05/13 12:02:55:882 | [ERROR] | | | | | | | 6968 | Signature MISMATCH of segmentID 3 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 2eea0555722f16034cf980b42c64f137
02/05/13 12:02:55:882 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6968 | Checksum validation failed for segment 3
02/05/13 12:02:56:147 | [ERROR] | | | | | | | 6972 | Signature MISMATCH of segmentID 7 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 0f62cbc6bc265e971857a63936f0409b
02/05/13 12:02:56:147 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6972 | Checksum validation failed for segment 7
02/05/13 12:02:56:516 | [ERROR] | | | | | | | 6964 | Signature MISMATCH of segmentID 2 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 63b39a75c5d5c561dd701f505dbd427f
02/05/13 12:02:56:516 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6964 | Checksum validation failed for segment 2
02/05/13 12:02:59:308 | [ERROR] | | | | | | | 6960 | Signature MISMATCH of segmentID 1 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = b8bde5b600a58c5577edda24474c6a4b
02/05/13 12:02:59:308 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6960 | Checksum validation failed for segment 1
02/05/13 12:02:59:761 | [ERROR] | | | | | | | 6952 | Signature MISMATCH of segmentID 5 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = fb8cb9b3a6fd7087c8070ace1e2cca03
02/05/13 12:02:59:761 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6952 | Checksum validation failed for segment 5
02/05/13 12:02:59:808 | [ERROR] | | | | | | | 6948 | Signature MISMATCH of segmentID 4 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = e42580a2025c5140895d03106a9c1e9d
02/05/13 12:02:59:808 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6948 | Checksum validation failed for segment 4
02/05/13 12:03:00:057 | [ERROR] | | | | | | | 6956 | Signature MISMATCH of segmentID 6 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = e121f4f33569884b1139b6ce967ae68c
02/05/13 12:03:00:057 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6956 | Checksum validation failed for segment 6
02/05/13 12:03:00:182 | [ERROR] | | | | | | | 6968 | Signature MISMATCH of segmentID 3 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 2eea0555722f16034cf980b42c64f137
02/05/13 12:03:00:182 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6968 | Checksum validation failed for segment 3
02/05/13 12:03:00:483 | [ERROR] | | | | | | | 6972 | Signature MISMATCH of segmentID 7 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 0f62cbc6bc265e971857a63936f0409b
02/05/13 12:03:00:483 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6972 | Checksum validation failed for segment 7
02/05/13 12:03:00:803 | [ERROR] | | | | | | | 6964 | Signature MISMATCH of segmentID 2 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 63b39a75c5d5c561dd701f505dbd427f
02/05/13 12:03:00:803 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6964 | Checksum validation failed for segment 2
02/05/13 12:03:02:545 | [ERROR] | | | | | | | 6960 | Signature MISMATCH of segmentID 1 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = b8bde5b600a58c5577edda24474c6a4b
02/05/13 12:03:02:545 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6960 | Checksum validation failed for segment 1
02/05/13 12:03:02:743 | [ERROR] | | | | | | | 6952 | Signature MISMATCH of segmentID 5 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = fb8cb9b3a6fd7087c8070ace1e2cca03
02/05/13 12:03:02:743 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6952 | Checksum validation failed for segment 5
02/05/13 12:03:02:773 | [ERROR] | | | | | | | 6948 | Signature MISMATCH of segmentID 4 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = e42580a2025c5140895d03106a9c1e9d
02/05/13 12:03:02:773 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6948 | Checksum validation failed for segment 4
02/05/13 12:03:02:893 | [ERROR] | | | | | | | 6956 | Signature MISMATCH of segmentID 6 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = e121f4f33569884b1139b6ce967ae68c
02/05/13 12:03:02:893 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6956 | Checksum validation failed for segment 6
02/05/13 12:03:03:922 | [ERROR] | | | | | | | 6968 | Signature MISMATCH of segmentID 3 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 2eea0555722f16034cf980b42c64f137
02/05/13 12:03:03:922 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6968 | Checksum validation failed for segment 3
02/05/13 12:03:04:832 | [ERROR] | | | | | | | 6964 | Signature MISMATCH of segmentID 2 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 63b39a75c5d5c561dd701f505dbd427f
02/05/13 12:03:04:832 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6964 | Checksum validation failed for segment 2
02/05/13 12:03:04:957 | [ERROR] | | | | | | | 6972 | Signature MISMATCH of segmentID 7 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 0f62cbc6bc265e971857a63936f0409b
02/05/13 12:03:04:957 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6972 | Checksum validation failed for segment 7
02/05/13 12:03:06:844 | [ERROR] | | | | | | | 6960 | Signature MISMATCH of segmentID 1 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = b8bde5b600a58c5577edda24474c6a4b
02/05/13 12:03:06:844 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6960 | Checksum validation failed for segment 1
02/05/13 12:03:07:047 | [ERROR] | | | | | | | 6948 | Signature MISMATCH of segmentID 4 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = e42580a2025c5140895d03106a9c1e9d
02/05/13 12:03:07:047 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6948 | Checksum validation failed for segment 4
02/05/13 12:03:07:047 | [ERROR] | | | | | | | 6952 | Signature MISMATCH of segmentID 5 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = fb8cb9b3a6fd7087c8070ace1e2cca03
02/05/13 12:03:07:047 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6952 | Checksum validation failed for segment 5
02/05/13 12:03:07:952 | [ERROR] | | | | | | | 6976 | Signature MISMATCH of segmentID 8 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 053a06054d585684dcbf8619637f2c51
02/05/13 12:03:07:952 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6976 | Checksum validation failed for segment 8
02/05/13 12:03:08:155 | [ERROR] | | | | | | | 6968 | Signature MISMATCH of segmentID 3 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 2eea0555722f16034cf980b42c64f137
02/05/13 12:03:08:155 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6968 | Checksum validation failed for segment 3
02/05/13 12:03:09:168 | [ERROR] | | | | | | | 6972 | Signature MISMATCH of segmentID 7 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 0f62cbc6bc265e971857a63936f0409b
02/05/13 12:03:09:168 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6972 | Checksum validation failed for segment 7
02/05/13 12:03:09:299 | [ERROR] | | | | | | | 6964 | Signature MISMATCH of segmentID 2 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 63b39a75c5d5c561dd701f505dbd427f
02/05/13 12:03:09:299 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6964 | Checksum validation failed for segment 2
02/05/13 12:03:11:015 | [ERROR] | | | | | | | 6948 | Signature MISMATCH of segmentID 4 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = e42580a2025c5140895d03106a9c1e9d
02/05/13 12:03:11:015 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6948 | Checksum validation failed for segment 4
02/05/13 12:03:11:135 | [ERROR] | | | | | | | 6952 | Signature MISMATCH of segmentID 5 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = fb8cb9b3a6fd7087c8070ace1e2cca03
02/05/13 12:03:11:135 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6952 | Checksum validation failed for segment 5
02/05/13 12:03:11:695 | [ERROR] | | | | | | | 6960 | Signature MISMATCH of segmentID 1 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = b8bde5b600a58c5577edda24474c6a4b
02/05/13 12:03:11:695 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6960 | Checksum validation failed for segment 1
02/05/13 12:03:11:880 | [ERROR] | | | | | | | 6956 | Signature MISMATCH of segmentID 6 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = e121f4f33569884b1139b6ce967ae68c
02/05/13 12:03:11:880 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6956 | Checksum validation failed for segment 6
02/05/13 12:03:12:245 | [ERROR] | | | | | | | 6976 | Signature MISMATCH of segmentID 8 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 053a06054d585684dcbf8619637f2c51
02/05/13 12:03:12:245 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6976 | Checksum validation failed for segment 8
02/05/13 12:03:12:400 | [ERROR] | | | | | | | 6968 | Signature MISMATCH of segmentID 3 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 2eea0555722f16034cf980b42c64f137
02/05/13 12:03:12:400 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6968 | Checksum validation failed for segment 3
02/05/13 12:03:12:647 | [ERROR] | | | | | | | 6964 | Signature MISMATCH of segmentID 2 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 63b39a75c5d5c561dd701f505dbd427f
02/05/13 12:03:12:647 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6964 | Checksum validation failed for segment 2
02/05/13 12:03:13:786 | [ERROR] | | | | | | | 6972 | Signature MISMATCH of segmentID 7 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = 0f62cbc6bc265e971857a63936f0409b
02/05/13 12:03:13:786 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6972 | Checksum validation failed for segment 7
02/05/13 12:03:15:299 | [ERROR] | | | | | | | 6952 | Signature MISMATCH of segmentID 5 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = fb8cb9b3a6fd7087c8070ace1e2cca03
02/05/13 12:03:15:299 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6952 | Checksum validation failed for segment 5
02/05/13 12:03:15:658 | [ERROR] | | | | | | | 6960 | Signature MISMATCH of segmentID 1 Download Data Signature = 68ec14f4126645daddbf67f965f7ca32 and Signature from ValidationXML = b8bde5b600a58c5577edda24474c6a4b
02/05/13 12:03:15:658 | [ERROR] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6960 | Checksum validation failed for segment 1
02/05/13 12:03:17:017 | [WARN] | {5BF940BF-ADC7-4324-A93C-DA3E06115241} | | | | | | 6996 | Some Error has come during download operation with Error type - -60, and Error Code - 417
02/05/13 12:10:14:798 | [INFO] | | | | | | | 6544 | Product Session is created and key generated is {B0039A42-2173-4D6F-BE14-4F676E49FFE6}
02/05/13 12:10:36:161 | [ERROR] | | | | | DLMNative | | 7156 | UpdaterCore Progress returned error Code :U43M1D207
02/05/13 12:10:36:161 | [ERROR] | | | | | DLMNative | | 7156 | Download Updates Returned Error
02/05/13 12:10:36:161 | [ERROR] | {B0039A42-2173-4D6F-BE14-4F676E49FFE6} | | | | DLMNative | | 7156 | download updates returned statusCode:43, errorCode:207
02/05/13 12:10:36:161 | [ERROR] | {B0039A42-2173-4D6F-BE14-4F676E49FFE6} | | | | DLMNative | | 7156 | Invalid Download or Validation error
Finally my LBS.Log
02/05/13 11:53:46:583 | [INFO] | | Download | LBS | LBSApplicationFacade | | | ****************Starting LBS workflow*******************
02/05/13 11:53:46:661 | [INFO] | | Download | LBS | LBSWorkflowManager | | | initializing screen
02/05/13 11:53:47:238 | [INFO] | | Download | LBS | ProductInfo | | | Product Sap Code not specified in the product information file
02/05/13 11:53:47:238 | [INFO] | | Download | LBS | ProductInfo | | | Product locale not specified in the product information file
02/05/13 11:53:47:238 | [INFO] | | Download | LBS | ProductInfo | | | Product name not specified in the product information file
02/05/13 11:53:47:238 | [INFO] | | Download | LBS | LBSWorkflowManager | | | Bootstraping Passed
02/05/13 11:53:47:253 | [INFO] | | Download | LBS | LBSWorkflowManager | | | LBS lock acquired
02/05/13 11:53:47:269 | [INFO] | | Download | LBS | LBSWorkflowManager | | | System requirements check passed
02/05/13 11:53:48:798 | [INFO] | | Download | LBS | LBSWorkflowManager | | | deployment lock check passed
02/05/13 11:53:48:814 | [INFO] | | Download | LBS | LBSWorkflowManager | | | AAM already present
02/05/13 11:53:48:829 | [INFO] | | Download | LBS | LBSWorkflowManager | | | ****Downloading AAM version info file****
02/05/13 11:53:51:981 | [INFO] | | Download | LBS | LBSWorkflowManager | | | Latest adobe application manager needs to be updated on the machine
02/05/13 11:53:51:996 | [INFO] | | Download | LBS | LBSWorkflowManager | | | Downloading Adobe Application Manager
02/05/13 11:54:05:850 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:54:05:866 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:54:05:881 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:54:06:006 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 3 of size 2097152 is Invalid
02/05/13 11:54:06:349 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:54:08:752 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:54:09:017 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:54:09:906 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:54:10:047 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:54:10:421 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 3 of size 2097152 is Invalid
02/05/13 11:54:12:949 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:54:13:198 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:54:14:072 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:54:14:306 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:54:15:055 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:54:17:052 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 3 of size 2097152 is Invalid
02/05/13 11:54:18:237 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:54:18:409 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:54:19:329 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:54:19:501 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:54:20:312 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:54:21:404 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:54:22:231 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 3 of size 2097152 is Invalid
02/05/13 11:54:22:528 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:54:22:793 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:54:23:729 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:54:23:760 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:54:24:509 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:54:26:553 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:54:26:678 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 3 of size 2097152 is Invalid
02/05/13 11:54:27:224 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:54:28:285 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:54:28:425 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:54:28:675 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:54:30:547 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:54:30:812 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:54:30:828 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:54:31:639 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 3 of size 2097152 is Invalid
02/05/13 11:54:32:466 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:54:32:481 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:54:33:261 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:54:34:962 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:54:35:087 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:54:35:212 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:54:36:257 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:54:36:616 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 3 of size 2097152 is Invalid
02/05/13 11:54:37:474 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:54:37:739 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:54:38:176 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:54:39:299 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:54:39:315 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:54:39:346 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:54:40:454 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:54:40:844 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:54:41:686 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 3 of size 2097152 is Invalid
02/05/13 11:54:42:232 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:54:42:357 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:54:42:497 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 10 of size 2097152 is Invalid
02/05/13 11:54:43:605 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:54:44:697 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:54:45:134 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:54:46:320 | [FATAL] | | Download | LBS | LBSWorkflowManager | | | Fatal error has occured. errotType = -60 extendedErrorCode = 417
02/05/13 11:54:46:335 | [WARN] | | Download | LBS | DownloadManifest | | | Asset file could not be downloaded
02/05/13 11:55:06:554 | [INFO] | | Download | LBS | LBSApplicationFacade | | | ****************Closing LBS workflow*******************
02/05/13 11:55:19:505 | [INFO] | | Download | LBS | LBSApplicationFacade | | | ****************Starting LBS workflow*******************
02/05/13 11:55:19:575 | [INFO] | | Download | LBS | LBSWorkflowManager | | | initializing screen
02/05/13 11:55:19:825 | [INFO] | | Download | LBS | ProductInfo | | | Product Sap Code not specified in the product information file
02/05/13 11:55:19:825 | [INFO] | | Download | LBS | ProductInfo | | | Product locale not specified in the product information file
02/05/13 11:55:19:825 | [INFO] | | Download | LBS | ProductInfo | | | Product name not specified in the product information file
02/05/13 11:55:19:825 | [INFO] | | Download | LBS | LBSWorkflowManager | | | Bootstraping Passed
02/05/13 11:55:19:835 | [INFO] | | Download | LBS | LBSWorkflowManager | | | LBS lock acquired
02/05/13 11:55:19:845 | [INFO] | | Download | LBS | LBSWorkflowManager | | | System requirements check passed
02/05/13 11:55:22:907 | [INFO] | | Download | LBS | LBSWorkflowManager | | | deployment lock check passed
02/05/13 11:55:22:922 | [INFO] | | Download | LBS | LBSWorkflowManager | | | AAM already present
02/05/13 11:55:22:938 | [INFO] | | Download | LBS | LBSWorkflowManager | | | ****Downloading AAM version info file****
02/05/13 11:55:25:980 | [INFO] | | Download | LBS | LBSWorkflowManager | | | Latest adobe application manager needs to be updated on the machine
02/05/13 11:55:25:996 | [INFO] | | Download | LBS | LBSWorkflowManager | | | Downloading Adobe Application Manager
02/05/13 11:55:37:229 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 3 of size 2097152 is Invalid
02/05/13 11:55:37:244 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:55:37:697 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:55:38:258 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:55:38:399 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:55:38:633 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:55:39:709 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:55:41:706 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:55:41:831 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:55:42:377 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:55:42:533 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:55:42:783 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:55:43:844 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:55:45:794 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:55:45:934 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:55:46:480 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:55:46:730 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:55:46:886 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:55:49:335 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:55:49:834 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:55:50:630 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:55:50:989 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:55:51:036 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:55:53:454 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:55:54:000 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:55:54:421 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:55:54:733 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 3 of size 2097152 is Invalid
02/05/13 11:55:55:076 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:55:55:092 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:55:55:154 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:55:57:666 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:55:58:072 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:55:58:587 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:55:58:899 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:55:59:289 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 3 of size 2097152 is Invalid
02/05/13 11:55:59:304 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:56:01:707 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:56:02:144 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:56:02:269 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:56:03:017 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:56:03:033 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:56:03:392 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:56:03:407 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:56:03:829 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:56:06:138 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 3 of size 2097152 is Invalid
02/05/13 11:56:06:403 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:56:06:543 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:56:07:277 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 10 of size 2097152 is Invalid
02/05/13 11:56:07:526 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:56:07:651 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:56:07:667 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:56:08:213 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:56:10:412 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 3 of size 2097152 is Invalid
02/05/13 11:56:10:678 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:56:10:709 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:56:11:302 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:56:11:692 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:56:11:832 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 10 of size 2097152 is Invalid
02/05/13 11:56:12:409 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:56:14:921 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:56:15:093 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:56:15:108 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 3 of size 2097152 is Invalid
02/05/13 11:56:19:524 | [FATAL] | | Download | LBS | LBSWorkflowManager | | | Fatal error has occured. errotType = -60 extendedErrorCode = 417
02/05/13 11:56:19:539 | [WARN] | | Download | LBS | DownloadManifest | | | Asset file could not be downloaded
02/05/13 11:56:55:999 | [INFO] | | Download | LBS | LBSApplicationFacade | | | ****************Closing LBS workflow*******************
02/05/13 11:57:29:450 | [INFO] | | Download | LBS | LBSApplicationFacade | | | ****************Starting LBS workflow*******************
02/05/13 11:57:29:511 | [INFO] | | Download | LBS | LBSWorkflowManager | | | initializing screen
02/05/13 11:57:29:656 | [INFO] | | Download | LBS | ProductInfo | | | Product Sap Code not specified in the product information file
02/05/13 11:57:29:656 | [INFO] | | Download | LBS | ProductInfo | | | Product locale not specified in the product information file
02/05/13 11:57:29:656 | [INFO] | | Download | LBS | ProductInfo | | | Product name not specified in the product information file
02/05/13 11:57:29:656 | [INFO] | | Download | LBS | LBSWorkflowManager | | | Bootstraping Passed
02/05/13 11:57:29:666 | [INFO] | | Download | LBS | LBSWorkflowManager | | | LBS lock acquired
02/05/13 11:57:29:676 | [INFO] | | Download | LBS | LBSWorkflowManager | | | System requirements check passed
02/05/13 11:57:32:722 | [INFO] | | Download | LBS | LBSWorkflowManager | | | deployment lock check passed
02/05/13 11:57:32:738 | [INFO] | | Download | LBS | LBSWorkflowManager | | | AAM already present
02/05/13 11:57:32:753 | [INFO] | | Download | LBS | LBSWorkflowManager | | | ****Downloading AAM version info file****
02/05/13 11:57:35:874 | [INFO] | | Download | LBS | LBSWorkflowManager | | | Latest adobe application manager needs to be updated on the machine
02/05/13 11:57:35:889 | [INFO] | | Download | LBS | LBSWorkflowManager | | | Downloading Adobe Application Manager
02/05/13 11:57:45:920 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:57:46:435 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:57:47:028 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:57:49:493 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 3 of size 2097152 is Invalid
02/05/13 11:57:49:508 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 4 of size 2097152 is Invalid
02/05/13 11:57:49:524 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:57:49:540 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:57:50:054 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:57:50:569 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:57:50:585 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:57:51:162 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:57:51:630 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 10 of size 2097152 is Invalid
02/05/13 11:57:53:518 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:57:54:095 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:57:54:594 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:57:54:610 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:57:55:296 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:57:55:655 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:57:57:652 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 10 of size 2097152 is Invalid
02/05/13 11:57:58:229 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:57:58:713 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:57:58:744 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:57:59:415 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:57:59:805 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:58:01:677 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:58:02:363 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 10 of size 2097152 is Invalid
02/05/13 11:58:02:753 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:58:02:784 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:58:03:502 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:58:03:876 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:58:05:795 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:58:05:920 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:58:06:466 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:58:06:981 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:58:07:667 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:58:08:073 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:58:09:865 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:58:09:972 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:58:10:295 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:58:10:615 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:58:11:250 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 10 of size 2097152 is Invalid
02/05/13 11:58:11:357 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:58:11:992 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:58:12:522 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:58:12:637 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:58:13:055 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:58:13:373 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:58:14:826 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:58:14:838 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 10 of size 2097152 is Invalid
02/05/13 11:58:15:474 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:58:15:689 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:58:15:950 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:58:16:527 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:58:17:198 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 6 of size 2097152 is Invalid
02/05/13 11:58:18:477 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 7 of size 2097152 is Invalid
02/05/13 11:58:18:789 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 5 of size 2097152 is Invalid
02/05/13 11:58:19:772 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 10 of size 2097152 is Invalid
02/05/13 11:58:19:912 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 1 of size 2097152 is Invalid
02/05/13 11:58:20:068 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 9 of size 2097152 is Invalid
02/05/13 11:58:20:645 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 8 of size 2097152 is Invalid
02/05/13 11:58:21:223 | [ERROR] | | Download | LBS | LBSWorkflowManager | | | Segment 2 of size 2097152 is Invalid
02/05/13 11:58:21:394 | [FATAL] | | Download | LBS | LBSWorkflowManager | | | Fatal error has occured. errotType = -60 extendedErrorCode = 417
02/05/13 11:58:21:410 | [WARN] | | Download | LBS | DownloadManifest | | | Asset file could not be downloaded
02/05/13 11:58:59:943 | [INFO] | | Download | LBS | LBSApplicationFacade | | | ****************Closing LBS workflow*******************
I am experiencing the same issues. Window7 64-bit in a corporate environment. I am the software asset manager for our company and I need to have this setup for multiple users. I would greatly appreciate a resolution to this other than downloading trial versions.
Matt,
I am glad (well not glad, it sucks but I'm glad I'm not alone) to hear you are experiencing the same thing. I have literally tried everything to get this to work. I even took a brand new laptop out of the box and Adobe was the only thing I installed. I can usually follow other posts and fix issues but I am stumped and WAY aggrivated. I love the concept as does my editing team but I'm in charge of installing and updating 5 PC's and my team is now aggrivated that they can't get what they need to do their jobs. Even if you download the trials, you don't get everything you need for the whole cloud process. Not to mention we all need updates badly and really need to start using Edge Animate.
Sorry for the inconveniece caused to you!
Please contact us back on chat so that we can troubleshoot the issue by taking control of your computer and control and resolve the issue.
