Brannyboy
How do you copy photo's from elements to an i-padmini
Feb 6, 2013 4:29 AM
How do you copy photo's from elements 10 to an i-padmini
    Feb 6, 2013 5:36 AM   in reply to Brannyboy
    If your IpadMini hasn't got a USB port then the only way I can think of is to email the photo to yourself and then retrieve it by logging to your email account using IpadMini.
    This method is fine if you have few photos only.  To transfer 1000s of photos require completely different device that can handle volume on an industrial scale.
    Good luck.
  • 99jon
    Jan 6, 2010
    Feb 6, 2013 7:09 AM   in reply to Brannyboy
    If you have Windows PC with iTunes its usually possible to connect your device, select it in the left hand panel and then sync with Albums in PSE.
    Feb 6, 2013 7:41 AM   in reply to Brannyboy
    Further to 99jon's reply, on a mac there is no direct connection between PSE and iOS devices (the route is through itunes). If you use photostream, your photos should be available to all your devices without the intervention of PSE.
