hsysgrp
Setting up a Remote Testing Server
Feb 6, 2013 11:02 AM
Tags: #dreamweaver
I cannot set up a testing server.  My remote server works fine. A test select.php page uploaded to the remote server retrieves data from the database no problem.
<?php
$host="qqqqqq"; // Host name
$username="xxxxx"; // Mysql username
$password="yyyy"; // Mysql password
$db_name="whatever"; // Database name
$tbl_name="products"; // Table name
// Connect to server and select database.
mysql_connect("$host", "$username", "$password")or die("cannot connect");
mysql_select_db("$db_name")or die("cannot select DB");
// Retrieve data from database
$sql="SELECT product_ID,product_name,product_unit,product_cost FROM $tbl_name";
$result=mysql_query($sql);
In the site server definition screen:
Remote Server
FTP Address: xxxxxxx
user name: yyyy
password: zzzz
root directory:root/root
web url: http://not.for.public.use
Test Server
FTP Address: xxxx2
user name:yyyy2
password: zzzz3
root directory:/root2
web url:http://only.for.public.use
When I test this input, I get cannot connect to the database.  Is it not possible to define a test server that is not local?
Thank you for any help.
hsysgrp
    Feb 6, 2013 9:39 AM   in reply to hsysgrp
    Please take your FTP details down as anyone can connect to your website
    Feb 6, 2013 9:46 AM   in reply to hsysgrp
    .. and don't forget to change your password, now that the world has seen it.
    ^_^
    Feb 6, 2013 9:51 AM   in reply to hsysgrp
    If you are trying to set up a 'local' testing server on your computer the connection details are most likely incorrect. Usually you have a different set of connections for a local server.
    The host name for instance would not be sql5c40a.carrierzone.com its more likely to be something like locahost.
    $host="XXXXXXXXXXXXXX.com"; // Host name
    $username="XXXXXXXXXXXX"; // Mysql username
    $password="XXXXXX"; // Mysql password
    $db_name="XXXXXXXXXXXX"; // Database name
    Are you getting confused between a testing server and a remote server? The remote server details that you supplied in your post are infact your FTP details to login into the server and upload/delete any files and the test server deatils wouldn't be an FTP connection either
    You  might want to read this in regards to setting up a local testing server:
    http://www.webassist.com/support/documentation/how-tos/xampp_for_windo ws.php
    Feb 6, 2013 10:02 AM   in reply to hsysgrp
    It's just been reported to the moderators. Hopefully they'll remove the details soon.
    Feb 6, 2013 10:37 AM   in reply to hsysgrp
    Use REMOTE server details.
    When you're ready to go live, change REMOTE details to your other server.
    Or, Simply create a TEST folder on your Remote server.  Add TEST folder to your Root directory (see screenshot).
    Root directory: htdocs/TEST/
    When you're ready to go live, remove the TEST folder.
    Nancy O.
    Feb 6, 2013 11:15 AM   in reply to hsysgrp
    As you are looking at this screen, if you view your post with those details there should be a text link for Edit that you can click to remove the password and such.
    ^_^
