As I understand there are at least three ways to move a video from Premiere Pro to Encore: (1) move sequence via dynamic link (2) Make a movie in Premiere Pro (avi perhaps) then import in Encore for final transcoding and (3) Transcode in Premiere Pro. Which method will result in the best quality DVD, or is there no noticable difference? Input is appreciated. Thanks.
My personal choice is to export Widescreen DV AVI from PPro (AVCHD source) and then let Encore do automatic transcoding when building my DVD image... so I let Encore take care of all the calculation of "best fit" of movie length to selected single or dual layer disc
Other people prefer to export MPEG2 DVD from PPro, and then give the individual video and audio files to Encore for authoring
I do NOT use Dynamic Link, because I have read of some problems
http://forums.adobe.com/thread/936216
http://forums.adobe.com/thread/938108
http://forums.adobe.com/thread/938549
Encoding notes http://forums.adobe.com/thread/1094516
I also have Encore create an ISO image and use http://www.imgburn.com/index.php?act=download to write that ISO to disc, since Imgburn gives me much more control
There is a fourth way which actually produces the 'best' quality.
4. Export out a lossless Intermediate and use HC Encoder's CQ mode to create a DVD compliant .m2v file.
http://www.bitburners.com/hc-encoder/
The other three are pretty equal as far as quality goes.
A question for the HC Encoder users - is the quality significantly better than other methods to burn DVDs.? I am curious, why use the HC Encoder since its use adds several steps to the process, i.e. the HC Encoder does not recognize avi format, thus Avithinth or some other program must be used to open the avi files in the decoder. Am I missing something?
Open your file in VDub, select Video>Filter>Resize and add the resize filter, with absolute pixels set at 720x576 (I am PAL), Aspect Ratio disabled, and filter Mode Lanczos3; check Interlaced as appropriate.
Then select Video>Colour Depth and set Decompression format to Auto, and Output Format to Same as decompression format.
Now select Video>Compression and select the Lagarith Lossless Codec.
Press F7 to start encoding.
This will produce a huge file, but the down-scaling quality is very good indeed.
You will have to put this file back into Premiere and use Interpret footage to bring it back to 16x9, then export for DVD.
If you do not already have the Lagarith codec installed on your system, you will have to download it and install it first. UT is an alternative lossless codec you could use - many people prefer it.
Thank you for the additional info. I am using Adobe Media Encoder. Lower bitrates results in smaller files. I would have thought smaller files = lower quality. Obviously I'm missing something (for instance: what exactly does "clean source video" mean?). WIll try encoding with smaller bit rates and see what the results look like. Thanks again for all the good info you folks are providing.
You misunderstood what Jim and I were saying. When I said HC Encoder can produce better results at lower bitrates, I meant in comparison to using AME. Not that lower bitrates look better than higher bitrates. Was saying that when comparing quality, it is harder to see a difference at high bitrates, but more obvious when making longer videos at lower data rates.
And by "clean video source", I mean a nice picture. If you are working from an old VHS tape that is grainy and nasty, then it's going to look bad no matter what. If you have a clear, sharp video to begin with, it will just encode better. More picture, less noise. Noise in an image does not compress well and uses up precious bandwidth.
Hope that clarifies, sorry for any confusion
Jeff
Hello,
This Tmpgenc looks pretty interesting.
However, so many of these workflows seem carefully tailored to a Windows environment.
I have a MacPro. Have similar high quality efforts been made in the Mac arena?
I've been searching and have not had much success.
Any thoughts?
Thanks!
Matt Dubuque, 100 Trees
North America
Asia Pacific
