Does anyone kow of a good way to shade or render a ship or boat hull? I have tried to use gradient mesh, but am not happy with the results. I am relatively new to Illustrator and am still learning. I am a marine artist switching from airbrush and pen to computer graphic illustrations. I am using the latest version of Illustrator. Thanks! Karl
The gradient mesh is a fairly advanced tool. If you want to have better control, take a look at the plug-in Mesh Tormentor (it's free). And take a look at this, it will give a good introduction in how meshes work: http://vectorboom.com/load/articles/web_roundups/mesh_tormentor_plugin _complete_guide/13-1-0-18
On top of it all, you should be prepared that you might need more than one object to render the hull. That means stacking of (semi)transparent objects, usaga of masks and blend modes to achieve your result.
Hi Steve,
Thanks for your reply. I am trying to achieve a realistic look to the hulls like as shown in the attached photo. The shading defines the contour of the hull. This picture is not my artwork. I wish mine looked half as good. Another fact is that I am learning this program on my own. I have no one to go to for answers, so bear with me.
Regards
Karl
That is basically the thecnique I used to create the drawing below; a rendering for a client's approval. I also come from an airbrush background, so that is how I thought of it; one layer laid over another; build the shadows in one direction, then, with another pass (layer) build from another direction (I hope I'm being clear). In any case, check out transparencies and blending modes.
It will take time, and practice, but you will get there.
To all of you who have responded, a big THANKS! I will try all of your suggestions. I think I know what path to take now (no pun intended).
Attached is a photo of what I am doing. It is a historical reconstruction of a schooner that sank in Lake Huron in 1900. I am bacially working from old photos and divers information.
Being a CAD guy for over 20 years, I think in CAD terms, so the new terminalogy throws me sometines. IE line vs path.
My drawing if that is what it is being called in the digital arts field today, is done in layers. The hull is divided into different layers, lower hull, upper hull, bulwarks etc. I figured this was the way to go because each have different contours. I may be overdoing it here but thats what I did. Am I wrong??
Just my opinion, but I think you're right on. I always find it easier to merge layers I later decide I don't need, than to take a layer full of complex elements and try to separate them into layers later.
It would be interesting to see your final result, if you care to post back when finished.
Good luck.
--OB
Hi Bob, Monika, Steve & Jacob
Well, I finally finished my schooner drawing. 83 layers later before flattening. These sailing vessels can be a real pain to do. I am not completely satisfied with my shading results, but it's a start. It's going to take time as I tend to be real nit picky on these historical projects. Thanks all for your help.
Karl
Very nice, Karl.
Do you feel different today (anchorbay turned mariner)?
You might consider continuing the water level hinting in front of the bow and behind the stern to show it all the way in front of the schooner, keeping it at a low Transparency>Opacity (all the way). thus revealing the (wavy) waterline (not the Plimsoll/load line).
Jacob,
I did have the waterline ahead and astern of the boat. I'm a little confused here, did you mean to bring the waterline to the front so that it shows along the whole length of the hull? I tried that but I thought it looked weird. I also had a 'bone in her teeth' (bow wave). Maybe I need to revisit this detail.
Started a new boat today, a shipwrecked steamer fron 1865. There have been approximately 9000 wrecks on the lakes since 1659 ( La Salle's GRIFFON) so I guess I have a lot of work to do. ![]()
Anchor Bay Boat Works is my un official organization name. I also produce model ship fittings on a limited basis and do custom work.
Regards,
Karl
Just curious, where are you guys located?
Karl,
I did, with a very low opacity so the hull shows through, just hinting the waterline to give an impression of how the boat floats.
I believe Bob is somewhere over there. For the rest of us, you can even see pictures (over) here:
Very nice, mariner41. I like it.
As to not being totally satisfied with it. I can understand. I don't know as I've ever done any project where I haven't wanted to tweek it 'Just a bit more'. Something I learned years ago in oil painting; sometimes you just have to know when to say 'It's done!' and step back.
Very, very nice!
--OB
North America
Asia Pacific
