Hello.
I built a short quiz in Captivate 6 and published the project in HTML5 files and as an SWF file. I'm working on a flex mobile project in Flash Builder 4.6 and I want to incorporate the Captivate quiz into this project. I can load the SWF using <s:SWFLoader id="loader" source="quiz/quiz.swf" />, but when I run the application the file doesn't play. When I use the debug tool, I receive the following error:
[SWF] CMT.swf - 3,695,040 bytes after decompression
[SWF] quiz/quiz.swf - 1,507,465 bytes after decompression
[SWF] quiz/quiz.swf/[[DYNAMIC]]/1 - 18,058 bytes after decompression
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at Function/<anonymous>()
Information from the view that the SWF file is loaded into:
<s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
title="'{data}' Test">
<fx:Declarations>
<!-- Place non-visual elements (e.g., services, value objects) here -->
</fx:Declarations>
</s:View>
I'm not sure how to go about fixing this problem. Is it just not possible to incorporate an SWF file not produced in Adobe Flash ? If so, would I be able to incorporate the HTML5 files instead?
Thank you for any help you could provide!
TJ
Hello TJ,
I saw your post and I'm very curious if you ever solved the problem. I'm running into the same problem as you did. Whatever I create in Captivate, it will give this error when I use it in a Mobile application in Flash Builder. And the strange thing is, it will not happen when I use the same swf in a WindowApplication.
Did you ever solve this problem?
Please let me know, because if this problem can not be solved, I have to redo about 70 questions now made in Captivate.
Bart van de Rotsheide
Hello, Bart.
Unfortunately, I was not able to resolve this problem.
TJ
