I've been trying to get a simple table with 3 cells to align properly. In the first cell is a vimeo video, text with an image in the next two cells.
The video aligns properly, and the other two cells do not.
I'd really be appreciative of any help you can give me.
Here is the table code and the image of what it produces. Below that is the CSS code for the blogholder and cellborder styles. Really simple stuff but I can't figure out why it doesn't align properly. I am inexperienced in trying to put up a vimeo video.
Thanks in advance for any clues for what is in my way.
CODE:
<div class="blogholder" >
<table width="918" border="0" cellpadding="10">
<tr valign="top">
<td colspan="3"><hr /></td>
</tr>
<tr>
<td width="300" height="306" align="left"><iframe src="http://player.vimeo.com/video/57555762" width="280" height="282" frameborder="0"></iframe></td>
<td width="280" align="top" valign="top" class="cellborder">
<img src="Images/HomePage/dd-mandala.png" alt="David's Desk logo" width="108" height="101" />
<p><strong> David's Desk </strong></p>
<p align="left"><em><strong>#69 Zombie Apocalypse</strong></em><br />
<strong>By David Spangler</strong></p>
<p> Having had several years when vampires were the cultural monster de jour, it now seems that zombies are having their turn. Books, games, television shows, and movies about zombies are proliferating... .<a href="http://lorian.org/davidspage.html#gpm1_2"><br /><u>Read more</u></a> </p> </td>
<td width="300" align="top" valign="top" class="cellborder" ><strong><img src="blog-mandala2.jpg" alt="Lorian blog mandala" width="100" height="100" class="textwrap"/>Views from the Lorian Community</strong>
<p align="center"><em><strong>#69 Zombie Apocalypse</strong></em><br />
<p align="left">Having had several years when vampires were the cultural monster de jour, it now seems that zombies are having their turn. Books, games, television shows, and movies about zombies are proliferating... .<a href="http://lorianblog.wordpress.com/">
<u> Read more</u></a> </p> </td>
</tr>
<tr align="center" valign="top">
</tr>
</table>
</div>
CSS CODE:
.blogholder {
border-left-style: none;
border-left-color: #FFFFFF;
padding: 10px;
vertical-align: top;
border-top-style: none;
border-right-style: none;
border-bottom-style: none;
border-top-color: #FFFFFF;
border-right-color: #FFFFFF;
border-bottom-color: #FFFFFF;
.cellborder {
border-left-width: thin;
border-left-style: solid;
border-left-color: #000000;
I tried it, and it made no difference. Thanks for the suggestion. Are there any others?
If tables are no longer used, is the better approach just to use CSS to position them? I switched to tables because I was having difficulty getting things to position correctly. But is that the better approach now? Is there something else I need to try?
Thanks.
CSS with floats (you won't need anything like position:relative added) would be easiest. Here's a very basic 3 column/centered layout...
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
<style type="text/css">
.column {
width:300px;
float:left;
height:600px;
border:1px solid black;
padding:5px;
#wrapper {
width:936px;
margin:auto;
</style>
</head>
<body>
<div id="wrapper">
<div class="column">Content1</div>
<div class="column">Content2</div>
<div class="column">Content3</div>
</div>
</body>
</html>
This has not worked. I have been trying to manage the floating divs but first they are stacked on top of each other and then one is out to the right but in the middle o the page. Really strange. This is why I went to using tables in the first place, because I couldn't get the floating parts to work without a lot of fuss.
What is not working with the first effort? The table version seems like it should work. It does work if all three cells are filled with text, but the vimio video seems to be where the problem is. Do any of you have any ideas on what the problem is there? Why the video might be causing it to be misaligned?
Thanks, this seems like such a simple problem, but it's driving me nuts!
My link is http://lorian.org/index2.html (table version) and index3.html.(CSS floated version). With 3 I subsequently tried to use a different CSS style rather than .forcellhome for each cell to float them to the right. Just made more of mess and seems so much more complicated. I'd really like to get the table version working.
Hi, I have checked your code it is working fine, recheck it once... copy the code bellow and past it in a new html page and check.
<head>
.blogholder {
padding: 10px;
.cellborder {
</style>
</head>
<body>
<tr valign="top">
</tr>
<tr>
</tr>
</tr>
</table>
</div>
</body>
</html>
This works. Both you and osgood have said that the code I displayed here is ok, and this proves that something else is the problem. Thanks for this.
However, what is it? I still don't know what the problem is.
Thanks for working with it. It's good to know.
Any ideas on what else might cause the problem?
I have yet to identify the issue when using a table based layout but as you say if you remove the video the content in col 2 and 3 sits where it should do at the top of the table.
For now get rid of the <div class="blogholder" ></div> AND table code betweeen it and repalce it with the 3 floating <divs> below: (Inline css styling shown)
<div id="wrapper" style="width: 918px; overflow: hidden; padding: 20px 0; border-top: 1px solid #999; border-bottom: 1px solid #999;">
<div id="col_1" style="float: left; width: 280px; text-align: center; padding: 0 15px 0 15px;"><iframe style="float: left;" src="http://player.vimeo.com/video/57555762" width="280" height="282" frameborder="0"></iframe></div>
<!-- end col_1 -->
<div id="col_2" style="float: left; width: 285px; margin-left: 7px;">
<img src="http://lorian.org/Images/HomePage/dd-mandala.png" alt="David's Desk logo" width="108" height="101" />
</div>
<!-- end col_2 -->
<div id="col_3" style="float: left; width: 285px; margin-left: 20px;">
<strong><img src="http://lorian.org/blog-mandala2.jpg" alt="Lorian blog mandala" width="100" height="100" class="textwrap"/>Views from the Lorian Community</strong>
</div>
<!-- end col_3 -->
</div>
<!--end wrapper -->
North America
Asia Pacific
