Hey,
We have bought a license key for upgrade from Flash Builder 4.0 SE to Flash Builder 4.7 SE, but we need access to Designer View which is not available in FB 4.7.
Our distributor tell us, that it is possible by doing downgrade to Flash Builder 4.6. To do it we should contact with Adobe Support.
So our questions are:
1. How can we downgrade Flash Builder from 4.7 SE to 4.6?
2. Could we change our license key to 4.6 license key?
3. How can we download Flash Builder 4.6 binary files?
Best regards,
Juri
Hello.
I have the same problem. Could someone give us an answer.
Thanks a lot.
Doesn't look like anyone wants to help. But if they do, I'd sure like some information on this myself.
In order for you to downgrade you need to hava an AVL license, and yes it is possible, you just need to call support.
http://www.adobe.com/volume-licensing/policies.html
Check Backward licensing policy
"Adobe allows program members to order a current-version license but use a prior version. These members can contact Adobe Customer Service to request a serial number for the earlier version if they do not already have one. Prior-version software is available via ESD and can be purchased through standard resellers. The program member must follow all guidelines of the current-version EULA.
Note: This policy is applicable under the TLP and Forms Licensing Program (FLP) as well."
Hope it helps!
