jenjabbour
RH10 backwards compatible with RH9?
Feb 7, 2013 10:41 AM
Tags: #compatibility #compatible #rh9 #rh10
I am currently running RH9, and my coworker is going to start using RH but has to purchase RH10, since RH9 is no longer for sale.  So I'm wondering if this means that I now have to upgrade to RH10, since we will be working on the same projects. I will need to be able to go back into projects he has worked on in RH10.
    Feb 7, 2013 10:49 AM   in reply to jenjabbour
    Once the project is upgraded, that's it. If you purchased RH9 through volume licensing, you can obtain more licenses for RH9 that way.
    Feb 7, 2013 10:58 AM   in reply to Jeff_Coatsworth
    There is a backdoor way of doing it if none of the Rh10 features have been used but I would not recommend it on a regular basis. You would need to check things every time and it might be some time before you spot something. I suspect there would be tears eventually.
    @petergrainge
    Feb 7, 2013 11:03 AM   in reply to jenjabbour
    Whoo-hoo - upgrades to RH10 all round!!
