Yes, the infamous ENCODE FAILED message.
I've been having problems right along trying to use Dynamic Link to export from Premiere Pro CS6 to Encore CS6. So I started exporting the project first and then importing the resulting file into Encore as a timeline, which has mostly worked.
So far, so good. But now I have made the switch from SD video to HD (ACVHD; 60i), and am trying to burn a DVD of my first HD project. I exported the Premiere project as an MPEG2, then imported the file in Encore as a timeline. Then I got the "Encode Failed" message, and I have no idea how to proceed.
My computer: Acer Aspire laptop, quadcore, 64-bit. There is plenty of empty space on the hard drive for the Encore project.
Premiere Pro output settings used to encode the MPEG: NTSC; 1280x720; 29.97fps; Quality 5.0; De-Interlaced; VBR; 2 pass; min 4.00; Target 10.00; Max 18.50 Mbps; MPEG; 384 Kbps; 16 bit; Stereo
Source settings: 1920x1080 (1.0); 29.97 fps; upper; 48000 Khz; Stereo
The resulting MPEG filesize is about 4.5GB.
Encore project settings:
Auth Mode: DVD
TV Standard: NTSC
Transcode Settings: Codec MPEG-2; 720x480; Frame Rate 29.97; Lower Field First; Dolby Digital; Max A/V Bitrate 7.0Mbps.
Am I missing something obvious? I'm not experienced with HD, or really all that much with Encore. Can anyone point me in the right direction?
Thank you.
There was no "do not trancsode" message when I imported the file into Encore.
I am able to import the MPEG2 into Encore as a timeline. I can then press the spacebar and see the viedeo play on the Encore timeline. I check the project before pressing BUILD, and there are no issues. Then I press BUILD, and about 10 seconds later I get the "Encode Failed" message.
You do not get a message. In the Encore project panel, look at the asset (the file you imported, not the timeline made out of it). To the right, you will its transcode status. What does it say?
When you press build, if Encore says that you have not already transcoded the assets, it does that first before "building" the disk etc. I believe that most of the Encode Failed errors are transcode issues, but I don't know for sure.
You can separate that issue by transcoding first by using "transcode now." However, if you exported correctly from Premeire, you should see "Do Not Transcode" or "Transcoded."
Ok, so I encoded using the MPEG2-DVD setting, and then imported the files into a new Encore project as a timeline. There were 2 files...a .m2v and a .wav.
In the project settings, the .m2v said don't transcode, and the .wav said untranscoded. I tried to transcode the .wav, but got an encode failed message. I'm not even sure if it's necessary to transcode the .wav. Anyway, I then tried to build the DVD, and again got the encode failed message.
That is correct.
That is correct. Most users want a dolby (ac3) file, and that is why Encore wants to transcode it. In earlier versions, the only free dolby encoder was in Encore. You can encode to ac3 in Premiere, but it is not an issue.
That is instructive and points to the audio in Premiere/source as the issue. Do you have any (even one frame long) gaps in the audio?
All this means, since Encore will transcode any untranscoded assets before the rest of the build, is that the wav was not transcoded.
When you export from Premiere now, you can do an audio only export, wav or ac3. As long as you don't change the length of the audio. If you do, I'd export it all again.
1. The .wav's DVD Transcode Setting is "Automatic."
That is fine. It will transcode to the default transcode you set when you created the project. Check and make sure that is dolby.
2. The timeline I exported from Premiere was exactly 59 minutes in duration. After importing the files as a timeline, the Encore timeline is about 3.5 seconds longer. Huh?
Makes no sense. Confirm that the file exported from Premiere is exactly 59. When you zoom in on the Encore timeline, are the video and audio exactly the same length?
It's getting weirder and weirder.
I imported the ac3 into Encore, put it on the timeline, and it's a fraction of a frame longer than the video. About 1/3 frame. I didn't know that was even possible.
But out of curiosity I pressed Build, and did not get the EFing message. (pardon my pun.) So I will play the DVD and see if the video is really 3.5 seconds too long.
In Premiere, I pressed the End button and than zoomed all the way in. 59 minutes exactly for both audio and video.
Tiny differences in video/audio length are not unusual, but can be a problem.
Let's hope this did it!
That does not mean that the file Premiere exported is exactly 59 minutes.
Use Gspot or MediaInfo to look at the file's length.
North America
Asia Pacific
