I am working on old Flex3 (Cairngorm2) app.
One of TextArea's there is completely ignoring new lines (Carriage Return/Line Feed)
and even skips some spaces (others work fine).
Code is pretty simple (well, little simplified here):
<fx:TextArea text="myText" selectable=true change=updateText(event)"/>
private function updateText(evt:Event):void {
var event:UpdateEvent = new UpdateEvent(UpdateEvent.UPDATE_EVENT);
event.myText=myText.text;
trace("myText"+event.myText) //added by me
event.dispatch();
I have read about weird behaviors of TextArea (skipping or even doubling some characters) on the net,
but so far could not find anything applicable in that case.
For example, something like myText.text.replace("\n", "\r") doesn't change anything.
I guess, there is no "\n" there.
If I trace, it returns line without newlines (like: 'startskip1lineskip2linesend;').
But if I copy-paste that line to say another TextArea on the screen (or non flex Chat app, I would get multiline text:
'start
skip1line
skip2lines
end;
And for various reasons I can't debug that app.
Any idea what might be wrong and how to fix it?
Please help!
TIA,
Oleg.
P.S.: App connects to SPs in the Database via Web Service. No BlazeDS.
I haven’t heard of this problem before. I’d guess there is code running that is removing the line breaks. I would first check to see if both \r and \n are being removed or not. Then I’d add a keyDown handler and single step in the debugger through the hundreds of lines of code that run when you hit a key. My guess is that you’ll end up in code you didn’t expect that is removing the whitespace.
North America
Asia Pacific
